Aqara temp sensors show unavailable in HA but works in zigbee2mqtt
Hi all,
I just installed a new HA and a new Raspberry pi 4 with a CC26X2R1 card for zigbee2mqtt. The zigbee2mqtt seems fine, i get data from the sensors but in HA all show unavailable.
See data from the sensors (data which I can view also with mqqtexplorer)
This is zigbee2mqtt config
And this is how I see on all sensors in HA (so basically I see the sensors but not their data)
Any idea what I miss or did wrong on the setup?
Thank you very much
L.E. this is mosquitto broker config from HA
 logins: []
 customize:
   active: false
   folder: mosquitto
 certfile: fullchain.pem
 keyfile: privkey.pem
 require_certificate: false
hi
any log in H.A (about mqtt) ?
sometimes sensors take ± 30 minutes to report states if the temp/humidity does not move a lot
I don t see something helpfully in the log but I just warm up 2 sensors and I see I get data in zigbee2mqtt status about new temperatures but HA is like does not see them. I guess once pi send these to mqtt then HA should get them,
yes it should…
hassio read mqtt
why your do not? see mqtt logs if clients are all connected or not.
have you other mqtt working devices (within hassio)?
No other mqtt devices …where are the logs you talk about? I guess are somewhere in HA
At some point yesterday started to work and now after more than 24 hours I have again unavailable …meanwhile did nothing to any system…so something is happening
Ok, I used terminal adn subscribed to ‘homeassistant/#’ topic .
While in zigbee2mqtt service status I see messages sent to that topic with sensors and data, in HA console I see only
Client (null) sending PINGREQ
Client (null) received PINGRESP
That means the messages from zigbee2mgtt does not arrive in HA?
I also restarted both zigbee2mgtt and HA and same result
Add this to configuration.yaml :
logger:
  default: error
  logs:
    homeassistant.components.mqtt: debug
Restart HA en post the log.
I added your conf and restarted HA. Then go to Supervisor → Mosquito → Log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] mosquitto.sh: executing...
[21:29:02] INFO: Setting up user mqtthass
[21:29:02] INFO: SSL is not enabled
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[21:29:02] INFO: Starting NGINX for authentication handling...
[21:29:03] INFO: Starting mosquitto MQTT broker...
1633717743: mosquitto version 1.6.12 starting
1633717743: |-- *** auth-plug: startup
1633717743: Config loaded from /etc/mosquitto/mosquitto.conf.
1633717743: Loading plugin: /usr/share/mosquitto/auth-plug.so
1633717743:  ├── Username/password checking enabled.
1633717743:  ├── TLS-PSK checking enabled.
1633717743:  └── Extended authentication not enabled.
1633717743: Opening ipv4 listen socket on port 1883.
1633717743: Opening ipv6 listen socket on port 1883.
1633717743: Opening websockets listen socket on port 1884.
1633717743: Warning: Mosquitto should not be run as root/administrator.
1633717743: mosquitto version 1.6.12 running
1633717743: New connection from 127.0.0.1 on port 1883.
1633717743: Socket error on client <unknown>, disconnecting.
1633717743: New connection from 172.30.32.1 on port 1883.
1633717743: New client connected from 172.30.32.1 as auto-A1F17FB2-0B2A-3E3A-B2F2-AC22D44CA97B (p2, c1, k60, u'mqtthass').
[21:29:04] INFO: Successfully send discovery information to Home Assistant.
