Aqara t2 relay
Does anyone know about Aqara Single or double t2 relay supports routing or if it is an end device like the sonoff zigbee relay. Can not find anything on Aqara website about routing support.
Let me google that for you:
The T1 relay is also a router if you get the “with Neutral” version, according to this.
It would be safer to assume that the “no Neutral” version isn’t a router.
So and where is on your first link written that is has routing functionality? I can google this pages by myself. So when you google something please check that the needed infos are found on that page. Also on the Aqara page nothing is written.
And what do I care about a link for T1 when I ask about the T2?
Sorry, thank you for your „help“ but it was not helping.
It’s written here in my first link:
" Once paired to your coordinator in Zigbee2MQTT, the device is identified as model LLKZMK12LM by manufacturer Aqara. Even though this has not always been the case with Aqara devices, this one is correctly labelled as a Router, capable or relaying Zigbee mesh traffic."
I also added a screenshot from the first link which clearly shows Device type: Router. If it had been an end device, that screenshot would have shown Device type: End Device.
You asked for:
The Aqara single relay is called the T1. The double relay is called the T2. I provided links for both because I was trying to „help“.
Here’s a handy tip for you:
Hmmm
I wonder if it is possible to get energy consumption data from T2 to HA?
Energy consumption for the T2 is definitely supported in Z2M, so should be possible. Aqara LLKZMK12LM control via MQTT | Zigbee2MQTT
EDIT: @Ildar_Gabdullin If you do integrate via Z2M but don’t see any values for energy entities, you’ll need to update your coordinator firmware. I had the same issue with the Aqara H1M switches and it took me a while to find the answer.
All the info that shows up when it’s added via the ZHA intergration:
and I have it listed in my power usage via individual device tracking:
Mine is currently being used to control access to a power socket in a shared laundry room that has a lock on it in my block should said lock be broken and someone tries to steal power, the T2 L1 has to be in an active state before the socket physical switch can be turned on to allow power to flow. (all units in my block have a dedicated socket in this laundry room).
You havent the last version firmware. There is a new versiĂłn from 2024
Could you try to update? Yo did try with ota updates both zha and z2m but i got It.
