The official tuya-convert repository is here: https://github.com/ct-Open-Source/tuya-convert
This covers version 2.x.
My plugs arrived today, so I will flash them tonight. Iām sure @sparkydave will be happy to see the ESPhome code though
Thanks for being the test dummy.
Kogan now have proper CCT RGB lights available, $69 for a 4 pack.
I picked one of these (iDigital Smart Home Wifi Globe [RGB Colour + Warm White]) up from the Reject Shop tonightā¦ successfully flashed with Tasmota using Tuya-Convert. However, struggling to figure put the right template (or even figure out if this is RGB, RGB_Color temp, or RGBW). A few templates (RGB + color temp) have kinda worked, but not fully.
Alone have tips on what this likely is (or how to figure out a template for it?)?
Thanks!
I assume you have watched some digilur, but he is often talking about templates and bulbs.
Might even worth trying a lohas template. have you done the relay test bit yet? kinda worked, but not fully isnāt very descriptiveā¦ is it changing colours but in the wrong direction or what?
have you tried this one actually
https://blakadder.github.io/templates/brilliant_20699.html
I have tried the 20699 template from the Tasmota databaseāeven the toggle didnāt work (same as the Kogan RGB). Iāve been working though a list of possibles (some work-ish) to try to figure it out. Will take a look at digilur shortlyā¦Thanks!
After trying a bunch of existing templates, I expect mine is somewhere in between a few. The most successful ones so far have been:
This one:
{"NAME":"TCP Smart RGBW","GPIO":[0,0,0,0,140,37,0,0,38,142,141,0,0],"FLAG":0,"BASE":18}
gives me:
- Working toggle
- Working brightness
- Working colour temperature (I thinkāgoes from whiteish-yellow to orange)
- Colour slider and saturation (?) slider just make the light flick on and off
This one:
{"NAME":"Brilliant RGB+","GPIO":[0,0,0,0,37,40,0,0,38,0,39,0,0],"FLAG":0,"BASE":18}
gives me:
- Working toggle
- No color temperature slider
- Colour slider changes colours between pink/purple/blue/red (unless saturation slider is āpalestā, in which case this slider does nothing)
- Saturation (?) slider (paleā>dark) changes colour from pale purple --> medium blue (varies a little depending on colour slider position)
This one (only the FLAG
value is different to above) seems to the same results:
{"NAME":"GenioBulbRGB","GPIO":[0,0,0,0,37,40,0,0,38,0,39,0,0],"FLAG":1,"BASE":18}
This one:
{"NAME":"Solimo RGBWW 9","GPIO":[0,0,0,0,37,40,0,0,38,41,39,0,0],"FLAG":0,"BASE":18}
gives me:
- Working toggle
- Colour temperature slides seems to just mimic the brightness slider in reverse
- Colour slider does nothing
- Saturation slider varies colour between blue and purple
None that I tried gave me green at any point, and I only got yellow when there was a ācolour tempā slider. Using it always switched the colour to yellow.
Any suggestions?
I think i have it solvedā¦ I worked though the relay method (here), with info from this table for a 4-channel system.
Seems like its pretty straightforward PWM-controlled bulb with:
- warm white (PWM4 (40)) on GPIO5
- red (PWM1 (37)) on GPIO12
- blue (PWM3 (39)) on GPIO14
- green (PWM2 (38)) on GPIO15
Iām try to get a template up on Tasmota.
I havent, but others may have
I recognise that desk, want to meet up at robodino some time and ill help you flash ?
yes they haveā¦ me
Per above, Tuya-Convert works, and Iāve submitted the Tasmota template for the light to the database. All seems to be working (though still need to set it up in HA!).
Found the problem with the new KOGAN power monitoring plugs. My ESP8266 running vtrust was not close enough to the plugs. Its been fine for most other appliances but not for these plugs. All converted without a firmware upgrade.
Also purchased the Kogan filament led bulbs. All tasmotised (if thatās a word). However one showed up in ap mode but l canāt connect to it after selecting the ap in Windows wifi settings. Hmm
Marginally off topic -
Have any of you lovely Aussies managed to integrate Amber Electricās API into home assistant??
amber gives wholesale power prices for $10 a month subscription and publishes their prices every half hour. A great trigger for demand management automations.
I have the details to get the information but am pretty bloody rubbish with cURL and am totally lost TBPH!
āWe love helping customers optimise their homes and thereās so much you can do, so donāt hesitate to have a chat with us if youāre interested and weāll work with you.ā
Have you tried contacting them in regards to it?
I hadnāt heard of them, so mostly just posting for a keep sakeā¦
Hi @exxamalte, thanks for your efforts to get the Brilliant fan controller working. With the help of of yourself and @thecubical Iāve been able to get mine up and running, and I also now have it installed.
Iāve modified your approach and I think I have come up with a solution that doesnāt need any rules in Tasmota.
I have used the following setup for Tasmota:
TuyaMCU 11,1
TuyaMCU 12,9
TuyaMCU 21,10
SetOption59 1
SetOption66 1
and the following in Home Assistant
fan:
- platform: mqtt
command_topic: "cmnd/fc_bri_01/POWER1"
state_topic: "tele/fc_bri_01/STATE"
state_value_template: "{{ value_json.POWER1.STATE }}"
speed_command_topic: "cmnd/fc_bri_01/Backlog"
speed_state_topic: "tele/fc_bri_01/RESULT"
speed_value_template: >
{% if value_json.TuyaReceived.Data == "55AA03070005030400010016" %}
Power1 1; TuyaSend4 3,0
{% elif value_json.TuyaReceived.Data == "55AA03070005030400010117" %}
Power1 1; TuyaSend4 3,1
{% elif value_json.TuyaReceived.Data == "55AA03070005030400010218" %}
Power1 1; TuyaSend4 3,2
{% endif %}
availability_topic: tele/fc_bri_01/LWT
payload_available: Online
payload_not_available: Offline
payload_low_speed: "Power1 1; TuyaSend4 3,0"
payload_medium_speed: "Power1 1; TuyaSend4 3,1"
payload_high_speed: "Power1 1; TuyaSend4 3,2"
payload_off: "OFF"
payload_on: "ON"
qos: 1
retain: false
speeds:
- low
- medium
- high
Itās not the most elegant solution, but it seems to work so far. I may try to improve it so the payload isnāt so clunky.
Hi HasQT,
The best place to see what amber are about is their site How it Works
I started a HA thread to try to dig into their data. I can get the real time data no problem, itās mooshing it into a shape that home assistant likes that im struggling with.
Nailing this will allow us to actively ādemand manageā based on price to save a little cash
Yes I saw that link after your initial post. Quite interesting. My quote was from their site. So I was suggesting they may be interested in helping you/them for mutual benefit.
Not for me at this point as I think Iād have to give up my pfit, besides I find powershop very competitive.
Template for the Reject Shop bulbs now up here:
https://blakadder.github.io/templates/idigital-9w.html
How much were those bulbs from the Reject shop? Cant find them on their website
