Hello. I’ve already got Philips Hue lights throughout the house, I’m about to redecorate the house and I consider replacing our traditional light switches with the Aqara wired smart switches.
The appeal for the wired smart switches is that we can still control the lights even if Home Assistant is down.
First question: I’m wondering if it’s also possible to combine it with automation, so for instance to turn on the light with different brightness and colour temperature based on the time of the day. Also, I’d like to light to turn on at different brightness if it was a short press or long press on the switch.
I reckon it could be tricky because the bulb would be powered off when the light is off, and the bulb would only be powered on after someone presses the switch on the wall. So I guess maybe it depends how long it takes for the bulb firmware to start up before it can receive a command from Home Assistant? Is it possible? Has anyone done it?
Second question: do you know if it’s possible to control the switch itself from Home Assistant. This would be required for a motion sensor to turn on the light, as it would need to power the bulb first, and then as per previous question, I could send a second message to the bulb to set the correct brightness and colour.
This is the switch I’m considering:
Thanks in advance
