Australian Weather Forecast using BOM Public FTP
BOM radar camera is out! Hell yeah!
It seems to be a bit picky with the radar ids you can use. No problem with the 128km radar ids but the 512km composites return only a black image (the id, frames and delta were correct). The old custom component did not have this issue.
I didnā€™t even know there was a custom component! I would have been straight on to itā€¦
Confirm these steps fixed mine too. Ta.
Mine is working fine with both the name (Melbourne) and id (for the 64km close up).
Try it with the 512km radar for Melbourne (ID ā€˜021ā€™). Make sure you include the quotes around the id number. Thatā€™s important, particularly for IDs with leading 0s.
Confirm 512km radar for Melbourne (ID ā€˜021ā€™) no-worky with:
- platform: bom
  delta: 360
  frames: 6
Adding your experience here would be appreciated:
No Prob. Done.
Mucking around with some macro/micro radar combinations to go on my permanent display. Working well. The animated dark sky card uses the bom forecast as per an earlier thread. I made it compact, cause I found I didnā€™t really look at the other stuff.
Is this the right thread for this? Just point me elsewhere if thereā€™s a better BoM radar oneā€¦
Something like this in lovelace.
- elements:
    - camera_image: camera.radar_256
      entity: camera.radar_256
      style:
        font-weight: bold
        height: 40%
        left: 20%
        top: 20%
        width: 40%
      type: image
  camera_image: camera.radar_64
  type: picture-elements
Sorry for the abandonware everybody, wish I had time to worry about this but Iā€™m sure you can all figure out this new custom component re-jig.
@Mahko_Mahko The old thread was here: Australian Animated Radar using BOM Public FTP Though now it is a built in component might be worth stating a new one.
@BrendanMoran Creating a custom component isnā€™t just for Christmas :slight_smile: :dog2:
But seriously, its all working with the ā€œgreat migrationā€ and manifest instructions.
Lodged an issue fort the New camera though.
The manifest instructions only apply to inbuilt components - not custom componentsā€¦
Thatā€™s not what I have found in practice. I tried the blank __init__.py file first. Made no difference. Sill got warnings/errors. Adding a manifest file stopped this occurring for three different custom components. Including this one.
I have also found the same with helping folks here, sometimes the __init__.py file doesnt fix and only a minimal manifest.json file works
If thatā€™s the case and they really are creating the right file I still think the dev needs to give input as to the recommended solution. Manifests are for core components according to the docs.
they are optional for custom components
awarecanYesterday at 2:40 AM
@aidbish , this manifest.json IS OPTIONAL for custom component
i had to query the devs yesterday as one doco said optional and the other said required, an update to the doco that said required has been put through to say they are optional for custom components
Just dropping by to say thank you for the component.
I got caught out for an hour by the 0.92 requirement change listed above about 1 day ago, but after realising I installed and it ran fine.
Worked for me, many thanks!