[21:29:04] INFO: Successfully send service information to the Supervisor.
and this is zigbee2mqtt status
Oct 08 21:30:05 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-08 21:30:05: MQTT publish: topic 'homeassistant/sensor/0x00158d000588a12a/pressure/config', payload '{"availability":[{"topic":"homeassistant/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d00
Oct 08 21:30:05 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-08 21:30:05: MQTT publish: topic 'homeassistant/sensor/0x00158d000588a12a/voltage/config', payload '{"availability":[{"topic":"homeassistant/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d000
Oct 08 21:30:05 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-08 21:30:05: MQTT publish: topic 'homeassistant/sensor/0x00158d000588a12a/linkquality/config', payload '{"availability":[{"topic":"homeassistant/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158
Oct 08 21:30:05 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-08 21:30:05: MQTT publish: topic 'homeassistant/sensor/0x00158d0006795415/battery/config', payload '{"availability":[{"topic":"homeassistant/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d000
Oct 08 21:30:05 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-08 21:30:05: MQTT publish: topic 'homeassistant/sensor/0x00158d0006795415/temperature/config', payload '{"availability":[{"topic":"homeassistant/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158
Oct 08 21:30:05 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-08 21:30:05: MQTT publish: topic 'homeassistant/sensor/0x00158d0006795415/humidity/config', payload '{"availability":[{"topic":"homeassistant/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d00
Oct 08 21:30:05 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-08 21:30:05: MQTT publish: topic 'homeassistant/sensor/0x00158d0006795415/pressure/config', payload '{"availability":[{"topic":"homeassistant/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d00
Oct 08 21:30:05 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-08 21:30:05: MQTT publish: topic 'homeassistant/sensor/0x00158d0006795415/voltage/config', payload '{"availability":[{"topic":"homeassistant/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158d000
Oct 08 21:30:05 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-08 21:30:05: MQTT publish: topic 'homeassistant/sensor/0x00158d0006795415/linkquality/config', payload '{"availability":[{"topic":"homeassistant/bridge/state"}],"device":{"identifiers":["zigbee2mqtt_0x00158
Oct 08 21:31:35 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-08 21:31:35: MQTT publish: topic 'homeassistant/temp-dormitor-noi', payload '{"battery":100,"humidity":47.98,"linkquality":120,"pressure":1015.3,"temperature":24.45,"voltage":3005}'
Now I am surprised because I have no idea who is "172.30.32.1 " but looking on terminal on HA i see HA has this ip on eth0. why? And seems somehow mosquito will start on this ip i guess
In supervisor → system my ip is 192.168.55.10/24 which is the one I am accessing the interface also and is defined on zigbee2mqtt as mqtt server.
Zigbee2mqtt client have the ip 192.168.55.11 but i don t see it anywhere in log…
What is wrong with my configuration ?
thanks a lot for log suggestion :slight_smile:
L.E. - I rebooted HA (host ) and after came back I have this in log of HA
[fix-attrs.d] done.
[21:46:11] INFO: Setting up user mqtthass
[21:46:11] INFO: SSL is not enabled
[cont-init.d] done.
[21:46:12] INFO: Starting NGINX for authentication handling...
[services.d] done.
[21:46:12] INFO: Starting mosquitto MQTT broker...
1633718772: mosquitto version 1.6.12 starting
1633718772: |-- *** auth-plug: startup
[21:46:13] INFO: Successfully send discovery information to Home Assistant.
[21:46:13] INFO: Successfully send service information to the Supervisor.
1633718772: Config loaded from /etc/mosquitto/mosquitto.conf.
1633718772: Loading plugin: /usr/share/mosquitto/auth-plug.so
1633718772:  ├── Username/password checking enabled.
1633718772:  ├── TLS-PSK checking enabled.
1633718772:  └── Extended authentication not enabled.
1633718772: Opening ipv4 listen socket on port 1883.
1633718772: Opening ipv6 listen socket on port 1883.
1633718772: Opening websockets listen socket on port 1884.
1633718772: Warning: Mosquitto should not be run as root/administrator.
1633718772: mosquitto version 1.6.12 running
1633718772: New connection from 127.0.0.1 on port 1883.
1633718772: Socket error on client <unknown>, disconnecting.
1633718773: New connection from 192.168.55.11 on port 1883.
