My Lounge Setup mite give other user Ideas
Just want to show off 1 room of my house that home assistant has Control of…
TV panasonic 65"
1= broadlink
2= IR repeater (going into cabinet
kick board slides out hiding all the cabling
how I get all my IR codes into home assistant
wemos with a IR shield on it with Tasmota on it
https://wiki.wemos.cc/products:d1_mini_shields:ir_controller_shield
my IR gas heater
one of many 433 switch talking to sonoff RF with tasmota on it
with the bluetooth sensor also have one in lounge hall master bedroom and bath room.
thanks to Intermit.tech
gas heat is control by the
  - platform: broadlink
    host: bla.bla.bla.bla
    mac: 'bla.bla.bla.bla'
    timeout: 15
    switches:
      gas_heater:
        friendly_name: "Gas Heater"
        command_on: 'JgBIAAABK5MVEBQ2FRAVERQRGQwUERQ2FRAVNhQ2FRAVEBkyFTUUERURFDYUERQRFDYUERURFDYUNhQRFTYUNhQRFDYVMBgTFAANBQ=='
        command_off: 'JgBIAAABKZUSExI3ExMSExIUEhMSExI4EhMSORI4EhMSExI5EjgSExI4EhAWOBI4EhMSExIUEjgSExI4EhMSFBI4EjgSORITEgANBQ=='
      gas_control:
        friendly_name: "Gas Control"
        command_on: 'JgBIAAABKpQTExI4EhQRFBETExMSExI4EhQROBM3ExMSExE5EzcTExM3EhQRFBI4EhMSExIUETkSEhM3EzgSExM3EzcWNRIUEgANBQ=='
        command_off: 'JgBIAAABKY8ZEhM3ExMSExEUEhMTEhM3ExMSOBI4ExISExM4EjgTEhITEzgSOBMSExITEhMTEjgSOBMSExITOBI4EzcTNhQTEgANBQ=='
gas control on is GAS UP on the ir remote
gas control off is GAS down on the ir remote
now joining all the bits
the 433 switch on the gas heater is the manual switch to turn on the lounge climate control.
- id: Gas Heater Toggle
  alias: Gas Heater Toggle
  initial_state: 'on'
  - entity_id: sensor.last_rf
    platform: state
    to: '112694'
  condition: []
  - data:
      entity_id: switch.gas_heater
    service_template: >
      {%- if (states.switch.gas_heater.state == 'off') -%}
        switch.turn_on
      {%- else -%}
        switch.turn_off
      {%- endif -%}
  - data:
      entity_id: climate.gas_heater , climate.hall_heater
    service_template: >
      {%- if (states.switch.gas_heater.state == 'on') -%}
        climate.turn_on
      {%- else -%}
        climate.turn_off
      {%- endif -%}
have this
template:
    sensors:
      garage_car_present:
        value_template: >
         {% set Car = states('sensor.car_spot_1')|int(1000) %}
         {% if (Car<200) %}
         Home
         {% else %}
         Away
         {% endif %}
      gasheater:
        value_template: >-
          {% if is_state("sensor.day_night", "Night")  and is_state('media_player.mckillentv', 'on') and
              is_state('switch.lava_lamp', 'on')  and is_state('sensor.am_pm', 'PM') %}
          on
          {% else %}
          off
          {% endif %}
for gas heater to turn on automatly
must be Night and TV on and Lava Lamp ON
- id: Gas Heater ON If TV ON
  alias: Gas Heater ON If TV ON
  - entity_id: sensor.gasheater
    platform: state
    to: 'on'
  condition: []
  - data:
    service: climate.turn_on
  - data:
      entity_id: climate.hall_heater
  - data:
      temperature: '22'
    service: climate.set_temperature
the lovelace look
now the Ir remote
I Have this sensor
  - platform: mqtt
    state_topic: "tele/IR/RESULT"
    value_template: '{{value_json.IrReceived.Data}}'
    expire_after: 1
    qos: 1
after 1 sec the sensor goes back to unknown (great to toggling a light )
so pressing the pause on the remote
- id: Kodi Pause
  alias: Kodi Pause
  - entity_id: sensor.last_ir
    platform: state
    to: '1908312'
  condition: []
  - data_template:
      entity_id: media_player.{{ states.input_select.kodi_machine.state}}
    service: media_player.media_play_pause
kodi pause/play
red button press
- id: RED IR
  alias: RED IR
  - entity_id: sensor.ir_codes
    platform: state
    to: RED
  condition: []
  - data:
      entity_id: light.kitchen
    service: light.toggle
  - data:
      payload: IR-RED
      topic: IR/CODES
    service: mqtt.publish
as I have a SKY the CH does nothing
well it now ups the gas heater up/down
- id: CH DIM DOWN
  alias: CH DIM DOWN
    platform: state
    to: DOWN
  - data:
      payload: IR-DIM DOWN
      topic: IR/CODES
  - service: script.turn_on
    entity_id: script.gas_down
- id: CH DIM UP
  alias: CH DIM UP
    platform: state
    to: UP
  - data:
      payload: IR-DIM UP
      topic: IR/CODES
    entity_id: script.gas_up
I have dyslexia writting this is heaps hard and than writting some yaml script automation code
see clear as mud
hope it make cents.
Nice project and well documented!
thanks bro
Thanks heaps for putting all of that together for me @myle!
all good bro
Nice! I love using my TV remote to mess with people haha
We have the same RF buttons too, I keep them on my kitchen table to have simple controls from the dinner table :slight_smile: and a set in my car to bypass the garage doors rolling code with a cheep tasmote’d garage door opener.
Might be insecure though so I should put the garage on a Smartthings Zigbee button soon…
I did this
can’t remember the last time I used my finger to open the garage door
