Aqara Wireless Remote Switch (Single Rocker) via xiaomi_aqara Integration
This is the blueprint for the latest version of the Remote Switch model remote.b186acn02 based on the blueprint for the double rocker (Xiaomi_aqara - Aqara Wireless Remote Switch (Double Rocker))
blueprint:
  name: xiaomi_aqara - Aqara Wireless Remote Switch (Single Rocker)
  description: Automate your Xiaomi Aqara Wireless Remote Switch (Single Rocker) using xiaomi events.
  domain: automation
  input:
    aqara_single_switch:
      name: Select the Aqara Wireless Remote Switch (Single Rocker)
      description: Aqara Wireless Remote Switch (Single Rocker)
      selector:
        device:
          entity:
          - integration: xiaomi_aqara
          filter:
          - model: remote.b186acn02
          multiple: false
    button_single_press:
      description: Action to run on single press
      default: []
      selector:
        action: {}
    button_double_press:
      description: Action to run on double press
      default: []
      selector:
        action: {}
    button_long_press:
      description: Action to run when button is long pressed (held down)
      default: []
      selector:
        action: {}
  source_url: https://community.home-assistant.io/t/aqara-wireless-remote-switch-single-rocker-via-xiaomi-aqara-integration/878020
mode: restart
max_exceeded: silent
variables:
  aqara_single_switch: !input aqara_single_switch
triggers:
- trigger: event
  event_type: xiaomi_aqara.click
conditions:
- condition: template
  value_template: '{{ device_id(trigger.event.data.entity_id) == aqara_single_switch
  alias: Check for device_id
actions:
- variables:
    click_type: '{{ trigger.event.data.click_type }}'
    entity_id: '{{ trigger.event.data.entity_id }}'
- choose:
  - conditions:
    - '{{ click_type == ''single'' }}'
    sequence: !input button_single_press
  - conditions:
    - '{{ click_type == ''double'' }}'
    sequence: !input button_double_press
  - conditions:
    - '{{ click_type == ''long'' }}'
    sequence: !input button_long_press
Hello osono-design,
Welcome to the Home Assistant Forum!
Thanks for contributing to the community with a new Blueprint.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
