Just trying to read meteo conditions based on a post I read. I try to read the ID provided there but these doesn’t seems to trigger. Below my code. I say over 4 the weather is bad and I turn on boolean.
Bad approach?
What that says is that when weather.homecr changes from a state of 5 to a state of 50 to trigger the automation. That’s not what you described though, you described a numeric state trigger like:
Thanks for your help: I thought it was something like “between”. Sorry, I’m from the “if then else” generation, just migrated from my Vera (luup) so I have to learn/adapt myself to HA syntax, totally new to me.
And what would be the syntax just to track “Rainy” condition? Something like
