Assistance with state change in automation
Hey, i think this might be simple but I cant get my head around it.
I have a device that when it reloads the integration, it renders a sensor’s state ‘unavailable’ then reports it back to its current state.
I am able to set my automation trigger to be only if the sensor changes from ‘0’ to ‘200’ but I want to put a condition, not to run if the sensor changes from ‘unavailable’ to ‘200’
I have also create a status helper so that the status only changes if the numbers change eg 0 > 200 = Refilled, 200 > 0 = Empty…maybe i should be using the status helper instead of the state?
Reason why I feel like I need to use the state instead of status, is so when I manually trigger the outlet on my external device, that it still can act as a trigger, just trying to prevent the false positives on the reload
evidence of the sensor change
The State trigger is very literal. If you set it with to: 200 and from: 0 it will only trigger when the value changes directly from “0” to “200” without any intermediary steps… a change from “unavailable” to “200” will not trigger it.
thanks for getting back to me so quickly. That park works for me, however is there a way I can make it so the first trigger is only from a state change? maybe ive asnwered my question while asking it, however when trying to use the attributes available I couldnt seem to get it to cooperate, see below:
Instead of dozens of screenshots, it is much easier for us to diagnose issues if you post the automation’s YAML configuration.
It looks like you may have specified an attribute Value… if you want to trigger off the actual state, leave the attribute field empty.
alias: RODI - Refill ATO - Finished
description: ""
triggers:
  - type: turned_off
    device_id: acbd50af8b493cb409970c6cd1040d05
    entity_id: 0c6a2b9576e4c07f4c5d8014a5f115eb
    domain: switch
    trigger: device
  - trigger: state
    entity_id:
      - input_select.ato_level_state
    to: Refilled
conditions:
  - condition: device
    type: is_off
    entity_id: 833ea930720a4826ef808f466f2c8cec
    domain: switch
  - condition: numeric_state
    entity_id: sensor.sensor_tado_thermostat_outdoor_temperature
    below: 30
actions:
  - data: {}
      entity_id: switch.plug_ro_booster_pump_switch
    action: switch.turn_off
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
  - data: {}
      entity_id: switch.sonoff_1000e5f654_1
  - delay:
      hours: 0
      minutes: 0
      seconds: 5
      milliseconds: 0
  - data: {}
      entity_id: switch.sonoff_1000e5f654_2
  - data: {}
      entity_id: switch.sonoff_1000e5f654_3
  - metadata: {}
      message: ATO Refill - Completed
    action: notify.mobile_app_iphone
mode: restart
I don’t see anything like to: 200 and from: 0 in that automation.
The state trigger has a not_from option.
First a little warning about using device ids instead of entity ids.
Next you can see in the trigger section that you have from and to keys.
If you look at the state trigger in the automation trigger documentation for HA you will see that there is an option to use not_from and not_to also. There is also an example of using it with the unknown/unavailable states.
ah sorry you’re right I used the state change for the time being because I want to test if the logic works on at least the next time it goes from unavailable to 200.
alias: STATUS - ATO Refilled
description: ""
triggers:
  - trigger: state
    entity_id:
      - sensor.apex_ato_hi
    to: "200"
    attribute: value
conditions:
  - condition: state
    entity_id: sensor.apex_ato_lo
    attribute: value
    state: "200"
actions:
  - action: input_select.select_option
    metadata: {}
      option: Refilled
      entity_id: input_select.ato_level_state
  - action: notify.mobile_app_iphone
    metadata: {}
      message: ATO Is Refilled
mode: single
triggers:
  - trigger: state
    entity_id:
    to: "200"
    not_from:
      - unavailable
      - unknown
thanks, I have to admit I dont currently control my automations in YAML, would there be a good video someone could link to or a thread to learn more about harnessing YAML automations over the GUI? I currently use the GUI to avoid mis-typing anything
further to this…if I edit in YAML and add the not_from…will that update in the GUI view or it doesnt work like that?
I assume this is a correct use of your suggestion?
description: ""
triggers:
  - trigger: state
    entity_id:
      - switch.apex_ro_make_ro
    to: "off"
    not_from:
      - unavailable
      - unknown
  - trigger: state
    entity_id:
    to: Refilled
No. If you are specifying from you don’t need not_from.
ok, i understand now. lastly, would you say its best practice to do one way or the other? or just specific to the task?
If you know the state(s) you want to trigger from use that/them.
