Woke up this morning, back to stone age. No lights turn on, floor slowly cooled down.
Check log and found error on all event when trigged. Also not able to communicate to any light-switch or lock, etc.
ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
Restarted Host, and everything start working for app 15-20 minutes, before same error appeared…
What I did yesterday:
- Added couple of new device.
- Heal network
- Update HA Core to 2022.3.2
System worked great from app. 18.00 to 2300 (yesterday)
What I have done today:
- Restart host x10.
- Restore system back to 2022.2.9
- Restart host and core several time.
Z-Wave JS is connected, now 4 dead node (yesterday none). Unable to see what’s node that’s dead because if unknown info. But its seems to me most of my light switch and dimmer is present.(first I react on today, because lights not turn on)
Debug logg from Zwave To MQTT:
2022-03-07T07:10:19.552Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:19.653Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:20.756Z CNTRLR [Node 105] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:20.756 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:20.757Z CNTRLR » [Node 106] requesting node neighbors...
2022-03-07T07:10:20.759Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:20.860Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:21.962Z CNTRLR [Node 106] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:21.962 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:21.962Z CNTRLR » [Node 109] requesting node neighbors...
2022-03-07T07:10:21.967Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:22.069Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:23.172Z CNTRLR [Node 109] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:23.173 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:23.173Z CNTRLR » [Node 111] requesting node neighbors...
2022-03-07T07:10:23.176Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:23.277Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:24.380Z CNTRLR [Node 111] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:24.380 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:24.381Z CNTRLR » [Node 113] requesting node neighbors...
2022-03-07T07:10:24.384Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:24.485Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:25.588Z CNTRLR [Node 113] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:25.589 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:25.589Z CNTRLR » [Node 114] requesting node neighbors...
2022-03-07T07:10:25.592Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:25.693Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:26.796Z CNTRLR [Node 114] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:26.797 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:26.797Z CNTRLR » [Node 115] requesting node neighbors...
2022-03-07T07:10:26.801Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:26.902Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:28.004Z CNTRLR [Node 115] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:28.005 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:28.005Z CNTRLR » [Node 117] requesting node neighbors...
2022-03-07T07:10:28.008Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:28.110Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:29.211Z CNTRLR [Node 117] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:29.212 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:29.212Z CNTRLR » [Node 118] requesting node neighbors...
2022-03-07T07:10:29.214Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:29.315Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:30.417Z CNTRLR [Node 118] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:30.418 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:30.418Z CNTRLR » [Node 119] requesting node neighbors...
2022-03-07T07:10:30.420Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:30.521Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:31.624Z CNTRLR [Node 119] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:31.624 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:31.625Z CNTRLR » [Node 121] requesting node neighbors...
2022-03-07T07:10:31.627Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:31.728Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:32.830Z CNTRLR [Node 121] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:32.832 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:32.832Z CNTRLR » [Node 122] requesting node neighbors...
2022-03-07T07:10:32.835Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:32.936Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:34.040Z CNTRLR [Node 122] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:34.040 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:34.040Z CNTRLR » [Node 123] requesting node neighbors...
2022-03-07T07:10:34.043Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:34.144Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:35.246Z CNTRLR [Node 123] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:35.247 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:35.247Z CNTRLR » [Node 124] requesting node neighbors...
2022-03-07T07:10:35.249Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:35.351Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:36.452Z CNTRLR [Node 124] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:36.452 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:36.453Z CNTRLR » [Node 126] requesting node neighbors...
2022-03-07T07:10:36.458Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:36.560Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:37.663Z CNTRLR [Node 126] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:37.663 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:37.664Z CNTRLR » [Node 127] requesting node neighbors...
2022-03-07T07:10:37.666Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:37.767Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:38.869Z CNTRLR [Node 127] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:38.870 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:38.870Z CNTRLR » [Node 133] requesting node neighbors...
2022-03-07T07:10:38.873Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:38.974Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:40.076Z CNTRLR [Node 133] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:40.076 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:40.076Z CNTRLR » [Node 134] requesting node neighbors...
2022-03-07T07:10:40.079Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:40.180Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:41.282Z CNTRLR [Node 134] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:41.282 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:41.283Z CNTRLR » [Node 135] requesting node neighbors...
