sorry!! I Dont understand this part . could be great if you could helpā¦thankxxx
First do points 1,2 and then post here json file.
Start with a simplified version of your card to get a code shorter.
Anyway, I provided a detailed instruction for a ācannot write a temple myselfā case.
HA requires ālearningā - if a user does not learn then he always needs someone to write a code.
is there any way to make this gem work with the GitHub - alexarch21/history-explorer-card: A card for Home Assistant Lovelace for exploring the history of your entities interactively and in real time.?
I get the following entity data for the history explorer card:
entities:
- entity_id: "123"
whereas I need something like this:
graphs:
- type: "line"
entities:
- entity: "123"
Any chance I can make a convertion? I saw card_params, but this is not sufficient?
I am trying to set a filter for any entity that has āiphoneā in the name, while ignoring case. Unfortunately this does not work. How can I filter using a regular expression like this?
type: custom:auto-entities
card:
type: entities
filter:
include:
- attributes:
device_class: battery
exclude:
- name: '*iPhone*' # does work
- name: '*iphone*' # does not work
- name: '/*iphone*/i'. # does not work
sort:
method: state
numeric: true
Iām trying to use auto entities with ownbee/bootstrap-grid-card: Bootstrap grid in Lovelace UI (github.com) and tried diffrent thing:
- type: custom:auto-entities
card:
type: custom:bootstrap-grid-card
card_param: row
filter:
include:
- domain: light
area: Living Room
options:
type: "custom:button-card"
class: "col-3 col-md-2"
template: button_light
exclude:
- domain: light
area: Living Room
Gives the error: No cards configured
I also tried:
card:
type: row
card_param: cards
filter:
include:
- domain: light
area: Living Room
options:
exclude:
- domain: light
area: Living Room
Gives the error Unkown type encountered: row, Is there a way to get this to work to fill the columns within the bootstrap row?
I want to use wildcards with group:
as we can with e. g. entitiy_id
. How?
Working:
include:
- entity_id: binary_sensor.*presence*
Not working:
include:
- group: binary_sensor.*presence*
group:
seems to only accept exactly one group and lists its entities. I need to list the entities of several groups, all sharing a similarity in their name. Thatās what I want to take advantage of.
I know one or two workarounds (like adressing the entities of all those groups manually or just listing all single groups by their name etc.) but those are not smart at all.
Why not create a group of groups and use that?
Not smart at all too.
- Will need to maintain an additional, totally useless group manually
- Just for auto-entities
- Not sure if it would even work cause the groupās entities would be groups (children) but I want grandchildren
No Iām not going that path. auto-entities should have that power.
No-one said it would be easy.
Well, itās an open source project, so fee free to submit a PR.
Not necessarily. You can use automations to dynamically update groups
Nice idea. But again an additional step and a workaround for a lacking feature in auto-entities
I agree that this would be a nice new feature, but since the addon is someoneās side project, I donāt expect it to be released soon. So if you are in need of a solution you should pick any workaround with the least friction. Which workaround that is, is a personal preference.
I tested my assumption: I was right. Having
- group containing
- other groups
- which contain entities
and using the root group as include filter (group: binary_sensor.root_group
) will only list the root groupsā entities - which are the other groups. Not getting the grandchildren that way. So that workaround is a dead end.
Iāve got around 20 Ring security sensors and they each have 4-5 entities each:
- state
- tamper status,
- battery level,
- āinfoā,
- bypass mode.
Iām to use auto-entities to do a device filter for *Ring*Sensor*
and get all the entitiesā¦ but Iām getting 80-100 individual entities which is a bit intense.
Is there a way to use this Lovelace plugin to fetch all Ring sensor entities AND group entities from the same device into one row/item? Maybe using multiple-entitity-row?
I can understand @e-raser s thought on it belonging to the functionality already, given Thomasā own documentation on GitHub - thomasloven/lovelace-auto-entities: š¹Automatically populate the entities-list of lovelace cards
Any filter option can use
as a wildcard for string comparison
Given that, I suppose an Issue on the repo is in order, maybe Thomas can explain, or fix.
on expanding the nested groups: FR: Add expand on nested groups (lights, switches etc) Ā· Issue #268 Ā· thomasloven/lovelace-auto-entities Ā· GitHub
As a side note, I found the interface choking on entering direct YAML for my card (specifically on the regex).
I wrote the code up in a separate editor, copy-pasta-ed into the field and saved it. The same exact thing that I keyed into the interface and did not work, now works without a problem.
Auto-entities card displaying battery status:
card:
type: entities
title: Button cell battery status
filter:
include:
- name: /.*?[Ss](ensor|witch)\d.*?([Pp]ower|[Bb]attery)/
sort:
method: state
reverse: false
numeric: true
show_empty: true
Does anybody know of a way to simply create a vertical list of areas with any of the stock cards?
The left most column should simply list the areas nameās rather than the full sensor name (here just as place holder a glance card).
type: horizontal-stack
cards:
card:
type: glance
show_state: false
show_icon: false
columns: 1
filter:
include:
- entity_id: sensor.eq3_temp*
exclude: []
card:
type: glance
show_name: false
show_icon: false
columns: 1
filter:
include:
- entity_id: sensor.eq3_temperature*
exclude: []
card:
type: glance
show_name: false
show_icon: false
columns: 1
filter:
include:
- entity_id: sensor.xiaomi_temperature*
exclude: []
card:
type: glance
show_name: false
show_icon: false
columns: 1
filter:
include:
- entity_id: sensor.xiaomi_humidity*
exclude: []
Meanwhile I found it !
For people looking for an example of mushroom integration, he is mine :
type: vertical-stack
cards:
- type: custom:mushroom-title-card
subtitle: Batteries
sort:
method: state
numeric: true
card:
type: entities
filter:
include:
- entity_id: '*battery_level*'
- attributes:
state_class: measurement
options:
type: custom:mushroom-template-card
primary: '{{ states[''this.entity_id''].attributes.friendly_name }}'
secondary: '{{ states[''this.entity_id''].state }}%'
icon: >-
{% set battery_level = states['this.entity_id'].state |float(0) %}
{% set battery_round = (battery_level / 10) | int(0) * 10 %} {% if
(battery_round >= 100) %}
{{ 'mdi:battery' }}
{% if (battery_round > 0) %}
{{'mdi:battery-' ~ battery_round}}
{{ 'mdi:battery-alert' }}
icon_color: >-
{% set battery_level = states['this.entity_id'].state |int(0) %}
(battery_level >= 50) %}
{{ 'green' }}
{% if (battery_level > states('input_number.number_batterij_drempel') |int(0)) %}
{{'orange'}}
{{ 'red' }}
tap_action:
action: none
double_tap_action:
action: none
exclude:
- attributes:
friendly_name: '* Battery Level'
sort:
method: state
numeric: true
why use the icon template? youāve selected the device_class: battery
, which does that for you
or doesnt the mushroom card show the core device_class? (asking since I dont use the Mushroom cards)
If you donāt specify an icon in a mushroom template card, none will be displayed
