Hey guys, do I need a specific option to have playback of last video working? I just have the standard default config from the example (I am using Arlo Q+). I just get a broken video icon when i click the thumbnail. And a “ERROR (MainThread) [custom_components.aarlo.camera] Video not found for None. Is it older than 30 days?” the standard arlo component worked fine and showed last video.
@skynet01 Are you using the custom aarlo glance card? I recommend them - you can get it from the hass-aarlo repository or the newer one here - it plays back recording directly from Arlo rather than via your Home Assistant device. And you can access older recordings.
I’ll set up my box with the standard card and take a look.
Yeah I am using aarlo smart glance card, the weird part is if I click video history icon and select video from the list they play fine, just not when I click the image
Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 33, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 67, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 216, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 115, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/stream/core.py", line 176, in get
return await self.handle(request, stream, sequence)
File "/usr/src/homeassistant/homeassistant/components/stream/hls.py", line 38, in handle
track, utcnow()).encode("utf-8"), headers=headers)
File "/usr/src/homeassistant/homeassistant/components/stream/hls.py", line 98, in render
self.render_preamble(track) +
File "/usr/src/homeassistant/homeassistant/components/stream/hls.py", line 72, in render_preamble
"#EXT-X-TARGETDURATION:{}".format(track.target_duration),
File "/usr/src/homeassistant/homeassistant/components/stream/core.py", line 83, in target_duration
return round(sum(durations) // len(self._segments)) or 1
ZeroDivisionError: integer division or modulo by zero
My aarlo panel config
entity: camera.aarlo_front
image_click: play
show:
- motion
- sound
- snapshot
- captured_today
- image_date
top_date: false
top_status: false
top_title: false
type: 'custom:aarlo-glance'
I’m assuming you have the stream: component enabled. Can I ask what environment you are running home-assistant in?
Somebody else - on the github page - was reporting the exact same issue. I think there is a bug in the stream component, it should handle the division by 0 but I don’t know if that would allow the video to start, it might be masking the real issue.
Do you have aarlo debug turned on? It would be nice to see what type of stream Arlo is giving us.
I am running on Hassio, Raspberry pi 3B+ . I do have stream component turned on. I just realized that “image_click: play” in my config suppose to turn on the live stream, which I believe the author said won’t work in my environment. Removing that part I can now click and see the last recorded video like before. But yes streaming would be nice
(Author here - I need to update that documentation!) Streaming might work in your environment but you have to recompile the ffmpeg binary. The problem is the stream is encrypted, because it’s travelling from Arlo’s servers and not directly from your camera, and ffmpeg wasn’t compiled with encryption for rtsp streams.
A couple of people have managed it, try searching this discussion for instructions.
Sorry for the late answer. It’s working fine now. The camera that is plugged in now shows a plug symbol instead of an empty battery in the arlo glance card. Thanks!
First of all, can I say thanks for creating this and also for supporting it the way you have.
I don’t know if you can help but when I start HA everything works fine but after a couple of hours, I can no longer change any of the arm modes. I get the following error in the log.
2019-07-30 18:17:33 WARNING (ArloBackgroundWorker) [pyaarlo] error in response={‘data’: {‘error’: ‘AUTO-5010’, ‘message’: “Device doesn’t belong to the User”, ‘reason’: “Redacted doesn’t belong to the User / Is not provisioned”}, ‘success’: False}
Does this mean anything to you? As I said, the automations and scripts I use work fine for a few hours after a restart but then stop working.