2022-03-07T07:10:41.285Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:41.386Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:42.488Z CNTRLR [Node 135] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:42.488 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:42.488Z CNTRLR » [Node 136] requesting node neighbors...
2022-03-07T07:10:42.491Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:42.592Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:43.694Z CNTRLR [Node 136] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:43.695 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:43.695Z CNTRLR » [Node 137] requesting node neighbors...
2022-03-07T07:10:43.697Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:43.797Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:44.900Z CNTRLR [Node 137] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:44.900 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:44.901Z CNTRLR » [Node 138] requesting node neighbors...
2022-03-07T07:10:44.903Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:45.003Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:46.106Z CNTRLR [Node 138] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:46.107 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:46.107Z CNTRLR » [Node 139] requesting node neighbors...
2022-03-07T07:10:46.113Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:46.213Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:47.315Z CNTRLR [Node 139] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:47.316 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:47.316Z CNTRLR » [Node 140] requesting node neighbors...
2022-03-07T07:10:47.318Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:47.422Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:48.524Z CNTRLR [Node 140] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:48.525 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:48.525Z CNTRLR » [Node 141] requesting node neighbors...
2022-03-07T07:10:48.528Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:48.629Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:49.731Z CNTRLR [Node 141] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:49.731 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:49.734Z CNTRLR » [Node 142] requesting node neighbors...
2022-03-07T07:10:49.737Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:49.837Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:50.939Z CNTRLR [Node 142] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:50.940 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:50.940Z CNTRLR » [Node 143] requesting node neighbors...
2022-03-07T07:10:50.943Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:51.044Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:52.146Z CNTRLR [Node 143] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:52.146 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:52.149Z CNTRLR » [Node 144] requesting node neighbors...
2022-03-07T07:10:52.153Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:52.254Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:53.356Z CNTRLR [Node 144] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:53.357 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:53.357Z CNTRLR » [Node 145] requesting node neighbors...
2022-03-07T07:10:53.359Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:53.461Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:54.562Z CNTRLR [Node 145] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:54.563 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:54.563Z CNTRLR » [Node 147] requesting node neighbors...
2022-03-07T07:10:54.566Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:54.667Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:55.769Z CNTRLR [Node 147] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:55.770 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:55.770Z CNTRLR » [Node 148] requesting node neighbors...
2022-03-07T07:10:55.772Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:55.873Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:56.975Z CNTRLR [Node 148] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:56.976 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:56.976Z CNTRLR » [Node 149] requesting node neighbors...
2022-03-07T07:10:56.978Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:57.079Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:10:58.183Z CNTRLR [Node 149] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:58.184 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:58.184Z CNTRLR » [Node 150] requesting node neighbors...
2022-03-07T07:10:58.186Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:58.287Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07 08:10:58.589 INFO APP: GET /health/zwave 200 0.551 ms - 1873
2022-03-07T07:10:59.388Z CNTRLR [Node 150] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:10:59.388 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:10:59.388Z CNTRLR » [Node 153] requesting node neighbors...
2022-03-07T07:10:59.391Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:10:59.492Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:00.593Z CNTRLR [Node 153] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:00.593 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:00.594Z CNTRLR » [Node 154] requesting node neighbors...
2022-03-07T07:11:00.596Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:00.697Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:01.798Z CNTRLR [Node 154] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:01.799 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:01.799Z CNTRLR » [Node 155] requesting node neighbors...
2022-03-07T07:11:01.801Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:01.902Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:03.004Z CNTRLR [Node 155] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:03.004 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:03.005Z CNTRLR » [Node 156] requesting node neighbors...
2022-03-07T07:11:03.007Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:03.108Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:04.209Z CNTRLR [Node 156] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:04.209 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:04.209Z CNTRLR » [Node 157] requesting node neighbors...
2022-03-07T07:11:04.213Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:04.314Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:05.416Z CNTRLR [Node 157] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:05.417 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:05.417Z CNTRLR » [Node 158] requesting node neighbors...
2022-03-07T07:11:05.419Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:05.520Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:06.624Z CNTRLR [Node 158] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:06.624 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:06.624Z CNTRLR » [Node 159] requesting node neighbors...
2022-03-07T07:11:06.627Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:06.728Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:07.828Z CNTRLR [Node 159] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:07.829 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:07.829Z CNTRLR » [Node 160] requesting node neighbors...
