Note: The blueprint was developed for my own case. You can use it as a draft for adaption to your own case.
The automation switches the climate on, if the temperature in room below T_goal-T_delta, and switches the climate off, if the temperature above the goal temperaute T_goal.
Additionaly the climate is switched on/off by the door/window sensor (defined as a group).
Furthermore there is a “input_boolean.flag” to heat the room once and reset to a T_min temperature after the temperature is reached (use it, if you want asleep in a warm room, but don’t need this temperature whole night).
Unfortunately, since it is not possible to use template_trigger in blueprints an the moment, you need additional binary_sensors defined outside of the blueprint, for the case T_curr > T_goal (current temperature above goal temperature), and T < T_goal - T_delta (current temperature is to low).
room_above_goal_t:
friendly_name: "room: T > T_goal"
value_template: >-
{{ states('sensor.room_t') | float > state_attr('climate.room_thermostat', 'temperature') |float }}
room_below_goal_t:
friendly_name: "room: T < T_goal-dT"
value_template: >-
{{ states('sensor.room_t') | float < (state_attr('climate.room_thermostat', 'temperature') |float - states('input_number.t_delta') | float) }}
Also you need a input_boolean for manually on/off the climate.
In my case I switch this flag if nobody is at home (off) or just arrived (on), as well as in this automation by “door/window” group.
All what you have to do, if it’s running, is to set your T_goal temperature manually at thermostat itself or with an automation. I set 4-5 different temperatures during the day by automations.
There is a deactived debbuger within automation notify.debugger_file. Delete it, if you get problems with the debbuger, or replace by your own notification.
The “auto”-state will be overwritten by “heat” state.
Here some pictures and graphs from UI.
Climate - control:
And graph of the controlled temperate (red = T_goal, green = T_curr, blue = T_goal - T_delta, white = on/off state of climate)
Here the screenshot of the automatisation:
Here is the blueprint itself:
blueprint:
name: Automatisation of heat controll
domain: automation
input:
climate_target:
description: Thermostat to be controlled
selector:
entity:
domain: climate
t_current_target:
description: Current temperature in room.
selector:
entity:
domain: sensor
climate_trigger_t_above:
name: Flag T > T_goal
description: Flag, it the temperature T above T_goal
selector:
entity:
domain: binary_sensor
climate_trigger_t_below:
name: Flag T < T_goal - T_delta
description: Flag, it the temperature T below T_goal - T_delta
selector:
entity:
open_close_target:
name: Door | Window - group
description: Group of sensors for switching off the climate in "on"-state
selector:
entity:
domain: group
climate_auto_control_target:
name: Manual switch for climate
description: Flag for activating / deactivating of climate control
selector:
entity:
domain: input_boolean
climate_reset_heating_control_target:
name: Manual switch for reset of temperature
description: Reset T_goal to T_min after reaching T_goal
selector:
entity:
t_min_target:
description: Minimal temperature is after reset of temperature in (heating once) mode.
default: 17
selector:
number:
min: 10.0
max: 30.0
step: 0.5
unit_of_measurement: °C
t_delta_target:
description: Maximal deviation of target temperature. T_low = T_goal - T_delta
default: input_number.system_delta_goal_t
selector:
entity:
domain: input_number
mode: restart
variables:
climate_target: !input climate_target
t_current_target: !input t_current_target
open_close_target: !input open_close_target
climate_auto_control_target: !input climate_auto_control_target
climate_reset_heating_control_target: !input climate_reset_heating_control_target
climate_trigger_t_above: !input climate_trigger_t_above
climate_trigger_t_below: !input climate_trigger_t_below
t_min_target: !input t_min_target
t_delta_target: !input t_delta_target
t_goal: "{{state_attr(climate_target, 'temperature') | float}}"
t_current: "{{states[t_current_target].state | float}}"
t_delta: "{{states[t_delta_target].state | float}}"
debug_mode: 'off'
- platform: state
entity_id: !input open_close_target
for: 00:00:45
- platform: state
entity_id: !input climate_target
to: auto
- platform: state
entity_id: !input climate_auto_control_target
- platform: state
entity_id: !input climate_trigger_t_above
to: 'on'
- platform: state
entity_id: !input climate_trigger_t_below
to: 'on'
- platform: state
to: heat
condition: []
- choose:
- conditions:
- condition: template
value_template: "{{ debug_mode == 'on' }}"
sequence:
