Still broken for me. It did only break after i restarted HA. Would yopu mind checking that?
I see a pull request in ha integration:
There is a commit that removes the "Bearer " string from the client-id.
Yes, couple of reboot today caused other things (integrate new things), works without problems.
Today my first way was myaudi and i have to confirm some things about data protection to see my car in browser.
And just to confirm: with the PR it works for me.
Since some time I started to see in my log file errors related to this integration. Strangely all the sensors work fine. Any idea what this indicates:
2022-02-12 15:35:06 ERROR (MainThread) [custom_components.audiconnect.audi_connect_account] Unable to obtain the vehicle shortTerm tripdata of WAUZZZFY1Hxxxxxxx: 403, message='Forbidden', url=URL('https://mal-1a.prd.ece.vwg-connect.com/api/bs/tripstatistics/v1/vehicles/WAUZZZFY1Hxxxxxxx/tripdata/shortTerm?type=list&from=1970-01-01T00:00:00Z&to=2022-02-12T16:05:05Z')
2022-02-12 15:35:06 ERROR (MainThread) [custom_components.audiconnect.audi_connect_account] Unable to obtain the vehicle longTerm tripdata of WAUZZZFY1Hxxxxxxx: 403, message='Forbidden', url=URL('https://mal-1a.prd.ece.vwg-connect.com/api/bs/tripstatistics/v1/vehicles/WAUZZZFY1Hxxxxxxx/tripdata/longTerm?type=list&from=1970-01-01T00:00:00Z&to=2022-02-12T16:05:06Z')
After the last update, the service to start climatisation is working with the E-Tron thanks to arjenvrh!
Anyone else in the US no longer able to log in? I’m getting errors on startup so I deleted and tried to re-add the integration and it simply gives me “Invalid Credentials.” I’ve confirmed the account is good in both the phone app and the web. My guess is the web has changed and the HA integration doesn’t match it now.
I got the same in DE region, when try to add Audi Connect intergration and place data get info Invalid credentials. Anyone has the same and can help?
This fixed on my side:
Thank you very much! Working!!
Same here - working again!! Thank you for the folks contributing to this integration.
What change did you exactly made to make it working again? From linked post it seems that only version number was changed from 4.5.1 to 4.6.0 (or I missed something more), but it does not resolve the problem, at least for me…
In the link on the page, in menue, files changed, there are 3 files changed, this change you have to change on your side to make it run.
Ups… did not expanded the view
Thanks a lot!
I installed this integration about a year ago, but it stopped working (Audi was complaining too much activity I think), so I removed it.
I added it again yesterday.
This time Model reports as unknown, so everything got named with “None/none” in the name instead of my model name.
Anyone know where the poll interval is stored? I forgot to check this when I installed, and want to maybe change it to a longer time (to avoid any potential issue as I may have had the first time I tried this.)
Thanks!
Found it in core.config_entries
. Is it safe to change this file, or is there a UI way to update Scan_Interval
? I would have thought there should be a UI method, since maybe one might need to update a password, etc., occasionally.
At every core update I have issues with this integration, Now
I I disable the integration before upgrading the core and enable after update.
But also sensors fail (update of integration?)
Is there any way to make this integraton only get new info by the press of a button instead of every 10 minutes?
When first installed, it worked fine, but eventually (within a few days) I start getting “forbidden” errors, like I’ve been throttled or something. I reinstalled this 10 days ago (Mar 1) and it stopped Mar 6 with those errors coming every 10 minutes as it attempts to login.
2022-03-06 17:15:53 ERROR (MainThread) [custom_components.audiconnect.audi_connect_account] Unable to obtain the vehicle shortTerm tripdata of WA1Cxxxxxxxxx: 403, message='Forbidden', url=URL('https://mal-1a.prd.ece.vwg-connect.com/api/bs/tripstatistics/v1/vehicles/WA1Cxxxxxxxxx/tripdata/shortTerm?type=list&from=1970-01-01T00:00:00Z&to=2022-03-06T23:45:53Z')
I reported this error some time ago: Audi MMI support - #448 by mirekmal
Ended with disabling logger writing this to file:
logger:
default: warning
#default: info
logs:
custom_components.audiconnect.audi_connect_account: fatal
I wonder if this is somehow model specific and audi connect does not report this for every car? I do not see any shortTerm tripdata data for my car (2017 Q5) inside the app…
BTW, integration again stopped to work for me yesterday… typical issue with logging into service, perhaps URL changes by them again. How are they maintaining this for their native app? It is not updated so frequently as URLs change…
Now even my Audi phone app isn’t working. Returns the following:
Retrieval not possible
Error: E.PA.VSR.1
(2203121415)
I guessing I’ve been blocked due to the excessive failed login attempts by the integration. This happended before (a year a ago). Back then, I uninstalled the integration and eventually the Audi’s phone app started working agian. Of course all this could be coincidence, but I doubt it.
Ever hear back or get a fix on this? I’m excited I finally noticed this add-on is working in the US again just logs are being loaded with the same messages. My q8 unlike it sounds like for you, does not show short and long term trip data as entities in HA.
