EDIT please note I have completely re-written the program and instructions following @ReneTode advice
EDIT1 Have updated script again. Warning options and syntax has changed again (sorry)
EDIT version 1.0 rewritten with regex to simplify the code also added new options. can now compare state values = >< + and -. See the code for new examples
EDIT: Version 1.1 correct parsing errors
EDIT: Version 2.0 now has a global search and replace . Translate option
EDIT Version 2.1 minor update
I have written a parameter driven Appdaemon script to extract multiple state attributes from multiple Entity Id’s and parse them into readable text ready to be sent to Alexa ( no reason why this won’t work for Google or any other TTS provider)
The script is triggered by a dummy bulb.
lights:
alexa_virtual:
friendly_name: "Alexa Dummy Light"
turn_on:
turn_off:
set_level:
This can be presented to Alexa (google ?) via HA Cloud, emulated hue, etc. The brightness levels (1-100) are then be used by my script to trigger the appropriate response
The bulb can be triggered by Alexa Routines or locally by motion sensors, time of day, NFC tags, etc.
The script requires the following parameters
SpeechParser:
module: SpeechParser
class: Speechparser
trigger: "light.alexa_virtual"
DEBUG: 1
entities:
1: binary_sensor.door_window_sensor_158d00019e18bf #front door
2: sensor.temperature_158d0001b9205b #living room temp
3: group.gupstairs # upstairs light
4: binary_sensor.door_window_sensor_158d00019e1738 # patio door
5: weather.dark_sky # weather forcast
1: "The {$01=FN} {$01=ST|on|is currently open}{$01=ST|off| is currently closed}"
2: "The {$02=FN} is currently {$02=ST} centigrade"
3: "The {$03=FN} are currently {$03=ST}"
4: "The {$04=FN} {$04=ST|on|is currently open}{$04=ST|off|is currently closed}"
5: "{g} on {d} the {D} of {m} {y} at {t}, The current outside temperture is {$05=TP} degrees, winspeed is {$05=wind_speed} miles per hour"
6: "{$02>ST|10|danger, temperatures high}"
7: "{$02>ST|$05=TP|Inside temperature is higher than the outside}"
8: "{$02<ST|20|Inside temperature, is lower than 20 degress}"
translate:
1: morning|morgan
The messages in message list will be triggered if the brightness level of the dummy bulb matches the parameter number
Information inside {} is used to extract information from HA text outside of the brackets is unaltered.
The entities list is indexed from 1 to 99 and is used by the ${state} command to extract data.
Use the # to add comments to each entity to help identify objects.
The following commands can be used:
d = current day that can be spoken in words {31st}
D = current day in name {Monday}
m = current month in words {April}
y = current year {2018}
t = current time split so correctly spoken { 11 24 PM}
g = Greeting based on current time [morning: afternoon: evening]
The $ command has additional parameters that are order and position dependent
{$} State
$[00-99][=|>|<][attrib]|[test value|replace value [$[00-99]= attrib] [+] [-] [1] [2] ]
“$” state command
“00-99” number matches entities from apps.yaml
“=” show value to replace if value to test = value to replace
“>” show value to replace if value to test > value to replace
“<” show value if replace if value to test < value to replace
“attrib” state name in HA can be shortened see shortcuts in the code
“|” separator
“test value” alpha or if using < > must be numeric
“|” separator
“replace value” alpha or numeric. can be another state command
“[1]” will display test value.
“[2]” will display replace value
“[+]” sum the values
“[-]” will subtract always display a positive number
Examples
The {$01=friendly_name} is {$01=state} degrees
This will parse to "The living room temperature is 17 point 2 degrees"
This can be further shorted by using the following shortcuts
ST = state
FN = friendly_name
TP = temperature
BR = brightness
"The {$01=FN} is {$01=ST} degrees"
State values can be changed
“The {$01=FN} is {$01=ST|on|open}{$01=ST|off|closed}”
This will parse to "The Patio door is closed" {off being replaced by closed}
“{g} {D} the {d} of {m} {y} at {t} the current outside temperature is {$05=TP} degrees, winspeed is {$05=wind_speed} miles per hour”
This will parse to “Good morning on Thursday the Thirty first of October 2018 at 11 52 AM the current outside temperature is 3 point 2 degrees, wind speed is 1 point 4 miles per hour”
“{$05>ST|15|temperature too high}”
This will parse to “Temperature too high”; if temp is greater than 15" or if temp is <= 15
“{$05<ST|10|temperature too low}”
This will parse to “Temperature too low” if temp is less than 10 “” if temp is <= 10
This will parse to Inside temperature is higher than the outside if $02 > (inside temp) $05 (outside temp)
“{$02>ST|$05=TP|Temperature is [1] degrees, [-] degrees higher than the outside temperature of [2] degrees}”
Temperature is 19.5 degrees, 5.5 degrees higher than the outside temperature of 10 degrees
There is limited error checking within the program. If any errors occur or the program does not work as expected. Set DEBUG: 1 . This will generate additional debug messages should highlight where the parsing errors occur.
