Automation not working can you give me some help?
hello, i’m a begginer with HA, i make some automation who’s work but this one doesn’t want to work.
can you help me ?
  • alias: ‘OuvertureDadou’
    - platform: state
      entity_id: binary_sensor.fibaro_system_fgms001_motion_sensor_sensor
      to: 'on'
    condition:
      condition: and
      conditions:
       - condition: state
         entity_id: cover.fibaro_system_fgrm222_roller_shutter_controller_2_level_5
         state: close
       - condition: state
         state: 'On'
       - condition: time
         after: '05:00:00'
         before: '07:30:00'
    • service: cover.set_cover_position
      position: 30
thanks for your help
You have the same entity in the trigger and the condition… If the trigger is validated this means that the entity binary_sensor.fibaro_system_fgms001_motion_sensor_sensor is “on”. Try to remove it in the condition and adapt the identation as follow (I made some changes, remove quotes in alias, added quotes in state: ‘close’… :
- alias: ouverturedadou
    - platform: state
      to: 'on'
  condition:
     condition: and
     conditions:
       - condition: state
         state: 'close'
       - condition: time
         after: '05:00:00'
         before: '07:30:00'
     - service: cover.set_cover_position
          position: 30
thanks for your help, i past this on my config i will test tomorow :smiley:
Please also read this and format your code correctly. Please be informed that on and off are normally lowercase, you can see the actual state if you go to Developer Tools -> States. Are you sure that the state of cover.fibaro_system_fgrm222_roller_shutter_controller_2_level_5is close and not closed, off or something else?
