To get this
you will need to add the following to your config.
Bom Weather Component
weather: - platform: bom station: IDQ60801.94592 name: Gold Coast monitored_conditions: - apparent_t - cloud - cloud_base_m - cloud_oktas - cloud_type_id - cloud_type - delta_t - gust_kmh - gust_kt - air_temp - dewpt - press - press_qnh - press_msl - press_tend - rain_trace - rel_hum - sea_state - swell_dir_worded - swell_height - swell_period - vis_km - weather - wind_dir - wind_spd_kmh - wind_spd_kt -
Breakout the Attributes of the above weather component with some templates
- platform: template sensors: bom_temp: friendly_name: "Gold Coast Temperature" value_template: "{{ states.weather.bom_gold_coast.attributes.temperature }}" device_class: temperature unit_of_measurement: °C bom_humd: friendly_name: "Gold Coast Humidity" value_template: "{{ states.weather.bom_gold_coast.attributes.humidity }}" #device_class: humidity unit_of_measurement: '%' bom_wind_sp: friendly_name: "Gold Coast Wind Speed" value_template: "{{ states.weather.bom_gold_coast.attributes.wind_speed }}" #device_class: temperature unit_of_measurement: km bom_wind_bear: friendly_name: "Gold Coast Wind Bearing" value_template: "{{ states.weather.bom_gold_coast.attributes.wind_bearing }}" #device_class: temperature #unit_of_measurement: km bom_pres: friendly_name: "Gold Coast Pressure" value_template: "{{ states.weather.bom_gold_coast.attributes.pressure }}" #device_class: temperature unit_of_measurement: hPa -
Add this to your lovelace configuration for the Custom Darksky Weather
- type: custom:dark-sky-weather-card entity_sun: sun.sun entity_daily_summary: sensor.bom_gc_forecast_detailed_summary_0 entity_current_conditions: sensor.dark_sky_icon entity_humidity: sensor.bom_humd entity_pressure: sensor.bom_pres entity_temperature: sensor.bom_temp entity_visibility: sensor.dark_sky_visibility entity_wind_bearing: sensor.bom_wind_bear entity_wind_speed: sensor.bom_wind_sp entity_forecast_high_temp_1: sensor.bom_gc_forecast_max_temp_c_1 entity_forecast_high_temp_2: sensor.bom_gc_forecast_max_temp_c_2 entity_forecast_high_temp_3: sensor.bom_gc_forecast_max_temp_c_3 entity_forecast_high_temp_4: sensor.bom_gc_forecast_max_temp_c_4 entity_forecast_high_temp_5: sensor.bom_gc_forecast_max_temp_c_5 entity_forecast_low_temp_1: sensor.bom_gc_forecast_min_temp_c_1 entity_forecast_low_temp_2: sensor.bom_gc_forecast_min_temp_c_2 entity_forecast_low_temp_3: sensor.bom_gc_forecast_min_temp_c_3 entity_forecast_low_temp_4: sensor.bom_gc_forecast_min_temp_c_4 entity_forecast_low_temp_5: sensor.bom_gc_forecast_min_temp_c_5 entity_forecast_icon_1: sensor.dark_sky_icon_1 entity_forecast_icon_2: sensor.dark_sky_icon_2 entity_forecast_icon_3: sensor.dark_sky_icon_3 entity_forecast_icon_4: sensor.dark_sky_icon_4 entity_forecast_icon_5: sensor.dark_sky_icon_5
entire package can be found here Weather Package
