Recently purchased an Aqara vibration sensor DJT11LM. Device was successfully paired via Z2M. It is specified that includes a binary sensor. I have paired the device again, but binary sensor does not appear. Have I done something wrong?
Binary sensor is one entity of the device it should’ve exposed.
Do you see a new device in HA but no binary sensor listed? Perhaps it is disabled by default?
Is there no device in HA at all? Perhaps you have MQTT discovery disabled in HA? Check your MQTT config.
Is there a device in HA but simply no binary sensor disabled or enabled? Sounds like a bug in Z2M in that case.
Tough to provide help given the information. Please clarify what you see in Z2M and what you see in HA. A screenshot of the device page in HA might help. Also the published MQTT discovery info should be listed on that device page. Or if there is no device then that helps to know too.
Interesting. In that case I think it’s a bug with Z2M. Especially if the binary sensor is missing from the discovery info entirely. HA really has no control over that, it just makes what Z2M tells it to.
I would report an issue here. Z2M also has a discord server so you could try there.