- service: notify.debugger_file
message: |-
Start of automation: {{now().strftime('%Y-%m-%d %H:%M:%S')}}
from_state: {{ trigger.from_state.state }}
to_state: {{ trigger.to_state.state }}
entity_id: {{ trigger.from_state.entity_id }}
climate_target: {{climate_target }}
t_delta_target: {{t_delta_target }}
t_current_target: {{t_current_target }}
t_current: {{t_current }}
open_close_target: {{open_close_target }}
climate_auto_control_target: {{climate_auto_control_target }}
climate_trigger_t_above: {{climate_trigger_t_above}}
climate_trigger_t_below: {{climate_trigger_t_below}}
t_min_target: {{t_min_target }}
climate_reset_heating_control_target: {{climate_reset_heating_control_target }}
t_goal: {{t_goal}}
t_delta: {{t_delta + 1.0}}
default: []
- choose:
- conditions:
value_template: '{{ trigger.from_state.entity_id == open_close_target}}'
sequence:
- choose:
- conditions:
sequence:
message: Called by door group
default: []
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
# door/window open -> check hold_temperature
- choose:
- conditions:
- condition: state
state: 'on'
sequence:
# hold_temperature on -> turn off hold_temperature
- service: input_boolean.turn_off
data: {}
default:
# hold_temperature off -> check climate on
- choose:
- conditions:
- condition: not
conditions:
- condition: state
state: 'off'
sequence:
# climate on -> turn off
- service: climate.turn_off
data: {}
default: [] #climate already off -> continue
default:
# door/window closed -> check hold_temperature
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
# hold_temperature off -> turn hold_temperature on
data: {}
default: [] # hold_temperature on -> continue
- conditions:
value_template: '{{ trigger.from_state.entity_id == climate_auto_control_target}}'
sequence:
# Called by hold_temperature
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
# hold_temperature on to off -> check climate on
- choose:
- conditions:
- condition: not
conditions:
- condition: state
state: 'off'
sequence:
data: {}
default: [] # climate off -> continue
default:
# hold_temperature off to on -> check if t < goal
- choose:
- conditions:
value_template: '{{ t_current < t_goal }}'
sequence:
# t < goal is true -> check if heat on
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
# climate off -> turn climate to heat mode
- service: climate.set_hvac_mode
hvac_mode: heat
default: [] # climate already on -> continue
default: [] # t < goal is false -> continue
- conditions:
- condition: or
conditions:
- condition: and
conditions:
value_template: '{{ trigger.from_state.entity_id == climate_target}}'
value_template: '{{ trigger.to_state.state == trigger.from_state.state}}'
- condition: and
conditions:
value_template: '{{ trigger.from_state.entity_id == t_current_target}}'
value_template: '{{ trigger.to_state.state != trigger.from_state.state}}'
- condition: and
conditions:
value_template: '{{ trigger.from_state.entity_id == climate_trigger_t_above}}'
- condition: and
conditions:
value_template: '{{ trigger.from_state.entity_id == climate_trigger_t_below}}'
sequence:
# 'Called by climate temperature or sensor: check hold_temperature on'
- choose:
- conditions:
- condition: or
conditions:
- condition: and
conditions:
- condition: and
conditions:
value_template: '{{ trigger.from_state.entity_id != climate_target}}'
value_template: '{{ t_current < t_goal - t_delta }}'
sequence:
# T < goal - d for sensor or T < goal for climate is true -> check if heat on
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
hvac_mode: heat
- conditions:
value_template: '{{ t_current > t_goal }}'
sequence:
# '"T > goal is true -> turn off climate, check if heat-once"'
- choose:
- conditions:
- condition: state
entity_id: !input climate_reset_heating_control_target
state: 'on'
sequence:
# heat once is true -> set T_min, reset heat once
data: {}
- service: climate.set_temperature
temperature: '{{t_min_target }}'
default: [] # heat once is off -> continue
data: {}
default: [] # Tgoal - d <= T <= Tgoal by sensor -> continue
- conditions:
- condition: and
conditions:
sequence:
# Called by climate state
- choose:
- conditions:
- condition: state
state: auto
sequence:
# '"climate auto -> auto to heat"'
hvac_mode: heat
- conditions:
- condition: state
state: heat
sequence:
# climate to heat -> check if hold_temperature is on
- choose:
- conditions:
- condition: state
state: 'off'
sequence:
# 'by climate on to heat: hold_temperature off -> turn on'
data: {}
default: [] # 'by climate on to heat: hold_temperature on -> continue'
default: [] # climate not auto and not to heat -> just continue
default: [] # Unknown trigger case
# '#### End of automation ####'