1633718773: New client connected from 192.168.55.11 as mqttjs_b1d52a3c (p2, c1, k60).
1633718789: New connection from 172.30.32.1 on port 1883.
1633718789: New client connected from 172.30.32.1 as 5sBTAyWxFbyaSzz6TYXHJI (p2, c1, k60, u'mqtthass').
and if I am looking on the zigbee2mgtt log I see this
Oct 08 21:45:55 clhomezgb01 npm[11056]: Zigbee2MQTT:error 2021-10-08 21:45:55: Not connected to MQTT server!
Oct 08 21:46:05 clhomezgb01 npm[11056]: Zigbee2MQTT:error 2021-10-08 21:46:05: Not connected to MQTT server!
Oct 08 21:46:13 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-08 21:46:13: Connected to MQTT server
Oct 08 21:46:13 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-08 21:46:13: MQTT publish: topic 'homeassistant/bridge/state', payload 'online'
Oct 08 21:46:49 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-08 21:46:49: MQTT publish: topic 'homeassistant/temp-dressing-etaj', payload '{"battery":100,"humidity":48.92,"linkquality":42,"pressure":1017.6,"temperature":21.47,"voltage":3035}'
So, somehow the zigbee2mqtt is connecting to my HA …but I still have devices unavailable …
What does the homeassistant log say?
this one?
21-10-09 07:16:50 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-10-09 07:46:11 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-10-09 07:46:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-10-09 07:46:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
21-10-09 07:46:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
21-10-09 07:46:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-10-09 07:46:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
21-10-09 07:46:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-10-09 07:46:11 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-10-09 07:46:11 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-10-09 07:46:11 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-10-09 07:46:11 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-10-09 07:46:11 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-10-09 07:46:43 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-10-09 07:46:50 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-10-09 08:16:51 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-10-09 08:20:11 INFO (MainThread) [supervisor.host.info] Updating local host information
21-10-09 08:20:12 INFO (MainThread) [supervisor.host.services] Updating service information
21-10-09 08:20:12 INFO (MainThread) [supervisor.host.network] Updating local network information
21-10-09 08:20:13 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-10-09 08:20:13 INFO (MainThread) [supervisor.host.manager] Host information reload completed
21-10-09 08:37:34 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:37 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:40 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:41 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:42 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:43 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:44 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:45 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:46 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:47 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:48 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:49 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:50 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:51 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:52 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
21-10-09 08:37:53 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session cad9b7337e024b7fcfe04cb20220636c840ee7df2b006b500607a61efd2edbd63550c9074a50da72102215fd36da7e21b6b1219e91bbbb3c338614587a1cf184
No , HA : configuration → logs
i see only one client (zigbee2mqtt? ) connected, one disconnected (hassio?).
seems there are not all on the same network.
127.0.0.1 ----> docker network mode ‘host’ (= your host : 193.168.55.10)
172.30.32.1----> docker custom network ‘bridge’
@francisp this is the HA log
Was too long to paste it here
@tomdudu38
192.168.55.11 is a raspberry pi which run zigbee2mqtt
192.168.55.10 is HA running on a intel nuc
Both are in the same network
HA clearly receives messages from mqtt.
What bothers me, in that log there are no temperature or humidity messages, and zigbee2mqtt is offline.
