Hello, I am looking for some AU complaint light switches for use with ESPHome, I have noticed that the deta switches from bunnings no longer use a esp chip.
Are there any alternatives out there that are still complaint ?
I have been looking at the Athom variants, But its hard to tell if they are OK for use in Aus.
However basically every one you open has the warning " New Tuya devices have replaced their Wi-Fi module with one incompatible with Tasmota!!!
Tuya-Convert might not be possible for this device since the template was added (2022-04-02)."
Its starting to feel like a real crab shoot as to if you will score a device with a ESP chip or not or if it will work or not.
I have encountered this kind of convolution in other fields, I was not expecting it to be this bad in home automation !
