No I decided on Shelly due to lower price mostly. It looks like the stitchy has been discontinued, check the MElec website.
Anyway, if you have a typical gyprock wall, yes you’d fit two behind a switch. Yes you can still switch on from the app, that’s what the “switch” connection is for, to signal the state of the physical switch. The device remains powered no matter which position the switch is in.
I have a couple of these (also available on AliExpress) which work really well. They run on 12Vdc so you just throw away the power supply they provide and get a locally sourced one which IS certified.
From the way zigbee and z-wave works, if its a direct powered device like a switch/relay or bulb it is considered a router device, if its battery powered its a end device that connects through the routing device it is able to use to connect back to the gateway you use.
a router needs to be active and listening 24/7, because it can not know when a message will arrive which needs to be forwarded.
with mains powered devices there is no need to conserve power; so these usually (but not always) have the router functionality enabled.
Many battery powered devices are sensors which wake up only when they need to send data - because extending battery life is a major issue - and so extremely unlikely to operate as routers.
I don’t think there is any hard-and-fast rule; it is up to the manufacturer (or user in the case of platforms like ESPhome) which modules are installed on each unit.
Mercator specifically call out several of their mains powered devices as not having router functionality in the linked page, however a user on Whirlpool suggests this list may not be accurate, so…
I don’t have ANY Zigbee devices yet - but my POE coordinator is in the mail along with a bunch of sensors, so I’ll be able to test out some of Mercator gear over summer
Had anyone found a way to upgrade the wiser ZigBee firmware without buying their $350 hub?
I bought a few wiser mechs to test and oh man, are they nice. Very premium feeling and hard wired 3-way switching. Just an occasional annoyance with unactioned button presses that seems like firmware.
I have no intent of using the hub long term and don’t want to fork out that much to fix a software issue. I also don’t know if a firmware update would actually resolve this.
I have a few Ikuu zigbee devices. SPP02G (Double Pointer Point with power monitor), SSW02GX-ZB (2 gang switch). Happy so far. About 3 months of use. All act as repeaters (since they are mains connected). This SSW02GX-ZB was brilliant as it would directly with the existing (not smart) mechanical two-way switches, no wiring changes but required a neutral.