2021-10-08 21:46:33 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/bridge/state (retained): b'offline'
this is from now on zigbee2mqtt
[email protected]:~ $ sudo systemctl status zigbee2mqtt.service
[sudo] password for clhome:
● zigbee2mqtt.service - zigbee2mqtt
   Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; vendor preset: enabled)
   Active: active (running) since Fri 2021-10-08 21:29:58 EEST; 21h ago
 Main PID: 11056 (npm)
    Tasks: 23 (limit: 4915)
   CGroup: /system.slice/zigbee2mqtt.service
           ├─11056 npm
           ├─11067 sh -c node index.js
           └─11068 node index.js
Oct 09 19:09:37 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-09 19:09:37: MQTT publish: topic 'homeassistant/temp-bucatarie', payload '{"battery":100,"humidity":48.84,"linkquality":36,"pressure":1023.1,"temperature":23.2,"voltage":3005}'
Oct 09 19:09:48 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-09 19:09:48: MQTT publish: topic 'homeassistant/temp-dormitor-luca', payload '{"battery":100,"humidity":50.88,"linkquality":72,"pressure":1015.8,"temperature":23.57,"voltage":3025}'
Oct 09 19:10:14 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-09 19:10:14: MQTT publish: topic 'homeassistant/temp-hol-etaj', payload '{"battery":100,"humidity":51.03,"linkquality":96,"pressure":1019.1,"temperature":22.77,"voltage":3025}'
Oct 09 19:10:14 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-09 19:10:14: MQTT publish: topic 'homeassistant/temp-hol-etaj', payload '{"battery":100,"humidity":51.06,"linkquality":96,"pressure":1019.1,"temperature":22.77,"voltage":3025}'
Oct 09 19:10:14 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-09 19:10:14: MQTT publish: topic 'homeassistant/temp-hol-etaj', payload '{"battery":100,"humidity":51.06,"linkquality":96,"pressure":1019,"temperature":22.77,"voltage":3025}'
Oct 09 19:11:24 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-09 19:11:24: MQTT publish: topic 'homeassistant/temp-dining', payload '{"battery":91,"humidity":48.29,"linkquality":72,"pressure":1018.6,"temperature":23.45,"voltage":2985}'
Oct 09 19:11:24 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-09 19:11:24: MQTT publish: topic 'homeassistant/temp-dining', payload '{"battery":91,"humidity":48.46,"linkquality":75,"pressure":1018.6,"temperature":23.45,"voltage":2985}'
Oct 09 19:11:24 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-09 19:11:24: MQTT publish: topic 'homeassistant/temp-dining', payload '{"battery":91,"humidity":48.46,"linkquality":75,"pressure":1018,"temperature":23.45,"voltage":2985}'
Oct 09 19:17:49 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-09 19:17:49: MQTT publish: topic 'homeassistant/temp-baie-parter', payload '{"battery":100,"humidity":52.15,"linkquality":48,"pressure":1019.4,"temperature":22.85,"voltage":3025}'
Oct 09 19:19:17 clhomezgb01 npm[11056]: Zigbee2MQTT:info  2021-10-09 19:19:17: MQTT publish: topic 'homeassistant/temp-dressing-etaj', payload '{"battery":100,"humidity":51.19,"linkquality":21,"pressure":1018.6,"temperature":23.04,"voltage":3035}'
So this is not offline…
What do you think I can do or try to fix it…:frowning:
Thanks anyway for all help you gave me …
how did you install mqtt?
did you use the integration or manual config?
seems you used manual config
u could add dicovery:true in ha / mqtt config or try the integration
I installed it by Supervisor - Add-on store
I changed config at some point looking for a solution to my issue
actual config is
logins:
  - username: mqtthass
    password: xxx
customize:
  active: false
  folder: mosquitto
When I installed it discovered all aqara devices from zigbee2mqtt and run about 1 or 2 days without any issues and without I doing something …then problems started
I think I will uninstall mqtt addon and reinstall it again… don t know what else I could do to make it working
Do you use other mqtt devices beside zigbee2mqtt ?
No, that zigbee2mqtt is the only one integration that I have on mqtt.
Found something weird…I did uninstall mqtt from supervisor and then rebooted the host
mqtt is gone now which is normal
But when I go to Configuration → integrations I still see mqtt there and i am able to configure it ???
Shouldn t be gone also from here? Maybe somehow I had it double ?
How to make sure I get rid off it and make a clean installation of mqtt?
I see there is a delete button, I will delete it from here as well
2 mqtt brokers seems the reason for this strange behavior.
