while ago I started my hobby of astronomy and stargazing. One of the most important things around this are obviously the seeing conditions and therefore a reliable forecast to plan the nights. From my personal experience, the most reliable service out there is 7timer.info. For iOS and Android there are apps available. With my little AstroWeather you can easily integrate the forecast into Home Assistant and create some automations to remind you to reserve the upcoming night for deep sky objects and the galaxies out there :-).
So the latest update broke this integration. It is complaining about elevation. There does not seem to be a way to set this if the integration is already installed.
I added the additional configuration parameter elevation which is required for the setting and rising calculations of the moon and the sun. A clean install works, but obviously the update fails. Sorry that I did not detect that while testing.
I’m searching for the correct way to support an update. In the meanwhile you could remove and add the integration again. Then it should work again.
Logger: homeassistant.components.sensor.recorder
Source: components/sensor/recorder.py:259
Integration: Sensor (documentation, issues)
First occurred: 12:30:10 (1 occurrences)
Last logged: 12:30:10
sensor.astroweather_lifted_index has unit ° which is unsupported for device_class temperature
The 7timer backend had technical problems which were resolved a couple of hours before. Reloading the integration in your configuration should resolve the problem