I use the following for Alexa TTS
Simply change these highlighted lines in the script to redirect to your TTS device
# Speech Parser
# Ver 1.0
# Ver 1.1 Update Parse for removing dot from float numbers ensure did not replace full stops
# ver 1.2 remove : from final parse
# ver 2.0 added translate option
# ver 2.1 updated with ;atest vesion of alexa media player
# This program extracts information from entities and converts them into a readable format
# for devices such as Alexa or google assistant to read.
# The program is triggered by a dummy bulb which can be then be presented to Alexa or Google.
# Depending on the brightness level { 1 to 100} triggered this program will parse a command line
# to extract the required information.
#SpeechParser:
# module: SpeechParser
# class: Speechparser
# trigger: "light.alexa_virtual"
# DEBUG: 1
# entities:
# 1:binary_sensor.door_window_sensor_158d00019e18bf # front door sensor
# 2: sensor.temperature_158d0001b9205b # living room thermostat
# 3: group.gupstairs # upstairs lights
# 4: binary_sensor.door_window_sensor_158d00019e1738 # patio door sensor
# 5: weather.dark_sky # weather
# messages:
# 1: "The {$01=FN} is {$01=ST|off|closed}{$01=ST|on|open}""
# 2: "The {$02=FN} is currently {$02=ST} centigrade"
# 3: "The {$03=FN} are currently {$03=ST}"
# 4: "The {$04=FN}{$04=ST|on|are open,please close now"}{$04=ST|off|closed}"
# 5: >
# {g} on {d} the {D} of {m} {y} at {t} the current outside temperature is {$05=TP}
# degrees winspeed is {$05=wind_speed} miles per hour
# 6: "{$02>state|18|temperature too high}{$02<state|19|temperature too low}
# translate:
# 1: morning|morgan
# Each parameter of the message list matches the brightness level of the dummy bulb so 1st parameter is 1% and so on
# Information inside {} is used to extract information from HA text outside of the brackets is unaltered.
# use yaml > to break down long message lines
# The entities list is indexed from 1 to 99 and is used by the ${state} command to extract data.
# Use the # to add comments to each entity to help identify objects.
# The following commands can be used :
# d = current day in spoken format {31st}
# D = current day in name {Monday}
# m = current month in words {April}
# y = current year {2018}
# t = current time (12h) split so correctly spoken { 11 24 PM}
# g = Greeting based on current time [morning:afternoon:evening]
# The $ command has additional parameters that are order dependent
# {$} State
# $[00-99][=|>|<][attrib]|[test value|replace value [$[00-99]= attrib] [+] [-] [1] [2] ]
# $ state command
# 00-99 number matches entities from apps.yaml
# = show value to replace if value to test = value to replace
# > show value to replace if value to test > value to replace
# < show value if replace if value to test < value to replace
# attrib state name in HA can be shorten see shortcuts in code
# | seperator
# test value alpha or if using < > must be numeric
# | seperator
# replace value alpha or numeric. can be another state command [1] will display
# test value. [2] will diplay replace value [+] sum the values
# [-] will subtract always display positive number
# The translate list (this is optional) is global search and replace .
# It will replace any text in the final parse it has the following format
# 1:source|replace
# 2:source|replace
# any text before the | will be replaced with text after the | .
