Well this is how it’s intended. The column is for cards only and not for “sub cards” (in this case the horizontal cards). Maybe i will add a new setting that will handle sub cards also.
You’re right, those images are not changing color for now. I will add this fix to my TODO list.
Hi @Ionut,
First of all, thanks for your great work with Ariela.
I use the UI view with lovelace, but I have some problems when I minimize the app and open it again. Sometimes, buttons stop working, or some images dissapear from page… I need to close app and open it again, it’s a little annoying.
Other thing, It’s when I change some image or JS file, there is no way to clean cache, for images and files stored in Web UI, so I need to ERASE all data in the app (incluide connection config, and all setting from Ariela). Is there a way to add a “clean cache” feature?
And finally, on web UI, then you turn the phone, Ariela reload the page… maybe this could be an option, but in my case, I don’t like it so much…
Nice so most things should be fixed, I will test today the latest version and let you know…What about Android Wear, when should we expect some new test versions
Indeed i spend a lot of time fixing / adding new features to Ariela. If you wish to support developing please use the Patreon or buy Ariela PRO so it can be my advantage too
Anyway, GitHub - MCrissDev/Ariela: Ariela has been created. Here you can find english string file (you can use it to create translations for other languages). Also you can use this repository to create / watch issues.
The Iframe thing is not really fixed…the iframes with the pictures dont remember their zoom extent and the Windy one with embeddable weather map which was before okay is now totally borked and the zoom function doesn’t function on the Windy one.
So perhaps it would be best if you revert to old behaviour.
If I use the Web-ui it is good. Gonna use that for the time being. Looking forward to Wear update :).
