Automation wont trigger. conditions maybe wrong
I did post this on Discord, but received no response, so allow me to ask again here:
 - alias: Reload Trafdri integration
    id: Reload Trafdri integration
      - platform: event
        event_type: system_log_event
        event_data:
          level: WARNING
      - platform: event
        event_data:
          level: ERROR
    condition:
      condition: or
      conditions:
          {{'[homeassistant.components.tradfri.base_class] Observation failed for'
            in trigger.event.data.message}}
          {{'[homeassistant.components.tradfri] Keep-alive failed'
          {{'Error received in UDP connection under DTLS' in trigger.event.data.message}}
      - service: script.reload_tradfri_integration
      - service: system_log.write
          message: >
            Ikea integration was reloaded because of {{trigger.id}} with message:
            {{trigger.event.data.message}}
          level: warning
          logger: homeassistant.components.tradfri
us supposed to catch Error and Warning message in the homeassistant log, and take actions as describe.
I can confirm those phrases do occur and for the third or-condition left out the trigger-id to make it pass more easily…
however, even though these triggers have happened, the action has not fired yet. Could it be the condition to find the selected phrase is incorrect?
please have a look for me? thanks
Have you checked the trace for that automation? That should tell you which step it is failing on, so you can make sure the conditions are working as expected.
Let’s assume the problem is in the condition and you correct it. Now the automation will trigger whenever there’s an a system_log_event, of level WARNING or ERROR, and will record it to the system log using the system_log.write service.
Running that service will produce a system_log_event which will re-trigger the automation. What it wrote to the log contains the phrase that condition looks for (including a level of WARNING) so it will proceed to execute its action. In other words, won’t the first trigger start an endless loop?
hmm, that might be a correct assumption, but, it is easily mitigated by changing the service…
          message: >
          level: warning
or something simple
i was wondering about the condition, because elsewhere I found a reference to trigger.event.data.message[0] and that made me think the condition might be incorrect, even though I dont yet see what the [0] would do in my specific situation
Based on what I have seen, message contains a list.
Then you agree it would become an endless loop unless corrected.
FWIW, I mention this only because I fell into the same trap and created a similar endless loop. Fortunately it was creating persistent notifications so I immediately detected the problem because it was highly visible (about a hundred notifications produced within seconds of the first trigger).
so, here this happens:
2021-11-16 16:37:50 WARNING (MainThread) [coap] Error received in UDP connection under DTLS: [Errno 111] Connection refused
and the automation didnt trigger.
and yes, so it was the [0] after all…
I tested in the dev tools services
and see what persistent notification was created:
in the homeassistant log:
2021-11-16 16:52:41 WARNING (MainThread) [homeassistant.components.tradfri] Ikea integration was reloaded because of observation
Yup, because message contains a list (as shown in the linked post). Not sure why it’s a list (when do multiple errors/warnings occur in the same message?) but there it is.
now that I have your brains for a second:
we cant set a variable before the conditions can we?
      - variables:
          data: >
            {{trigger.event.data.message[0]}}
so I can use
{{'[homeassistant.components.tradfri.base_class] Observation failed for' in data}}
probably can move the conditions to the action, but in this case I dont think I want to do that
I think it works if you set variables at the top of the automation where they should be updated immediately after a trigger fires (i.e. just before the condition is evaluated).
    variables:
      msg0: '{{trigger.event.data.message[0]}}'
     ... etc ...
BTW, Ikea called and asked why are you calling their product Trafdri. :wink:
Hahaha hadn’t noticed :wink:
Thanks , I’ll change that….
have some more details, and maybe I need to change the template. what happened:
Logger: coap
Source: /usr/local/lib/python3.9/site-packages/aiocoap/transports/tinydtls.py:280
First occurred: 08:29:58 (2 occurrences)
Last logged: 08:29:59
was logged and the automation kicked in showing me the notification:
which is very nice. However, as you can see there is much more detail in the log more-info, which I also like to have in my notification. Based on the {{trigger.event.data.message[0]}} I now use in the automation, would another template be able to show me these other details, especially Logger and Source? maybe I need to check a full {{trigger.event.data}} to see what’s available…
note btw the odd mixup in trigger id which is reported to be ‘observation’, and origins a Warning level, while this was an Error, and should have logged id ‘failed’…
update
this is what happens:
Full data: {'name': 'coap', 'message': ['Error received in UDP connection under DTLS: [Errno 111] Connection refused'], 'level': 'WARNING', 'source': ('/usr/local/lib/python3.9/site-packages/aiocoap/transports/tinydtls.py', 280), 'timestamp': 1637155664.0627038, 'exception': '', 'count': 1, 'first_occurred': 1637155664.0627038}
testing:
      - service: persistent_notification.create
          title: >
            {{trigger.event.data.level}}: Tradfri reloaded
          message: >
            {{now().timestamp()|timestamp_custom('%X')}}: Ikea Tradfri integration was
              reloaded because of {{trigger.id}}:
              Message: {{trigger.event.data.message[0]}},
              Logger: {{trigger.event.data.name}},
              Source: {{trigger.event.data.source}},
              Level: {{trigger.event.data.level}},
              Full data: {{trigger.event.data}}
for now
need some extra assistance please, somehow the condition wont pass while triggering in
2022-01-13 10:34:34 ERROR (MainThread) [custom_components.tahoma] Authentication failed while fetching device events data: Bad credentials
in:
  - alias: Reload Tahoma integration
    id: Reload Tahoma integration
    mode: restart
      - platform: event
        event_data:
          level: ERROR
    condition:
        {{'[custom_components.tahoma] Authentication failed while fetching device events data: Bad credentials'
          in trigger.event.data.message[0]}}
and it seems the parser doesn’t see the whole string as string:
and
‘events data’ is colored as a reserved field. Or would that be mere optics and do I need to change something else in the condition.
testing the string in template editor:
{% set error =     '[custom_components.tahoma] Authentication failed while fetching device events data: Bad credentials'%}
{{error}}
returns alright, the full string, including [] and :
why are you splitting the line? That adds a carriage return.
I dont, that’s the automation tracer. this is what I have:
    condition:
is message a list or a string?
according to Taras, and what we found out below that, it is a list Automation wont trigger. conditions maybe wrong - #5 by 123
Its a bit hard to test, because the error can not be forced…
this is where its created ha-tahoma/coordinator.py at 8c2491c06fe97ed3db9220e18c87e5cc6380eca3 · iMicknl/ha-tahoma · GitHub
if it’s a list, the error has to match exactly for in to work, unlike the string interpolation where it just needs to contain a fraction of the error.
yes, I copied the full string from the error, so it should be ok in that regard.
Ive just reloaded the automation without the [0], to see if it still triggers and passes. Can only wait now…
well, that’s assuming it doesn’t have carriage returns or hidden whitespace
