Australian Weather Forecast using BOM Public FTP
Manifest is what worked for me
and for the record, just upgraded from 91.4 to 92.2, with just an empty __init__.py file - no errors, all works.
I firstly tried with just an empty __init__.py but HA still complained, created the manifest.json and then it was happy and working nicely. It seems odd that people are having differing results for the same custom_component
Could someone help me with which IDV value i should be using for Frankston.
When i look the forecast up it seems to have two IDV values but neither of these match Frankston
http://www.bom.gov.au/vic/forecasts/frankston.shtml
How good are your python skills?
I’m in the same boat. The info is on the BOM FTP site, but not at a dedicated Product ID (eg. IDV10450).
The Frankston forecast is in ftp://ftp.bom.gov.au/anon/gen/fwo/IDV10753.xml
But you’d need an extra layer of detail to pull out it’s forecast data, while ignoring all the other towns/areas.
For example:
product_id: IDV10753
aac: VIC_PT023
It’s beyond me.
Yeah my python skills are non-exisit, and i wouldnt have the time or the will to learn at this point
Then your closest is IDV10450, City Forecast - Melbourne (VIC).
Hi, I have saved the bom_forecast.py into /hass_config/custom_components/sensor directory. /hass_config is where my configuration.yaml is located.
Then I edited the configuration.yaml as per indicated. But when i start home assistant, it says:
"Integration bom_forecast not found when trying to verify its sensor platform"
I know I am missing something here. Help appreciated.Thanks
Rename the directory to custom_components/bom_forecast. Rename the bom_forecast.py file to sensor.py
This has been required since 0.91 https://www.home-assistant.io/blog/2019/04/03/release-91/#notable-breaking-change
Hi Tom, I have just tried. it is throwing the same error. Any ideas?
The log says:
Integration bom_forecast not found when trying to verify its sensor platform.
9:55 PM components/homeassistant/init.py (ERROR)
add a empty __init__.py to the same directory.
thats a double underscore before and after init
And if that doesn’t fix it, add a manifest file as per these instructions:
Thanks. I have now done this. Doesn’t work. Still the same error.
Thanks. Have now done this too. If I run the check config button, it says:
Configuration invalidCHECK CONFIG
Invalid config for [sensor.bom_forecast]: Malformed Product ID for dictionary value @ data[‘product_id’]. Got ‘IDW60901.94608’. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.bom_forecast/
Your product id should be: IDW60901 not IDW60901.94608
Thanks mate. That does it. No more errors!
But when i add a sensor card in Lovelace, I am not seeing any relevant sensor associated with the weather forecast. Am I expected to see ‘max’, ‘min’, ‘chance of rain’ etc?
Edit: it turns out there are other errors.
Sun May 12 2019 00:16:40 GMT+0800 (Australian Western Standard Time)
Error while setting up platform bom_forecast
  File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
    return fut.result()
  File "/config/custom_components/bom_forecast/sensor.py", line 241, in setup_platform
    bom_forecast_data.update()
  File "/usr/src/app/homeassistant/util/__init__.py", line 224, in wrapper
    result = method(*args, **kwargs)
  File "/config/custom_components/bom_forecast/sensor.py", line 421, in update
    ftp.retrbinary('RETR ' + self._product_id + '.xml', file_obj.write)
  File "/usr/local/lib/python3.7/ftplib.py", line 442, in retrbinary
    with self.transfercmd(cmd, rest) as conn:
  File "/usr/local/lib/python3.7/ftplib.py", line 399, in transfercmd
    return self.ntransfercmd(cmd, rest)[0]
  File "/usr/local/lib/python3.7/ftplib.py", line 365, in ntransfercmd
    resp = self.sendcmd(cmd)
  File "/usr/local/lib/python3.7/ftplib.py", line 273, in sendcmd
    return self.getresp()
  File "/usr/local/lib/python3.7/ftplib.py", line 246, in getresp
    raise error_perm(resp)
ftplib.error_perm: 550 Failed to open file.
edit 2: I am using home assistant 0.92.1 in a docker in ubuntu if that makes a difference?
Anyone any ideas? Thanks much.
I am getting these as well
 anyone know why the forecast is not included in the official bom package?
I had a look through the BoM FTP server. The product id you want for the Perth forecast is: IDW12300.
IDW60901 is the latest Perth observations.
You are a legend Tom. I edited the product ID and restart home assistant, now everything is working. no errors. and I can see the daily forecast.
Awesome, thanks for posting these instructions, worked like a charm!
I’ve created a pull request on this repo to contain your instructions, as no doubt more people will run into this too. :slight_smile:
