As above i bought these last week…they turned up yesterday…spent last night messing around with one of them…
So far not too impressed…first and foremost i couldnt get it on the home assistant…initial connection using my phone was easy but after that not so much…
Home Assisant first crashed (got stuck on the config screen) couple of reboots got me a bit further…
Asked for a code which was 123-45-678 - which it a. wouldnt accept and b. from what i can see was not changeable…
Then went looking for firmware which i couldnt find…athom website is pretty crashy and no sign of firmware either…
Messaged seller and the first thing he said was dont update the firmware…red flag to me…if i cant update it what happens when stuff stops working? Model on the back says PG06
So, so far…not too good…ill throw up some photos from my phone in a bit…
These work, these work, and these work. I’m sure there’s more Zigbee options, and there’s certainly plenty of Z-Wave options. It’s only if you want to stick with WiFi that things get tricky.
Cheers - ill keep them in mind…however while weve been chatting ive found a lad on ebay thats got 4 reflashed tasmota GP111 plugs so hes already done the hard work for me…i dont mind reflashing them…its just finding some that can be flashed!
I was going to buy some of these, but went with Local Bytes plugs in the end. Bought 6, all connected using Tasmota (they can be flashed to ESPHome but I just stuck with Tasmota) and like them so much I bought another 6!
Can’t say how long they will last as have only had the first lot for 3-4 weeks, but no issues so far.
I bought three Athom pre-flashed to ESPHome. Have worked really well. I did reflash and showed up in my ESPHome dashboard. There is a web site out there that has a template yaml and getting the first flash was a bit tricky but I worked it out!
Ok - everyone is loosing me a bit…! that GitHub link - not sure what that is… @nickrout neither - mines an athom plug… @JulianDH - no idea what that is!
Sorry i didnt reply sooner…was out at the flicks watching Avatar2…
Hello I posted the configuration yaml I have used to OTA flash my Athom plug. I hope that is helpful. My plugs did come preflashed with ESPHome but I wanted to set up my own configuration file on my ESPHome dashboard. It was a bit of a fiddle but I worked it out. I have tickets booked for Avatar but reviews have been truely dreadful
Hi there. Not really sure what it is youve posted and how i was supposed to use it…! As i say im really new to all of this and the coding/scripty stuff is way out of my league at the moment…i sent the athom plugs back and ordered some already flashed gosun plugs…
Avatar: Well we really all liked it…! much like the first one…
I have the Hive plugs and they’re great routers in my network and seem to be able to carry a signal much more effectively than other manufacturers’ router devices. How do your Salus plugs stack up against the Hive plugs specifically as routers in your zigbee network? (I’ve had poor experience with Sonoff and Ikea router devices.)
