gekim.84
(Gekim84)
March 7, 2019, 11:57pm
41
very wierd, I tested and seemed have have worked when I adjusted the time (added +8 hours)
- condition: time
after: '23:53:00'
before: '23:55:00'
I don’t know why my system is showing two different times, and why the automation is honoring the false timezone.
for all I know, all of you guys’ solutions might have worked, its just maybe my clock is messed up
Sounds like it!
What OS is HA installed on? Raspberry Pi? Raspbian? Does that report the correct local time?
What time zone is configured in HA…
This will suck if this is what has stopped the system working lol!
gekim.84
(Gekim84)
March 8, 2019, 12:20am
43
I’m on HA 0.88.1 on Docker in Synology.
my container environment settings seem correct tho:
gekim.84
(Gekim84)
March 8, 2019, 12:25am
44
I’ve already modified my homeassistant time_zone in my config yaml
restarted HA and check the home-assistant.log file
Its still seeing a different time than my clock:
what about the host o/s? can you ssh into that? (I can on my synology)
123
(Taras)
March 8, 2019, 12:36am
46
They work but, as I’ve documented in a previous post, not the way you expect (even when your clock issues get sorted out). Your original automation still won’t shut off the lights if they were turned on before 22:30.
Anyway, first things first; get the clock problem resolved. You’re not alone; I’ve read about this problem in other posts. Unfortunately, I can’t find them now.
gekim.84
(Gekim84)
March 8, 2019, 12:37am
47
well i can log in to the settings, the regional time is correct. I can try to SSH when I get home, but what do I type to retrieve the info that i need once I SSH’d?
123
(Taras)
March 8, 2019, 12:38am
48
For starters, type date
My box replies:
Thu Mar 7 19:38:23 EST 2019
Ooops! You’re running on a Synology box.
Maybe this? Synology Time
Might need to google that…
But can you post the top section of your configuration.yaml?
gekim.84
(Gekim84)
March 8, 2019, 12:42am
50
i literally just type “date” after I SSH to my synology?
123
(Taras)
March 8, 2019, 12:43am
51
Maybe … I forgot you weren’t running on a vanilla Linux box.
gekim.84
(Gekim84)
52
Here you go, I posted it above:
[image]
[image]
I can still ssh into mine… should still work…
gekim.84
(Gekim84)
March 8, 2019, 1:30am
54
@DavidFW1960 what do you type in to retrieve the necessary info after SSH log in? I’m using putty to log in my Synology
gekim.84
(Gekim84)
March 8, 2019, 2:38am
56
just ssh to synology, seems like the date is correct to what is the current time in my area.
gekim.84
(Gekim84)
March 8, 2019, 2:46am
57
I fixed the date!!!
in the environments tab in the docker container my TZ was: America/Los Angeles
it was missing an underscore, should have been: America/Los_Angeles from the very beginning
pqpxd
February 12, 2020, 5:10pm
60
Hey there!
Sorry it’s a late reply but I really like your card setup! Don’t suppose you’re able to share the config on how you created this?
