I used a service called 3dhubs.com. You upload the 3d file, and they give you a quote from a local 3d printer. The guy I got the finished product from was just working out of his house, presumably subsidising his hobby.
From the website that @OzGav linked, you can order the prints from someone local. Itâs really neat! (I only discovered this today) It was going to be US$23 to get 5 of those mounts printed and delivered from NSW to WA. (There were no people registered in WA. The people making them are in Aus but the website is US to itâs in USD but you can pay via CC or PayPal)
There does appear to be a few machines at the city of Melbourne library, so Iâll probably have a further dig into the detail on that!
Triple and quad are out of stock on bunnings website. Oh well I missed out.
Anyone know anything about these Arlec âgrid connectâ hub and sensors available at Bunnings?
Seem pretty good value, although the range (10m) of Bluetooth wonât always be enough.
Anyone know if they use an ESP8266, ESP32 or something else?
Would really like to be able to flash the hub using esphome.
They should be TUYA based since they are labelled âGrid Connectâ.
Neither are Aus certified, so any Sparky worth his salt wouldnât install them anyways.
I just bought one of the starter kits, and they have a TYBT3 chip inside the sensors (door, temp, and motion) and Iâm still working on getting the controller to bits. StandbyâŠ!
they use a bluetooth connection, so will probably have range issues.
As a 3D printing rookie should I print it in ABS or PLA?
I am not too sure, often the author suggests a material, but this one hasnât. I googled it and found this
3D printing with PLA vs. ABS: What's the difference? | Protolabs Network
PLA is the most commonly used filament, is reasonably environmentally friendly, and is fine for most indoor applications. If it needs to be particularly strong or durable (such as for outdoor use) then you might want to consider ABS.
Hey mate, not sure if you ended up buying one of these, but I have and re-flashed with esphome manually. It has a pretty standard Tuya style TYWE2S ESP8285, so it should be flash-able with OTA via Tuya convert as well.
Unfortunately no external control switching, but I added one myself anywayâŠ
Saw these at my bunnings, anybody know if we can integrate into HA?
Shame it doesnât do RF
You can consider as an alternative the Mirabella Genio IR from Kmart
https://www.kmart.com.au/product/mirabella-genio-wi-fi-smart-ir-universal-remote-controller/2622812
Full how-to from flashing until Tasmota template setup
I have had some trouble with my tuya convert, so I flashed it manually but check the how-to it mentions tuya convert
Good Luck
hay bro I did this
Thanks, no I got a Brilliant brand one instead. Tuya-converted and now running esphome.
There are plenty of rf/ir hubs that do integrate, such as openmqttgateway. There is nothing magical about au/nz certification as they are low voltage.
Hi @diramu
I picked up one of these anyway (though youâre right about the noise for 2+ speeds).
I have successfully Tuya Converted, and worked through all the setting here (quite similar to the GoldAir settings).
However, Iâm having some issues getting HA to âtalkâ to the fan (the TuyaMCU commands come back as unknown; Rule1 doesnât seem to detect the IR control inputs).
Would you mind sharing your config?
Thanks!
Hey folks,
Anyone found a way to integrate the Holman Bluetooth-enabled garden lighting system? Iâm new to Home Assistant, so Iâm wondering if thereâs a generic âBluetooth lightâ integration that could be re-purposed for this sort of thing?
Ta!
Afraid not.
