I have re-flashed and installed a few of these recently and they seem to work flawlessly.
As a licensed Electrician they appear to be a solid product. I am only running a small amount of load through them (28w max) and they don’t show any signs of distress. Not sure how they would hold up with 10A continuous but i have seen plenty of certified products that don’t handle there full rated current without failure.
They are pretty damn cheap, and look like they wont block the plug next door. I’m looking for some plugs to do power monitoring. I bought a 2 pack of the TP-Link HS110 and they are too wide.
The tasmota templates page gives all sorts of details like pcb number, product id and so on. Also it is quite a complex setup. Have you done through it line by line and checked you code.
Apologies, answered that in a hurry. This was the first template that I tried.
I haven’t verified the Tuya Product Id or the PCB Code, etc, but have verified that the MQTT payloads sent on cmnd/diffuser/POWER1 or cmnd/diffuser/POWER2 don’t control the fan or the speed for example. This is true for the light and the water as well.
I’ve even verified the web buttons (below) don’t control the unit
Hey guys, I haven’t done the research to say this is definitely a good deal, but on the face of it this looks a good deal for some Shelly devices! Happy to hear anyone’s inputs on that.
I’m considering a purchase, but won’t be able to look in detail for a few hours.
@grantc
I’ve got one working through the Local Tuya component. Still needs to be in the Tuya app but you can control it without internet and see the power sensors in home assistant. I’ve settled on this as a comprimise.
Apparently you can manually flash them but the screws are a different security screw than I have a tool for.
They definitely have to have the RCM marked on them by the manufacturer or importer, and there are particular requirements on how the mark is displayed. See AS/NZS 4417
