The asuswrt device tracker connected by shh can’t stablish connection with router.
It was working in 0.85
Log error:
Error during setup of component asuswrt
File “/usr/local/lib/python3.6/site-packages/homeassistant/setup.py”, line 145, in _async_setup_component
hass, processed_config)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/asuswrt.py”, line 61, in async_setup
await api.connection.async_connect()
File “/usr/local/lib/python3.6/site-packages/aioasuswrt/connection.py”, line 66, in async_connect
self._client = await asyncssh.connect(self._host, **kwargs)
File “/usr/local/lib/python3.6/site-packages/asyncssh/misc.py”, line 182, in await
return (yield from self._coro)
File “/usr/local/lib/python3.6/site-packages/asyncssh/connection.py”, line 5454, in connect
conn, _ = yield from create_connection(None, host, port, **kwargs)
File “/usr/local/lib/python3.6/site-packages/asyncssh/connection.py”, line 5110, in create_connection
yield from auth_waiter
File “/usr/local/lib/python3.6/site-packages/asyncssh/connection.py”, line 627, in data_received
while self._inpbuf and self._recv_handler():
File “/usr/local/lib/python3.6/site-packages/asyncssh/connection.py”, line 847, in _recv_packet
processed = handler.process_packet(pkttype, seq, packet)
File “/usr/local/lib/python3.6/site-packages/asyncssh/packet.py”, line 215, in process_packet
self._packet_handlers[pkttype](self, pkttype, pktid, packet)
File “/usr/local/lib/python3.6/site-packages/asyncssh/connection.py”, line 1414, in _process_kexinit
self._kex = get_kex(self, kex_alg)
File “/usr/local/lib/python3.6/site-packages/asyncssh/kex.py”, line 122, in get_kex
return handler(alg, conn, hash_alg, *args)
File “/usr/local/lib/python3.6/site-packages/asyncssh/kex_ecdh.py”, line 47, in init
self._priv = ecdh_class(*args)
File “/usr/local/lib/python3.6/site-packages/asyncssh/crypto/curve25519.py”, line 31, in init
self._priv_key = x25519.X25519PrivateKey.generate()
File “/usr/local/lib/python3.6/site-packages/cryptography/hazmat/primitives/asymmetric/x25519.py”, line 39, in generate
_Reasons.UNSUPPORTED_EXCHANGE_ALGORITHM
cryptography.exceptions.UnsupportedAlgorithm: X25519 is not supported by this version of OpenSSL.
