Automation for alarm not armed and I'm away - Envisalink with Honeywell alarm
Hi, I am using Envisalink with a Honeywell alarm and I’m trying to figure out an automation for the status of the alarm when I am away. In other words, if the alarm is not armed (either ready, not armed or fault, not armed) and I am away, notify me. I have the away part down, but I can’t figure out what to use for the alarm portion. Thanks.
Hi HA11,
Are you using a blueprint. If you are having a problem with a specific Blueprint, the first point of contact is in the Exchange (or Github) post that you found the Blueprint in originally.
There are people there using the equipment and the blueprint and will be able to give you more accurate information regarding your problem.
Here you might find someone.
Hi, I’m not currently using one. Thank you for the info.
I’m not familiar with Envisalink or Honeywell, but if you have them integrated into Home Assistant you could probably use this Blueprint.
Once you leave your home zone you can us an “If-Then” to check if your system is armed, and if it’s not, send a notification.