2022-03-07T07:11:07.831Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:07.931Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:09.033Z CNTRLR [Node 160] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:09.033 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:09.033Z CNTRLR » [Node 161] requesting node neighbors...
2022-03-07T07:11:09.036Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:09.136Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:10.236Z CNTRLR [Node 161] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:10.237 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:10.237Z CNTRLR » [Node 162] requesting node neighbors...
2022-03-07T07:11:10.239Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:10.340Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:11.442Z CNTRLR [Node 162] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:11.442 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:11.442Z CNTRLR » [Node 167] requesting node neighbors...
2022-03-07T07:11:11.445Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:11.545Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:12.647Z CNTRLR [Node 167] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:12.647 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:12.648Z CNTRLR » [Node 168] requesting node neighbors...
2022-03-07T07:11:12.650Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:12.750Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:13.852Z CNTRLR [Node 168] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:13.853 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:13.854Z CNTRLR » [Node 169] requesting node neighbors...
2022-03-07T07:11:13.857Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:13.957Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:15.058Z CNTRLR [Node 169] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:15.058 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:15.058Z CNTRLR » [Node 170] requesting node neighbors...
2022-03-07T07:11:15.066Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:15.166Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:16.267Z CNTRLR [Node 170] requesting the node neighbors failed: Failed to send the message af
2022-03-07 08:11:16.268 ERROR ZWAVE: Failed to send the message after 3 attempts (ZW0202)
2022-03-07T07:11:16.268Z CNTRLR Turning RF on...
2022-03-07T07:11:16.270Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:11:16.371Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:11:17.473Z CNTRLR Error turning RF on: Failed to send the message after 3 attempts (ZW0202)
2022-03-07 08:11:17.474 INFO ZWAVE: Success zwave api call refreshNeighbors {
'1': [ [length]: 0 ],
'6': [ [length]: 0 ],
'7': [ [length]: 0 ],
'8': [ [length]: 0 ],
'9': [ [length]: 0 ],
'10': [ [length]: 0 ],
'11': [ [length]: 0 ],
'12': [ [length]: 0 ],
'13': [ [length]: 0 ],
'14': [ [length]: 0 ],
'15': [ [length]: 0 ],
'18': [ [length]: 0 ],
'19': [ [length]: 0 ],
'20': [ [length]: 0 ],
'22': [ [length]: 0 ],
'23': [ [length]: 0 ],
'24': [ [length]: 0 ],
'25': [ [length]: 0 ],
'26': [ [length]: 0 ],
'27': [ [length]: 0 ],
'28': [ [length]: 0 ],
'29': [ [length]: 0 ],
'30': [ [length]: 0 ],
'31': [ [length]: 0 ],
'32': [ [length]: 0 ],
'33': [ [length]: 0 ],
'34': [ [length]: 0 ],
'35': [ [length]: 0 ],
'36': [ [length]: 0 ],
'37': [ [length]: 0 ],
'38': [ [length]: 0 ],
'41': [ [length]: 0 ],
'42': [ [length]: 0 ],
'43': [ [length]: 0 ],
'44': [ [length]: 0 ],
'45': [ [length]: 0 ],
'46': [ [length]: 0 ],
'47': [ [length]: 0 ],
'49': [ [length]: 0 ],
'50': [ [length]: 0 ],
'51': [ [length]: 0 ],
'52': [ [length]: 0 ],
'57': [ [length]: 0 ],
'60': [ [length]: 0 ],
'62': [ [length]: 0 ],
'64': [ [length]: 0 ],
