Did u ground gpio0 when u plug usb in
I tried founding a0 and also tried grounding reset
neither had an effect
Maybe a misstype, but you ground GPIO0 not A0.
After and Australian approved smartplug, preferably zwave or ZigBee that show power consumption. Iāve got a few Dlink wifi ones that are very unreliable and also a WeMo but they arenāt available anymore.
I seen the xiaomi ones work with deconz but they donāt have the insulated pins required here.
Cheers
In the case of Z-Wave you could go with Aeotec Smart Switch 6. Iāve got two of them and they do support power consumption reports.
Another popular choice are the WiFi-based Kogan plugs - however you want to flash your own firmware.
You get 4-6 of the Kogan plugs for the price of a single Aeotec Smart Switch.
no I couldnāt find a gpio0 on this module.
Have you tried adding it to the Grid app and doing a firmware update first, then try flashing with Tuya Convert 2. I read something the other day about some things needing a firmware update first.
It will not work with TC1, as the 190HA appears to be an revised version of the 189HA which needed TC2. Also, make sure you are using a clean install of Raspbian and a fresh download of TC2.
Iāve done a fresh install with Ubuntu, Iāll try doing a firmware update. I just canāt get the thing to serial flash itās not being picked up at allā¦
legit doing my head in! haha
Thats really odd, my phone isnāt getting an ip from vtrust-flash when it worked fine.
Its a ubuntu laptop and was fine for the last flash. Rebooted phone and laptop
Bingo, seems tuya-convert v1 is terminating a heap of stuff in ubuntu to do its job where as V2 isnāt!
And despite connecting the device to Grid Connect and doing an update iāve been unable to flash it using Tuya-Convert v1 or v2
This is what i have in the v2 logs
Backing up NetworkManager.cfg...
Restarting NetworkManager...
Backing up /etc/dnsmasq.conf...
Writing dnsmasq config file...
Creating new /etc/dnsmasq.conf...
Writing hostapd config file...
Configuring AP interface...
Applying iptables rules...
Starting DNSMASQ server...
dnsmasq: failed to create listening socket for port 53: Address already in use
RTNETLINK answers: File exists
Starting AP on wlp2s0 in screen terminal...
Configuration file: /etc/hostapd/hostapd.conf
Using interface wlp2s0 with hwaddr 18:cf:5e:ed:7a:a3 and ssid "vtrust-flash"
wlp2s0: interface state UNINITIALIZED->ENABLED
wlp2s0: AP-ENABLED
wlp2s0: STA 34:29:12:38:d4:00 IEEE 802.11: authenticated
wlp2s0: STA 34:29:12:38:d4:00 IEEE 802.11: associated (aid 1)
wlp2s0: AP-STA-CONNECTED 34:29:12:38:d4:00
wlp2s0: STA 34:29:12:38:d4:00 RADIUS: starting accounting session C21CC582432580B9
wlp2s0: STA 34:29:12:38:d4:00 WPA: pairwise key handshake completed (RSN)
wlp2s0: STA d8:f1:5b:92:aa:d7 IEEE 802.11: authenticated
wlp2s0: STA d8:f1:5b:92:aa:d7 IEEE 802.11: associated (aid 2)
wlp2s0: AP-STA-CONNECTED d8:f1:5b:92:aa:d7
wlp2s0: STA d8:f1:5b:92:aa:d7 RADIUS: starting accounting session 1098184EA398748C
wlp2s0: STA d8:f1:5b:92:aa:d7 WPA: pairwise key handshake completed (RSN)
wlp2s0: AP-STA-DISCONNECTED d8:f1:5b:92:aa:d7
wlp2s0: STA d8:f1:5b:92:aa:d7 IEEE 802.11: disassociated
wlp2s0: STA d8:f1:5b:92:aa:d7 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
wlp2s0: interface state ENABLED->DISABLED
wlp2s0: AP-STA-DISCONNECTED 34:29:12:38:d4:00
wlp2s0: AP-DISABLED
nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Listening on port 80
^CTraceback (most recent call last):
File "./fake-registration-server.py", line 160, in <module>
main()
File "./fake-registration-server.py", line 156, in main
tornado.ioloop.IOLoop.current().start()
File "/usr/local/lib/python3.6/dist-packages/tornado/platform/asyncio.py", line 148, in start
self.asyncio_loop.run_forever()
File "/usr/lib/python3.6/asyncio/base_events.py", line 438, in run_forever
self._run_once()
File "/usr/lib/python3.6/asyncio/base_events.py", line 1415, in _run_once
event_list = self._selector.select(timeout)
File "/usr/lib/python3.6/selectors.py", line 445, in select
fd_event_list = self._epoll.poll(timeout, max_ev)
KeyboardInterrupt
main()
self._run_once()
Seems whatever Tuya-Convert is doing its wiping the config to the plug and the app canāt find it so thats quite interesting.
