I have been using the Alexa Media component as a TTS delivery mechanism
and the Alexa App routines function, to ask Alexa about the state of various entities
Edit updated program to render Grammatical sentences (unlike me
EDIT replaced this program with
For example, Alexa is the patio door open.
I have been using individual input boolean to trigger these responses. This has proved cumbersome. I finally hit upon the idea of using a dummy light bulb. This allows the Alexa app to use the brightness levels and gives a 100 triggers with one entity. To create a dummy bulb in HA you need to create a blank light template
lights:
alexa_virtual:
friendly_name: "Alexa Dummy Light"
turn_on:
turn_off:
set_level:
This bulb can then be exposed to Alexa via Alexa Cloud or emulated Hue.
I have written the following Appdeamon script to respond to the trigger event from the dummy bulb
# This program responds via ALexa TTS to trigger events generated by the Alexa App routines function.
# It responds with generated spoken description of state of the triggered entity.
# It requires a template light switch is created in HA
# - platform: template
# lights:
# alexa_virtual:
# friendly_name: "Alexa Dummy Light"
# turn_on:
# turn_off:
# set_level:
# This dummy light switch brightness level is used to generate 100 unique triggers.
# Each trigger is matched to a list of entities to create the following type of Alexa conversations
# "Alexa is the patio door open" (created in the Alexa app Routine)
# "Please wait while I check" (created in the Alexa app Routine)
# Set dummy Light bulb brightness to 1% (created in the Alexa app Routine)
# "The patio door is closed" (created by this app)
# Program requires the following parameters
# AlexaReport:
# module: AlexaReport
# class: Alexareport
# trigger: < Enity name of virtual bulb>
# device: < Entity name of Alexa media device
# ent:
# - < Entity of sensor to obtain state >
# - < Next entity >
# - < and so on >
# 1st entiy is triggered on brightness of 1% second on 2% etc
# Version 1.1 Added better English
import appdaemon.plugins.hass.hassapi as hass
class Alexareport(hass.Hass):
def initialize(self):
# get vars
self.trigger=self.args["trigger"]
self.alexa = self.args["device"]
# check if dummy bulb triggered
self.listen_state(self.alexareport,self.trigger,new="on")
def alexareport (self, entity, attribute, old, new, kwargs):
self.log(("{} triggered").format(self.trigger))
#setup list for entities
ent = []
# dim value of dummy light
value = self.get_state(self.trigger, attribute = "brightness")
# Convert brightness 0 to 255 as persentage then -1 as python list start 0 not 1
psent = int(round(value/255*100)) -1
#get entity id from args and add to ent list
for entity in self.args["ent"]:
ent.append(entity)
# Test if dim value matches listnumber in array -1 as array start at 0
if psent > (len(ent) -1) :
# Dim value does not match entry in list error and turn off dummy light
self.log("Message {} value out of range ignored".format(psent+1))
self.turn_off(self.trigger)
else:
# get entity details
obj = ent[psent]
fname = self.friendly_name(obj)
state = self.get_state(obj)
uom = self.get_state(obj, attribute = "unit_of_measurement")
dc = self.get_state(obj, attribute = "device_class")
# if values are null set as blank to stop errors when concatenating strings
if uom == None :
uom = ""
if dc == None :
dc = ""
# check if entity is plural or singular (is or are)
if fname.endswith("s" ):
sorp = " are "
else :
sorp = " is "
#construct alexa reply
mess = "The " + fname + sorp + dc + " " + state + " " + uom
# Check entity type to change on/off to appropriate values. Add as required
mess = mess.replace("opening on","open")
mess = mess.replace("opening off","closed")
mess = mess.replace("moisture on","wet")
mess = mess.replace("moisture off","dry")
mess = mess.replace("motion on","triggered")
mess = mess.replace("motion off","off")
mess = mess.replace("temperature","")
mess = mess.replace("humidity", "")
mess = mess.replace("pressure","")
# replace symbols and SI with words. Add as required
mess = mess.replace(" "," ")
mess = mess.replace("°C","Centagrade")
mess = mess.replace("km","Kilometres")
mess = mess.replace("GiB","Gigabytes")
mess = mess.replace("MiB","Megabytes")
mess = mess.replace("lx","Lux")
mess = mess.replace("%","Percent")
mess = mess.replace("mbar","Milibar")
mess = mess.replace("hPa","Hectopascal")
mess = mess.replace("lm","Lumin")
self.log("Message {} is {}".format(psent+1,mess))
#send message to alexa and turn off dummy bulb
self.call_service('media_player/alexa_tts', entity_id=self.alexa, message=mess)
Documentation is in the program, but the real trick is using the Alexa App Routines to trigger the dummy light bulb, you can use any scripts, node-red or even the template bulb to react to the trigger event.
So in the Alexa App, you can create a new routine
“Alexa is the patio door open” (created in the Alexa app)
“Please wait while I check” (created in the Alexa app)
Set dummy Light bulb brightness to 1% (created in the Alexa app)
“The patio door is closed” (response triggered by brightness level)
Hope this is useful
