Iadded the Aqara Cube controller via ZHA, and then pulled down the blueprint for it from here. I got a couple of the automations from it running via the automation ui, and then it suddenly showed as “greyed out” / disabled, and there is a slash through the edit icon on the right.
I tried removing the automation from automations.yml, but the item still shows in the UI. I have removed the blueprint as well, and rebooted several times, and still it shows.
- What would cause the automation to become like this to start with?
- How do I remove it from the UI?
Thanks in advance,
