Just try a different motor. Not all beds have all the motors. This way you can find out what motor does what. Important is that you don’t alter the structure of the JSON payload. Do not add extra enters or spaces because the Auping Connect gets confused otherwise.
I have 3 motors like you. The command bed_flat lowers both the middle (back) and lower (feet) but not the top (neck).
The command bed_tv doesn’t do anything with my bed. Any idea why ?
As you can see, I’ve activated all motors, but none is reacted to the request. I also don’t see any error message in the HA log. Really for the hell of me, I can’t understand why I can lower the bed but not bring it up.
@Expaso Thank you for sticking with me till the end. You are amazing !
I still don’t get totally why the auping_TV doesn’t work but with the template that you provided (without some spaces), it works. For reference to others
@Expaso I just replaced the Auping Connect to the newer release as it never really worked good for me. Any ideas on the integration as the app changed dramatically ?
What do you need specifically? I never use the app to be honest, I only use the HTTP calls for automation (hey google, activate TV mode / goodnight) and the physical remotes.
For the initial Auping connect was extremely buggy and was more out then on. Hence I pushed the company where we bought the bed, to give me the more advanced system (less open). As I assume you are going to stay with your current version, I guess you can’t help me.
Basically the remotes (user friendly), motors have changed and no more special box for the Auping connect. Works really fine with the app every time. In the app or home assistant, i couldn’t get it to work previously.
Did you get the new version to work with the Auping connect integration? I understood that they moved away from WiFi and the new Connect is based on Bluetooth only, although they still use a ESP board (which has wifi / bluetooth on the chip).
I’m about to upgrade my ‘old’ connect to the new one, but that only makes sense if the new system is still able to connect to home assistant. I would expect that it still works, since they have recently updated the Homey app (which has native support for Auping connect) and I expect that this also works with the latest Auping Connect version (not sure btw).
As the previous version didn’t work well for me. Unstable connection, I moved over. I can use the app and works as expected.
You don’t find the same info as in the previous version. So I wouldn’t know how you would find the information you need to make the connection. I would be interested in an integration though
I recently acquired the new Hive Smart modules for my Auping Bed. Just wondering, how can I retrieve the key that I need to connect to my bed? I saw mentioned about that you could find it in the App, but I can’t seem to find it. Playing around with Fiddler, but that doesn’t work either (app on my phone can’t seem to connect to the bed through the Fiddler proxy). Any ideas?
