Ionut
(Ionut Cristea)
May 14, 2019, 1:28pm
243
Hello all,
Version 1.3.3.0 is out.
What’s new:
update Russian localization
updated Google libraries
show time when notifications are received
reduced internet data consumption
Please test it and let me know how it goes. Thank you.
Ionut
(Ionut Cristea)
May 17, 2019, 8:45am
244
Hello all,
Version 1.3.3.1 is out.
What’s new:
Changed badges UI look
small other UI changes
Fixed Mobile App notification event issue
fixed mobile_app typo
Yoinkz
May 20, 2019, 7:09pm
245
Sorry - been travelling.
Here is my conf:
- platform: generic
still_image_url: https://xxx.xxx.xxx.xx/snap.jpeg
stream_source: rtsp://xxx.xxx.xx.xx:7447/xxxxxxxxxxxx
verify_ssl: false
Ionut
(Ionut Cristea)
May 23, 2019, 11:25am
246
Version 1.3.3.2 is out.
What’s new:
NEW: support for Lovelace Picture card
NEW: added option to enable / disable scroll down refresh in Web Ui
NEW: add possibility to set the horizontal-stack card number of visible items
fixed invalid thermostat command send when changing values
fixed invalid cover grayed out buttons
fixed entity-button icon
small device tracker improvements
small UI changes
Please test it and let me know if works. Thank you.
Ionut
(Ionut Cristea)
May 27, 2019, 10:20am
248
Version 1.3.3.3 is out.
What’s new:
NEW: MQTT Notification grabber (send notifications info from other apps to Home Assistant)
fixed crash when device tracker name can’t be retrieved
other fixes
Notification grabber sensor documentation can be found here:
http://ariela.surodev.com/2019/05/27/notifications-grabber/
koying
(Chris B)
May 29, 2019, 10:54am
249
Please add some kind of migration path from the Free version to the PRO one, ideally through in-app purchase, but an “export/import config” would be already great
Ionut
(Ionut Cristea)
May 29, 2019, 11:20am
250
Thank you for the suggestion. I will see what i can do about this.
Ionut
(Ionut Cristea)
May 30, 2019, 11:48am
251
Version 1.3.3.4 is out.
What’s new:
remove quotes in wifi mqtt sensor ssid
fixed invalid battery mqtt sensor icon display
setup screen UI changes and simplification
other UI changes
hardware accelerated UI drawing
Ionut
(Ionut Cristea)
June 3, 2019, 12:11pm
252
Hello all,
Version 1.3.3.5 is out.
What’s new:
rework on UI items (in order to show properly color schemes)
fixed crash when showing vacuum entity information’s
fixed text overlap in entity dialog info
Ionut
(Ionut Cristea)
June 4, 2019, 9:16am
253
Version 1.3.3.6 is out.
What’s new:
NEW: added MQTT publish retain option
NEW: added option to force the Mobile App integration
better compatibility with OS Night Mode
Note: if you use to force the Mobile App integration, do not forget to delete the old entry from HOMEASSISTANTFOLDER/.storage/core.device_registry file.
Ionut
(Ionut Cristea)
June 10, 2019, 6:45am
254
Hello all,
Version 1.3.3.7 of Ariela is available.
What’s new:
NEW: support Mobile APP sensors
NEW: moved sensors from MQTT to the main settings since sensors aren’t MQTT only now
NEW: support opening url in notifications
change MQTT dev tool button text to publish
change “Mobile API notification” text to “Mobile APP notification”
@robbiet480 thank you very much for developing this cool component.
Note: some sensors are only available to the MQTT but most of them are compatible with mobile app too. Please test it and let me know how it goes. Thank you.
Ionut
(Ionut Cristea)
June 11, 2019, 6:09am
255
Hello all,
Version 1.3.3.8 is out. What’s new:
NEW: added option to vibrate when toggling switches, buttons etc
NEW: added option to vibrate when clicking on widgets
updated Russian localization
fixed device tracker issue loading even if disabled
fixed issue where user can’t enter sensors screen if MQTT is not enabled
added information dialog when forcing mobile_app on device
Thank you
phdemart
(Philippe Demartin)
June 11, 2019, 3:22pm
256
Work’s greate, t6he only problem I have, is the notification who don’t switch to the dark mode.
Ionut
(Ionut Cristea)
June 11, 2019, 4:19pm
257
I will add this to my TODO list.
Ionut
(Ionut Cristea)
June 12, 2019, 6:36am
258
Hello all,
Version 1.3.3.9 is out.
What’s new:
NEW: support for camera streaming
updated German localization
fixed incorrect cover icon when device_class is garage
small UI changes
fixed device tracker crash
matisaul
(Matias Saul)
June 12, 2019, 12:37pm
259
Hi @Ionut ,
After this update, my device tracker always show the same coordinates (like 4450 kms from my home) and my home wifi doesn’t shows me at home neither.
I remove and force update mobile app credentials, but nothing changes… I tried with my wife’s phone and mine.
Ionut
(Ionut Cristea)
June 12, 2019, 12:38pm
260
matisaul:
Device tracker is the same old one, it do not use mobile_app component (but it will soon). Please send me current logs so i can investigate. Thank you.
matisaul
(Matias Saul)
June 12, 2019, 1:11pm
261
Don’t ask me why, but now start working again… If I have this problem again I tell you… Thanks!
@Ionut
Thank you for incorporating url in notifications. Much appreciated
Updated today to version 1.3.3.9 on android. Now my tracker status is always away. Checked device tracker in HA and it seems that longitude and latitude values are switched.
