Hello folks - seasons greetings!
I am having the most trouble getting some automations set up for my Zwave immersion heater controller (Horstmann SIR321). To all instents and purposes, it is a relay/switch so the only thing that can be done with its entity is Turn on/Turn off.
Background
I have most of the basic building blocks working but there are some niggles that I am struggling to debug. Most of what is working has been copy and pasted from the cookbook/the forum.
My primary goals for the water heater and HA are as follows:
- Have a button in Lovelace which when pressed puts the water heater on for 1 hour
- Trigger the water heater to come on for one hour at a different time each day of the week (also from Lovelace)
This screenshot shows what the front end looks like:
The code for the cards looks like this:
- badges: []
cards:
- entities:
- switch.horstmann_secure_meters_sir321_rf_countdown_timer_switch
show_header_toggle: false
title: Immersion Heater Status
type: entities
- entity: automation.hot_water_on_one_hour
hold_action:
action: none
icon: 'mdi:thermometer-lines'
name: Boost hot water for 1 hour
show_icon: true
show_name: true
tap_action:
action: call-service
service: automation.trigger
type: entity-button
- entities:
- entity: input_datetime.hws_mo
- entity: input_datetime.hws_tu
- entity: input_datetime.hws_we
- entity: input_datetime.hws_th
- entity: input_datetime.hws_fr
- entity: input_datetime.hws_sa
- entity: input_datetime.hws_su
title: Water heater schedule
type: entities
path: hot-water
title: Hot Water
At the back end I have the following automations:
Hot Water On - One Hour
Turns the heater on
[Send a notification to my phone for debugging]
Delays for an hour
Turns it off -
Hot water - Monday
Use a template, a time sensor and input entitiy to evaluate the current time
Check a condition to see if it is the right day of the week
Trigger the Hot Water On - One Hour automation
Once this is working, it is my intention to have further automations which cover the other days of the week
Automations.yaml looks like this:
- id: '1571092941517'
alias: Hot Water On - One Hour
description: Switches the water on for 1 hour at any time
trigger: []
condition: []
- device_id: 75fb2ec189524b3c81012dde9cbe066c
domain: switch
entity_id: switch.horstmann_secure_meters_sir321_rf_countdown_timer_switch
type: turn_on
- data:
message: automation triggered - Hot Water On - One Hour
service: notify.notify
- delay: 01:00:00
domain: switch
type: turn_off
- id: '1577119893046'
alias: 'DEBUG: Hot water switch on'
description: ''
domain: switch
platform: device
type: turned_on
condition: []
- data:
message: water heater on
service: system_log.write
- id: '1577120792510'
alias: 'DEBUG: Hot water switch off'
description: ''
domain: switch
platform: device
type: turned_off
condition: []
- data:
message: water heater off
- id: '1577124991290'
alias: Hot water - Monday
description: Monday day condition is in config.yaml you can't see it here
value_template: '{{ states(''sensor.time'') == (states.input_datetime.hws_mo.attributes.tim>
| int | timestamp_custom(''%H:%M'', False)) }}'
condition:
- after: 00:00:01
before: '23:59:59'
condition: time
weekday:
- mon
- data:
entity_id: automation.hot_water_on_one_hour
- data:
message: Monday automation triggered
For debugging I have two extra automations that write to the log what the switch is doing.
All automations have been tested in isolation, if they are triggered by clicking the ‘Trigger’ button in the (i) card for each automation they work properly:
For reference this is my configurations.yaml file:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: !secret
longitude: !secret
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/London
# Customization file
customize: !include customize.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Discover some devices automatically
discovery:
# Sensors
- platform: time_date
display_options:
- 'time'
- 'date'
- 'date_time'
- 'time_date'
- 'time_utc'
- 'beat'
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
#Entity Variables
#Hot water timer inputs
input_datetime:
hws_mo:
name: Set time for water heater (Monday)
has_date: false
has_time: true
hws_tu:
name: Set time for water heater (Tuesday)
has_date: false
has_time: true
hws_we:
name: Set time for water heater (Wednesday)
has_date: false
has_time: true
hws_th:
name: Set time for water heater (Thursday)
has_date: false
has_time: true
hws_fr:
name: Set time for water heater (Friday)
has_date: false
has_time: true
hws_sa:
name: Set time for water heater (Saturday)
has_date: false
has_time: true
hws_su:
name: Set time for water heater (Sunday)
has_date: false
has_time: true
- Hot Water On - One Hour - expected behaviour: water switch goes on, notification arrives to phone, water goes off after one hour
- Hot water - Monday - expected behaviour: water switch goes on, notification arrives to phone, water switch goes on, second notification arrives to phone from nested automation trigger, water goes off after time delay
I am aware that triggering in this way ignores conditions. The time based automation has also been tested and fires at the right time if the day is correct.
For reference I am running HA inside a docker container. Docker is running on Unbuntu 18 on an NUC, I got it up and running using this tutorial: Absolute Beginners guide to installing HA on Intel NUC using Docker and since then have added samba and git to the docker container where HA runs. I’m not sure if further details are relevant, please let me know if they might be useful.
The system is running Home Assistant 0.100.1
Frontend version: 20191002.2 - latest
System Health
arch | x86_64 |
dev | false |
docker | true |
hassio | false |
os_name | Linux |
python_version | 3.7.4 |
timezone | Europe/London |
version | 0.100.1 |
virtualenv | false |
Lovelace
mode | storage |
resources | 0 |
views | 3 |
Issues
In practice, however, things are not so good. I currently have the following issues with my set up:
When pressing the ‘Boost hot water for 1 hour’ button in lovelace behaviour is inconsistent.
—Pressing the button causes the ‘Monday’ automation to fire, a ‘Monday’ notification arrives to my phone
------It would seem that the button is mapped to the wrong trigger but it isn’t
—Sometimes, the water switch does toggle over and sometimes it doesn’t
—When the switch does activate from this button press, three notifications arrive to my phone, one for ‘Monday’ and two for ‘one hour boost’ (I presume this is one from the actual entity call and one from the nested call inside the monday automation). -
When the ‘Monday’ automation is triggered by the correct date and time, sometimes it calls the ‘one hour boost’ automation trigger and sometimes it doesn’t.
Three notifications from one button press:
More simply:
- The entity card in lovelace seems to be calling the wrong automation
- The time based automation intermittently doesn’t call the 1 hour automation in its action
All of which results in some early morning cold showers that are pretty unpleasant!
Questions
All this in mind, I would really appreciate some pointers on the following things:
- Is there something wrong with my set up that I have missed?
- What might be causing the intermittent behaviour of automation making them unreliable?
- How do you go about debugging something like this, the logs and so on have no shown me anything that I can use to progress
- Would it be better to just have on-delay-off actions in each of my day-of-the-week automation, instead of calling another automation trigger (this feels like duplicating code but maybe that’s ok in this instance)
Any tips much appreciated!
Many thanks and warm regards,
D