'68': [ [length]: 0 ],
'69': [ [length]: 0 ],
'70': [ [length]: 0 ],
'72': [ [length]: 0 ],
'73': [ [length]: 0 ],
'74': [ [length]: 0 ],
'75': [ [length]: 0 ],
'76': [ [length]: 0 ],
'77': [ [length]: 0 ],
'78': [ [length]: 0 ],
'79': [ [length]: 0 ],
'81': [ [length]: 0 ],
'82': [ [length]: 0 ],
'83': [ [length]: 0 ],
'84': [ [length]: 0 ],
'85': [ [length]: 0 ],
'86': [ [length]: 0 ],
'87': [ [length]: 0 ],
'88': [ [length]: 0 ],
'89': [ [length]: 0 ],
'90': [ [length]: 0 ],
'92': [ [length]: 0 ],
'93': [ [length]: 0 ],
'94': [ [length]: 0 ],
'95': [ [length]: 0 ],
'97': [ [length]: 0 ],
'99': [ [length]: 0 ],
'100': [ [length]: 0 ],
'101': [ [length]: 0 ],
'102': [ [length]: 0 ],
'103': [ [length]: 0 ],
'105': [ [length]: 0 ],
'106': [ [length]: 0 ],
'109': [ [length]: 0 ],
'111': [ [length]: 0 ],
'113': [ [length]: 0 ],
'114': [ [length]: 0 ],
'115': [ [length]: 0 ],
'117': [ [length]: 0 ],
'118': [ [length]: 0 ],
'119': [ [length]: 0 ],
'121': [ [length]: 0 ],
'122': [ [length]: 0 ],
'123': [ [length]: 0 ],
'124': [ [length]: 0 ],
'126': [ [length]: 0 ],
'127': [ [length]: 0 ],
'133': [ [length]: 0 ],
'134': [ [length]: 0 ],
'135': [ [length]: 0 ],
'136': [ [length]: 0 ],
'137': [ [length]: 0 ],
'138': [ [length]: 0 ],
'139': [ [length]: 0 ],
'140': [ [length]: 0 ],
'141': [ [length]: 0 ],
'142': [ [length]: 0 ],
'143': [ [length]: 0 ],
'144': [ [length]: 0 ],
'145': [ [length]: 0 ],
'147': [ [length]: 0 ],
'148': [ [length]: 0 ],
'149': [ [length]: 0 ],
'150': [ [length]: 0 ],
'153': [ [length]: 0 ],
'154': [ [length]: 0 ],
'155': [ [length]: 0 ],
'156': [ [length]: 0 ],
'157': [ [length]: 0 ],
'158': [ [length]: 0 ],
'159': [ [length]: 0 ],
'160': [ [length]: 0 ],
'161': [ [length]: 0 ],
'162': [ [length]: 0 ],
'167': [ [length]: 0 ],
'168': [ [length]: 0 ],
'169': [ [length]: 0 ],
'170': [ [length]: 0 ]
2022-03-07 08:12:58.593 INFO APP: GET /health/zwave 200 0.635 ms - 1873
2022-03-07 08:14:58.598 INFO APP: GET /health/zwave 200 0.564 ms - 1873
2022-03-07 08:16:58.603 INFO APP: GET /health/zwave 200 0.472 ms - 1873
2022-03-07T07:18:21.939Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:18:22.041Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:18:23.142Z CNTRLR [Node 095] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2022-03-07T07:18:23.643Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:18:23.745Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07T07:18:24.846Z CNTRLR [Node 095] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
2022-03-07T07:18:25.348Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2022-03-07T07:18:25.451Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2022-03-07 08:18:26.554 ERROR ZWAVE-SERVER: Failed to send the message after 3 attempts (ZW0202)
ZWaveError: Failed to send the message after 3 attempts (ZW0202)
at Driver.sendMessage (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:3390:23)
at Driver.sendCommand (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:3567:28)
at Driver.trySendCommandSupervised (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:3662:15)
at MultilevelSwitchCCAPI.set (/opt/node_modules/zwave-js/src/lib/commandclass/MultilevelSwitchCC.ts:173:47)
at Proxy.MultilevelSwitchCCAPI.<computed> (/opt/node_modules/zwave-js/src/lib/commandclass/MultilevelSwitchCC.ts:323:33)
at ZWaveNode.setValue (/opt/node_modules/zwave-js/src/lib/node/Node.ts:867:14)
at Function.handle (/opt/node_modules/@zwave-js/server/dist/lib/node/message_handler.js:23:44)
at Object.node (/opt/node_modules/@zwave-js/server/dist/lib/server.js:39:91)
at Client.receiveMessage (/opt/node_modules/@zwave-js/server/dist/lib/server.js:95:99)
at WebSocket.<anonymous> (/opt/node_modules/@zwave-js/server/dist/lib/server.js:48:45)
