Maybe I have seen this and maybe there are some floating around, but does anyone know of a good way to schedule daily or weekly backups in HA? With all the improvements which there is probably more than I need I cannot believe scheduling backups are not in HA by default. Yes, I am aware you can run manual ones. Just looking for something reliable.
thanks. External backups would be nice but for now I am just looking to back it up locally. I’d have to check some older posts, but I am pretty sure from ha > command line I can kick off backup. I just never got added in as script that could be automated.
#!/bin/sh
# Stop Home Assistant
ha core stop
# Create Backup
ha backups new --name "Automated backup $(date +%Y-%m-%d)"
# Start Home Assistant
ha core start
It is really, really not advised to safe a backup only locally. It is like don't doing a backup at all... And trust me, we all know what we're talking about. But I trust in you, that you at least download a backup to your local machine (eg. your laptop).
That being said, and not to sound to much like a teacher, have you taken a look at the above linked Add-on from @sabeechen? It allows for the automated backup and optionally an upload to GoogleDrive.
Trust me, this Add-on is what you want. Setup a password and it is even ok-ish to upload it to Google. If someone does the effort to encrypt your password protected HA config, it is more likely that that person or organization has already other things hacked from you. Assuming you used a strong password...
Seriously, check out the Add-on, it is the de facto standard for automated backups in HA, and it is very well maintained!
Couple things. I appreciate the feedback, but just because I might be a newbie with HA doesn’t mean with IT in general. So the first thing of which I’d like to point out is I did not get chance to revise my last post before you replied. The next is if I am going to back up to somewhere it will probably be something other than Google. Need I say this company doesn’t exactly have the best reputation when it comes to privacy? The other thing is your assuming perhaps HA is running on a local computer. Incorrect, it was initially running as a VM on a separate IoT vlan in Ubiquiti home network. It is now running on a dedicated HP Micro Mini. You are correct that I do at times download a backup of HA to my local computer.
I was able to get Samba Backup installed and for now whether you disagree with me which I am guessing you do I just want to do a local backup. Once they are working I will certainly want to upload to my Dropbox. Just prefer to not use the guys (Google) that want to know what tissue paper used when you go to the crapper.
If you had said so from the beginning, my answer would’ve been another. So next time just tell people what you’re after and what your capabilities are, so they can give you an answer, that fit your needs. On the other hand, with that attitude you might get not that many answers as you had hoped for.
No attitude and didn’t think it came off that way. By the way your reply to me came off as if you were talking to an someone ill informed and a bit obnoxious (And trust me, we all know what we’re talking about). You may want to choose your own words little more carefully. Some people might not take kindly to that, even with good intents.
If you think Google is all fine and dandy, go read what the European Union courts have said with them and blatant disregard for privacy.
As it turns out I found my answer for automated scheduled backups via the video below. Guess sometimes have to look further and ignore certain elements who say trust me we know what we are talking about. Really, than why was what I found not posted as I clearly stated what I was looking for. I’d comment further but why waste my time when I supposed to believe egoistical individuals that want me to trust them. I am not referring to the people on these forums in the past who have helped me just the last one who replied to me.
Just to save anyone else the pain of skimming a 17 minute Youtube, you can create an automation in HA to run whenever you want (assuming it’s within a 24hour period - creating 25+ hours requires some finagling).
In the Actions section, search for ‘backup’ and select ‘Home Assistant Supervisor Create a full backup’.
Alternately, if you are comfortable with the CLI, you can simply run backup creation as a cron job. Save scripts under one of the following directories to have it run at the specified frequency:
/etc/periodic/15min
/etc/periodic/hourly
/etc/periodic/daily
/etc/periodic/weekly
/etc/periodic/monthly
Here’s a script I put together for the purpose, which additionally pushes the new backup to a remote VPS:
#!/bin/bash
slug="$(ha backups new | grep slug | awk '{ print $NF }')"
scp /root/backup/${slug}.tar my.ssh.server:home-assistant-backups/
# keep only last four backups
cd /root/backup; ls -t | tail -n +5 | xargs rm
ssh my.ssh.server 'cd home-assistant-backups; ls -t | tail -n +5 | xargs rm'
Saving the script to any of the folders will automatically schedule it. I’m looking into the same thing and I have not tested Ryan’s script but I believe that the script assumes that you have SSH keys in place for authentication and a directory on the target server called home-assistant-backups.
Ryan the script is simple and elegant. SCP is cool. I’m trying to work out how to do this up to a box I have on the net from about 18 different HA boxes in a secure and scalable way.