# Examples
# "The {$01=friendly_name} is {$01=state} degrees"
# This will parse to "The living room temperature is 17 point 2 degrees"
# This can be further shorted by using the following shortcuts
# ST = state
# FN = friendly_name
# TP = temperature
# BR = brightness
# "The {$01=FN} is {$01=ST} degrees"
# State values can be changed
# "The {$01=FN} is {$01=ST|on|open}{$01=ST|off|closed}
# This will parse to "The Patio door is closed" {off being replaced by closed}
# "Good {g} {D} the {d} of {m} {y} at {t} the current outside temperature is {$05=TP} degrees, winspeed is {$05=wind_speed} miles per hour"
# This will parse to "Good morning on Thursday the Thirty first of October 2018 at 11 52 AM the current outside temperature is 3 point 2 degrees, wind speed is 1 point 4 miles per # hour "
# "{$05>ST|15|temperature too high}"
# This will parse to "Temperature too high" if temp is greater than 15 or "” if temp is <= 15
# "{$05<ST|10|temperature too low, current temperature is [1] degrees }"
# This will parse to "Temperature too low, current temperature is 6.5 degress"
# if temp is less than 10 or "” if temp is >= 10
# "{$02>ST|$05=TP|Temperature is [1] degrees, [-] degrees higher than the outside temperature of [2] degrees}"
# Temperature is 19.5 degrees, 5.5 degrees higher than the outside temperature of 10 degrees
# There is limited error checking. So if there are any errors or the program does not work as expected.
# Set DEBUG: 1 . This should hightlight where the parsing errors occur. Normally misplaced brackets
# or commands in the wrong order
import appdaemon.plugins.hass.hassapi as hass
class Speechparser(hass.Hass):
def initialize(self):
self.trigger=self.args["trigger"]
self.listen_state(self.speechparser,self.trigger,new="on")
def debug(self, text):
if self.args["DEBUG"] == 1:
self.log(text)
def remove_dot(self, text):
import re
p = re.findall("(\d+.\d)", text)
for i in p :
t = i.replace("."," point ")
text = text.replace(i,t)
return text
def speechparser (self, entity, attribute, old, new, kwargs):
import subprocess
import re
self.log("{} triggered".format(self.trigger))
# change these lines for your TTS system. #
# This uses last_called in the alexa media player via a template sensor # #
# if only using 1 device change TTS_Voice = entity_id of alexa to respond #
self.call_service("alexa_media/update_last_called") #
TTS_voice = self.get_state("sensor.last_alexa") #
self.debug("{} is the talking echo".format(TTS_voice))
# setup vars
sub_cmd = {"d":"","D":"","m":"","y":"","t":"","g":""}
num2words = {1:'1st',2:'2nd',3:'3rd',4:'4th',5:'5th',6:'6th',7:'7th',8:'8th',9:'9th',10:'10th',\
11:'11th',12:'12th',13:'13th',14:'14th',15:'15th',16:'16th',17:'17th',18:'18th',19:'19th',\
20:'20th',21:'21st',22:'22nd',23:'23rd',24:'24th',25:'25th',26:'26th',27:'27th',28:'28th',\
29:'29th',30:'30th',31:'31st'}
# load sub_cmd with current date time values
now = self.datetime()
yr = now.strftime("%Y")
cen,dec = divmod(int(yr),100)
dayn = (now.strftime("%d"))
sub_cmd["d"] = now.strftime("%A")
sub_cmd["D"] = num2words[int(dayn)]
sub_cmd["m"] = now.strftime("%B")
mn = now.strftime("%M")
hour = now.strftime("%I")
am_pm = now.strftime("%p")
sub_cmd["y"] = str(cen) + str(dec)
sub_cmd["t"] = hour + " " + mn + " " + am_pm
hr = int(hour)
if am_pm == "AM" :
greeting = "morning"
if am_pm == "PM" and hr >= 5 :
greeting = "evening"
else :
greeting = "afternoon"
sub_cmd["g"] = greeting
self.debug("{}".format(sub_cmd))
# get dummy light brightness
v = self.get_state(self.trigger, attribute = "brightness")
# error checking
if v == None :
self.debug("Invalid trigger value {}".format(v))
self.turn_off(self.trigger)
return
# convert brightness 0-255 to %
value = round((v/255*100))
self.debug("Trigger value= {}".format(value))
# load params from apps.yaml
try :
ent = self.args["entities"]
except:
self.debug("No entities options")
ent = ""
try :
