Do we still need to leave device_tracker and see turned on?
You will have to turn on device_tracker and choose mobile_app or see or both
Can you please share the logs so i can investigate? Thank you.
Version 1.3.4.2 is out.
Whatâs new:
- updated google libraries
- NEW: added force_image notification parameter
- Android Wear connection improvements
- small other fixes
Hi⌠Yes, Iâm getting updates, but I donât see my devices location on maps in Ariela
If you are home those devices will not be shown.
Thatâs strange⌠Before switching to mobile app device tracker, I always tracked my devices on map, even if I was at home⌠So, if Iâm in any zone (home, work, etc), my devices will never be shown?
Hello all,
New Ariela version available.
Whatâs new:
- NEW: Android Wear battery sensor
- fixed Ariela crash when adding widgets
- fixed issue where the device tracker wifi canât be set
- fixed incorrect MQTT sensors setup instructions
- removed force android wear credentials option since this is not needed anymore
- fixed TTS sensor loading issue
- fixed cover disabled arrows issue
Please test it and let me know how it goes. Thank you.
Version 1.3.4.4 is out.
Whatâs new:
- show the SSL webview dialog only once
- updated Russian localization
- hide Android Wear battery sensor is no Android Wear device is available
- fixed issue where entity name is not shown
- fixed weather entities status icon loading issue
- fixed HFP / A2DP sensors issue where the location is not send
- fixed crash when trying to edit an entity attributes
@Ionut, there seems to be a really big pause between starting Ariela and it showing the HA page when using the self-signed cert. It just sits on a white page not doing anything obvious, for about 10 seconds, then the page loads and all is good. After the first time it no longer mentions the self-signed cert, but the pause is there every time. Iâll get a log and send it over.
Hello all,
Version 1.3.4.5 is out:
- NEW: GPS accuracy setting (do not send GPS location if accuracy in meters is less then a set value)
- fixed issue when updating mobile_app sensor
- make badges icons smaller
- fixed icon loading issue in sensor lovelace card
- minor UI changes to sensor lovelace card
- change PRO app name from Ariela PRO to Ariela
Please test it and let me know how it works. Thank you.
Version 1.3.4.6 is out.
Whatâs new:
- NEW: support for counter entities
- updated Google libraries
- fixed map zone radius display issue
- fixed issue when entities do not appear on map
- improved HFP / A2DP sensors sending informations
- fixed crash when retrieving device tracking name
- do now show group switch if group name is null or empty string
Hello all,
Version 1.3.4.7 is out.
Whatâs new:
- NEW: added setting to allow Ariela run in background or not
- NEW: support for markdown language in Markdown Lovelace card
- NEW: support for markdown language in notifications
- improved widgets usage
- allow arming / disarming alarms when no code is required
- fixed issue when history graph is not showing for some entities
- moved home wifi networks setting to device tracker entry
- moved auto reconnect setting to server connection entry
Hello all,
Version 1.3.4.8 is out.
Whatâs new:
- NEW: VPN Mode setting (if this mode is enabled, internal IP address is used for connection)
- NEW: entity registry tools
- NEW: Heart Rate MQTT / Mobile_app sensor
- NEW: Heart Rate MQTT / Mobile_app Android Wear Sensor
- fixed issue when markdown card url are not opened
- fixed issue when gauge card name is not showing properly
- fixed issue when Wear battery sensor registered incorrectly
- small UI changes
Thank you.
Hello all,
Ariela version 1.3.4.9 is out.
Whatâs new:
- NEW: add possibility to change application language
- NEW: open stream cameras from push notifications
- fixed 405 error when handling widgets
- check if VPN is currently active when retrieving server URL
- fixed device_tracker updating even if its disabled
- reset step counter sensor value after detecting day change
- fixed camera rendering issue in picture entity Lovelace card
VPN detection with OpenVPN seems to be working well, thanks
Has anyone done some power consumption measurements when location and/or other sensors are active? A few months ago I tested the location sending and decided it was not worth the battery consumption at the time.
It would be interesting to see how much battery is used depending on the settings.
If you use device tracker (using mobile_app) you can even close Ariela (not run in background) and Ariela will have most to nothing battery consumption.
Alright, Iâll give it a try and see how it goes
