Yes, give it some time
im not able to add the aquara e1 to my deconz in home assitant, the conbee2 stick is up to date and the latest deconz availble in homeassistant is also installed, also newest ha,
is the e1 not avaible atm via the homeassistant deconz???
i tried everything, as a light, sensor, switch everything, can you tell me the exact way to pair it?
like when i must press what on the roller and deconz?
best regards
press and hold reset button in the buttom - blue light will blink
and then make a search in deconz under lights
already tried that more then one time, what could it be?
deCONZ
Current version: 6.15.0
conbee2:
2.17.01 / 1.7.2022Firmware26780700
does it blink blue?
yes, it blinks several times blue and then stops, and deconz don’t find a new lamp, also tried resetting with 10 seconds and so on.
hmm maybe yours dont work - I got 3 and all paired like I described.
i really don’t think its the device, something is not working maybe a setting in deconz i don’t know
i will now restart my pi maybe its working then.
try restart your HOST, not only HA
I have the same problem. Bought my E1 on Amazon.de. The device has a different model number and in deconz also a different identifier.
Model: Aqara CM-M01
Deconz model identifier: lumi.curtain.agl001
From deconz it can be operated. In Phoscon it does not appear at all. In Home Assistant as an unnamed device without any interaction possibility.
I believe the E1 Curtain Driver is a different product than the original post, which is the E1 Roller Shade Driver. I also can’t get the E1 Curtain Driver to work, and from the Deconz Discord, it looks like it’s not yet supported.
Why did they call them both “E1”!
Aqara Curtain Driver E1 ZNCLBL01LM
Not Deconz but working over ZigBee: Aqara Curtain Driver E1 - #14 by BrotherWrong?
The official conbee guide includes neither the blind or the curtain model which is confusing: ConBee II Compatibility list
I’ll keep looking and start the thread if necessary. If. Anyone finds something I am interested to know
sorry for reopening old thread.
i have 2 of these aqara roller shade driver e1
i have added them on phoscon as lumi.curtain.acn002
i found them on HA via deconz as the light bulb
but i cannot control them via HA
blind as bulb - on off does not work
brightness if i change does not work
how do i control this on HA?
update:
my deconz was on a different machine.
connected conbee2 to pi with HA.
now the deconz identified all the features of blind
Did you ever fix this?
One of my two motors fell off the network (again) but this time when I add it I just get the hex address as in your image. I’ve removed it, reset it, rebooted my host and all the things I can think of but whenever I try and pair it this is what I get. It’s not listed in Phoscon (to be expected I guess). I’ve never had a device behave like this before.
