Also what is the best settings to have the battery status updated (from phone to HASS), without Ariela app consuming too much battery?
mobile_app its automatically loaded if you have default: set in the configuration.yaml
Just disable device tracker and you should be safe
is that correct or should be
default_config: (this I have)
default_config: its what you should have
allow background running is needed, or better off?
You should have it set to true in order to allow Ariela communicating to HA all the time. Also same for reconnection option.
Ok will do.
Now I have a major problem, since I had many “phone” integration, and was not sure sure which was good, I deleted all of them, went to Ariela app and changed the device name, then restarted HASSIO … hoping that the integration would populate with the new name … but no, no integration now
any clue?
Just go to Ariela -> Settings and click on force mobile app integration in order to have the device re-registered
Hello all,
Version 1.3.7.6 is out.
What’s new:
- NEW: background view support with beautiful parallax animation
- NEW: move view tabs to the bottom
- fixed color issue when dark mode enabled in the notifications area
- fixed issue when loading local images
- updated Russian localization
- updated Google libraries
- smoother loading experience when using WebUi mode
yes that was it, thanks
I installed HAnotify component, but when I trigger no notification is sent
In Ariela settings HANOtify firebase is greyed out, and Push-notification mobile app is ON
You should have the mobile_app notification up and running You do not need HANotify anymore.
Oh ok so better delete the custom component
not on the play store after 20 hours?
Its already there
For some users its possible that Play Store could deliver the update much slower. Just try to refresh / enter app info and the update should appear.
I think there is a little bug with locks.
When they are in open state are showed as blue open lock.
When they are in close state are showed as yellow open lock
In close state should not change color but instead show a blue closed lock
Hi!
First of all thank you for amazing app!)
Buy two one for me and wife
Have you planned to add simple thermostat lovelace card (Lovelace: Simple thermostat card)? This is like normal thermostat, but he main difference is that it replaces the round dial with simple buttons and it presents relevant entity attributes as well as custom sensor values in a simple-to-read table format.
It will be really great)
I added the card to my TODO list so let me see when i can plan it for release.
Btw, thank you very much for the support, i really appreciate it.
Thank you! I will really wait for the support of this component.
Special thanks for Russian localization