Try
sudo systemctl stop systemd-resolved
Before starting tuya-convert. It looks like tuya-convert is trying to start up itās own DNS server (port 53) to send the update requests to tuyaconvert rather than the proper servers. But because Ubuntu want to have their own local DNS server, it doesnāt work. You then get errors about lookups, but for running tuya-convert this is in fine. Once you are are done, you can restart it by changing stop to start above. I have had to do this with V1 and V2.
Have you tried to swap Rx & Tx just in case?
yep tried that. multiple times
Iāll give the DNS thing a go. Iām honestly considering getting a pi for the conversionsā¦ canāt tell if itās me or these devices
I got one going no issues on the arlec grid convert though. the other one is in pieces as I thought maybe Iād try de-soldering it to flash it
These might be of interest
I like the look of these. Iāve been searching for a consistent look across lights, fans, and outlets. And, it has energy monitoring at the switch.
Thanks for the link.
I just saw these GridConnect smart ceiling fans at Bunnings (in Dural NSW) last weekend. Has anyone perhaps bought one and flashed Tasmota/ESPHome and could share the experience and configuration?
Iām willing to brick an item up to $50, beyond that either I wonāt flash it or not buy it unless proven to work with new firmware
Apologies for the delay in posting config, in fact someone beat me to the Tasmota template;
{"NAME":"KoganPOW","GPIO":[0,0,0,17,134,132,0,0,131,56,21,0,0],"FLAG":0,"BASE":52}
Adapted it to ESPHome using this config;
substitutions:
plug_name: kogan_pow2_1234
# Higher value gives lower watt readout
current_res: "0.00087"
# Lower value gives lower voltage readout
voltage_div: "775"
esphome:
platform: ESP8266
board: esp8285
wifi:
ssid: 'WiFi'
password: 'Password'
ap:
ssid: "${plug_name} Hotspot"
password: "Password"
captive_portal:
logger:
api:
ota:
web_server:
port: 80
time:
- platform: homeassistant
binary_sensor:
- platform: status
- platform: gpio
pin:
number: 03
mode: INPUT_PULLUP
inverted: True
on_press:
- switch.toggle: relay
switch:
- platform: gpio
pin: GPIO14
restore_mode: ALWAYS_OFF
on_turn_on:
- switch.turn_on: led
on_turn_off:
- switch.turn_off: led
- platform: gpio
pin: GPIO13
inverted: True
- platform: hlw8012
sel_pin:
number: GPIO12
inverted: True
cf_pin: GPIO04
cf1_pin: GPIO05
current_resistor: ${current_res}
voltage_divider: ${voltage_div}
current:
unit_of_measurement: A
voltage:
unit_of_measurement: V
power:
unit_of_measurement: W
change_mode_every: 8
update_interval: 10s
- platform: total_daily_energy
name: "${plug_name}_Total Daily Energy"
power_id: "${plug_name}_Wattage"
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
unit_of_measurement: kWh
# Extra sensor to keep track of plug uptime
- platform: uptime
Itās from Bunnings, brick it and return it. āitās faultyā.
How do i submit an issue for Tuya-convert 2 (which i believe is made by M4dmartig4n
On the other Tuya Convert by Arendst i can see an issues page, on m4dmartig4n i canāt see one
Edit: Sorry, I didnāt read that properly the first time on my phone. I thought you were asking where to submit a code. Apologies.