I went through many iterations but settled on the following shell script cron job solution. I hope it help folks save some time :
#!/bin/sh
# This script works in HassOS core 2024.12.2
# -Performs a full backup saved to the local server (only keeping the last 4 local backup files)
# -Performs a full backup saved to a network storage location
# -Provides success or failure feedback in the form of notifications within the HassOS UI
# Update with your Home Assistant URL
HA_URL="http://homeassistant.local:8123"
# Create (HA_TOKEN) a Long-Lived Access Token from the HA UI: Profile/Security/Long-lived access tokens
HA_TOKEN="REPLACE_WITH_TOKEN"
# Create (NET_STORE) a network storage location from the HA UI: Settings/System/Storage/Network Storage
NET_STORE="REPLACE_WITH_NETWORK_STORAGE_NAME" # Just the name you created above for the storage location
# Save this file to your HA server in one of the automated cron folders: etc/periodic/weekly (I set mine weekly and named it 'HABackup.sh')
# Make the file executable from the HA terminal (or ssh): chmod +x /etc/periodic/weekly/HABackup.sh
# Assure no file incompatibilities (since this file was created in windows), from HA terminal: dos2unix /etc/periodic/weekly/HABackup.sh
# Run/test the script by running it from HA terminal: /etc/periodic/weekly/HABackup.sh
# Kill all cron jobs from HA terminal: killall crond
# Set all cron jobs from HA terminal: crond
BACKUP_DIR="/root/backup"
MAX_RETRIES=3
RETRY_DELAY=10 # Delay between retries in seconds
# Sends a persistent notification to Home Assistant
send_notification() {
local message="$1"
# Optional: adjust the title as needed
curl -s -X POST -H "Authorization: Bearer $HA_TOKEN" \
-H "Content-Type: application/json" \
-d "{\"message\": \"$message\", \"title\": \"Weekly Backup\"}" \
"$HA_URL/api/services/persistent_notification/create" > /dev/null
# We now replace log_message with direct calls to send_notification
log_message() {
send_notification "$1"
# Create a new Home Assistant backup (local) and get the slug, with retry logic
slug=""
for i in $(seq 1 "$MAX_RETRIES"); do
slug="$(ha backups new 2>/dev/null | grep slug | awk '{ print $NF }')"
if [ -n "$slug" ]; then
log_message "INFO: Local backup created successfully with slug: ${slug}"
break
else
sleep "$RETRY_DELAY"
fi
done
# Check if slug was retrieved after all retries
if [ -z "$slug" ]; then
log_message "ERROR: All attempts to create weekly local backup failed"
exit 1
fi
# Verify the backup file exists before proceeding
backup_file="${BACKUP_DIR}/${slug}.tar"
if [ ! -f "$backup_file" ]; then
log_message "ERROR: Backup file ${backup_file} does not exist"
exit 1
fi
# Keep only the last four local backups
cd "$BACKUP_DIR" || {
log_message "ERROR: Failed to change directory to backup directory"
exit 1
ls -t | tail -n +5 | xargs rm -f
# Create a new Home Assistant backup on the NET_STORE
ha backups new --location "$NET_STORE" --name "Weekly_Backup_$(date +'%Y%m%d%H%M%S')" --no-progress 2>/dev/null
if [ $? -eq 0 ]; then
log_message "INFO: Weekly NAS Backup created successfully"
break
else
fi
done
# Verify if NET_STORE backup creation succeeded after retries
if [ $? -ne 0 ]; then
log_message "ERROR: All attempts to create weekly NAS backup failed"
exit 1
fi
Exactly what I was looking to do! Thank you for the awesome script.
I’m getting this error after setting it up per comments:
/etc/periodic/daily/Hass-backup-script.sh zsh: /etc/periodic/daily/Hass-backup-script.sh: bad interpreter: /bin/sh^M: no such file or directory
I resolved this by doing:
sed -i -e 's/\r$/\n/' Hass-backup-script.sh
But then I get these errors:
> tc /etc/periodic/daily ➜ daily ls Hass-backup-script.sh ➜ daily sed -i -e ‘s/\r$/\n/’ Hass-backup-script.sh ➜ daily /etc/periodic/daily/Hass-backup-script.sh curl: (2) no URL specified curl: try ‘curl --help’ or ‘curl --manual’ for more information /etc/periodic/daily/Hass-backup-script.sh: line 63: -H: not found /etc/periodic/daily/Hass-backup-script.sh: line 65: -d: not found /etc/periodic/daily/Hass-backup-script.sh: line 67: http://homeassistant.local:8123/api/services/persistent_notification/create: not found curl: (2) no URL specified curl: try ‘curl --help’ or ‘curl --manual’ for more information /etc/periodic/daily/Hass-backup-script.sh: line 63: -H: not found /etc/periodic/daily/Hass-backup-script.sh: line 65: -d: not found /etc/periodic/daily/Hass-backup-script.sh: line 67: http://homeassistant.local:8123/api/services/persistent_notification/create: not found ➜ daily
UPDATE: I fixed formatting issues with proper QuickEdit app for Android, rather than a plain text editor app. I re-ran it and all looks good now except for a descriptive file name for backup file.
I’m getting the slug as the filename instead of the friendly name where stated here:
ha backups new --location "$NET_STORE" --name "Daily_Backup_$(date +'%Y%m%d%H%M%S')" --no-progress 2>/dev/null
log_message "INFO: Daily unRAID Backup created successfully"
break
else