mess = self.args["messages"]
except:
self.debug("No message options")
return
try :
tran = self.args["translate"]
except:
self.debug("No translate options")
tran = ""
self.debug("{} of Entities {}".format(len(ent),ent))
self.debug(" {} of Messages {}".format(len(mess),mess))
self.debug(" {} of Translates {}".format(len(tran),tran))
self.debug("Trigger value (%) {} bulb brightness {}".format(value,v))
# error checking
if value > len(mess) or value == 0 or value > 99 :
self.debug("Invalid trigger value {}".format(value))
return
# get message line
parse = mess[value]
# error checking
if parse.count("{") != parse.count("}"):
self.debug("Mismatch of {}")
return
# error checking
if parse.count("[") != parse.count("]"):
self.debug("Mismatch of []")
return
# shortcuts add as required #
parse = parse.replace("FN","friendly_name").replace("TP","temperature")
parse = parse.replace("BR","brightness").replace("ST","state")
self.debug("parse data = {}".format(parse))
# extract three types of message commands simple {.} short {......}
# and extended {......|*|*} via regex
simple = re.findall("({[a-zA-Z]})",parse)
short = re.findall("({.[0-9][0-9].\w+})",parse)
extend = re.findall("({.[0-9=><\w]+\|.+?\|.+?})",parse)
self.debug("simple {}".format(simple))
self.debug("short {}".format(short))
self.debug("extend {}".format(extend))
# loop to extract {.} commands
for i in simple :
scmd = i[1]
sval = sub_cmd[scmd]
parse = parse.replace(i,sval)
self.debug("simple parse= {}".format(parse))
# loop to extract short commands {......}
for i in short :
# regex to split command
scmd = re.findall("{(\$)([0-9][0-9])(.)(\w+)}",i)
self.debug("scmd = {}".format(scmd))
ind = int(scmd[0][1])
st = scmd[0][3]
self.debug("ind {} state {}".format(ind,st))
# get state value from HA
sval = str((self.get_state(ent[ind], attribute = st)))
sval = self.remove_dot(sval)
self.debug("short parse= {}".format(parse))
# loop to extract extended commands {......|*|*}
for i in extend :
scmd = re.findall("{(\$)([0-9][0-9])(.)(\w+)\|(.+)\|(.+)}",i)
op = scmd[0][2]
st = scmd[0][3]
s1 = scmd[0][4]
s2 = scmd[0][5]
# check if extended value is state
if s1[0] == "$" :
ind= int(s1[1:3])
st = s1[4:]
self.debug("ind1 {} state {}".format(ind,st))
cval = str(self.get_state(ent[ind], attribute =st))
else:
cval = s1
# replace [] values
s2 = s2.replace("[1]",sval)
s2 = s2.replace("[2]",cval)
# stop TTS saying "dot"
s2 = self.remove_dot(s2)
self.debug("ext output parse= {}".format(s2))
# test operators
self.debug("input value = {} replace Value = {}".format(s1,s2))
self.debug("operator is {}".format(op))
if op == "=" :
if sval == cval :
sval = s2
else :
sval = ""
if op == "<" or op == ">":
posv =round(abs(float(sval) - float(cval)),2)
posv = str(posv)
val = s1 + s2
val = str(val)
s2 = s2.replace("[-]",posv)
s2 = s2.replace("[+]",val)
if float(sval) < float(cval) :
sval = s2
elif float(sval) > float(cval) :
sval = s2
else :
sval = ""
# update parse
self.debug("extended parse= {}".format(parse))
# this is the parsed message ready for reading.remove white spaces and : #
parse = " ".join(parse.split())
parse = parse.replace(":","")
# add any translations
for i in tran :
self.debug("translate {}".format(tran[i]))
scmd = re.findall("[a-zA-Z ,]*",tran[i])
self.debug("translate source {} replace with {}".format(scmd[0],scmd[2]))
parse = parse.replace(scmd[0],scmd[2])
self.debug("Message {} for {} is {}".format(value,TTS_voice,parse))
# this is the code for sending messagae via alexa_media notify #
# replace with notify or whenever command used #
self.call_service("notify/alexa_media",data={"type":"tts"},message=parse,target=TTS_voice)
# turn off trigger bulb
