Automations copied works while original does not
Hi, I have 112 Automation rules ; 110 are DeConz-related.
Last week, DeConz gave me an error. After reconnecting de Conbee II, it looks like the IP-address of DeConz has changed. So I had to remove the old Hub and add the new Hub (all the devices paired with DeConz have the same name AND device-id !).
But none of the automations work !!!
To make them work, there is a simple bypass : open an automation, copy the name, duplicate the automation, save the new with the copied name (paste), exit the new one, exit the old one and delete the old one. But doing this 110 times… that’s asking for problems !
Strange thing… If I keep the old automation and I go into automations.yaml, the complete yaml for these two automations are exactly the same (except for the ‘id:’-number).
How can I make the old automations working without supidly copy-pasting them all one-by-one ?
Are you absolutely sure about this part?
What does a trace say on one of the ‘bad’ ones.
Also I assume you’re using devices in your automations - good time to edit them alm to use entity id’s instead (if the entity ID od the same it survives reinstalling or swithching integrations)
I’m more than sure !
  • id: ‘1711908841585’
    alias: LivInk-b-2k EetZ 0%
    description: ‘’
    • device_id: 5b6a62cc034932ea244f3cc961006dee
      domain: deconz
      platform: device
      type: remote_button_short_release
      subtype: button_2
      condition:
    • service: light.turn_off
      entity_id:
      • light.eethoek_zone
        transition: 1
        mode: single
  • id: ‘1712166735318’
    description: ‘2424’
      domain: deconz
      platform: device
      subtype: button_2
      condition:
      entity_id:
        transition: 1
        mode: single
        The first does NOT work ; the second (which is a copy of the first and to identify I added ‘2424’ to the description).
I found something else (which a normal living being should not check) in core.entity-registry :
“aliases”: ,
“area_id”: null,
“capabilities”: {
“id”: “1711908841585”
“config_entry_id”: null,
“device_class”: null,
“device_id”: null,
“disabled_by”: null,
“entity_category”: null,
“entity_id”: “automation.livink_b_2k_eetz_0_2”,
“hidden_by”: null,
“icon”: null,
“id”: “1d476f71e3ffbd7f16e07c0f6b61dd5e”,
“has_entity_name”: false,
“labels”: ,
“name”: null,
“options”: {
“cloud.google_assistant”: {
“should_expose”: false
“cloud.alexa”: {
“conversation”: {
“original_device_class”: null,
“original_icon”: null,
“original_name”: “LivInk-b-2k EetZ 0%”,
“platform”: “automation”,
“supported_features”: 0,
“translation_key”: null,
“unique_id”: “1711908841585”,
“previous_unique_id”: null,
“unit_of_measurement”: null
and
“aliases”: ,
“area_id”: null,
“capabilities”: {
“id”: “1712166735318”
“device_id”: null,
“entity_id”: “automation.livink_b_2k_eetz_0”,
“hidden_by”: null,
“icon”: null,
“id”: “7af9c41cca2d201c2d7bceb1c7731d67”,
“labels”: ,
“name”: null,
“options”: {
“cloud.alexa”: {
“conversation”: {
“unique_id”: “1712166735318”,
and
** “config_entry_id”: null,**
** “entity_id”: “automation.livink_b_2k_eetz_0”,**
** “id”: “52eaafa46d07cf3545fbcff70a8a93c5”,**
** “orphaned_timestamp”: 1711908891.5437758,**
** “platform”: “automation”,**
** “unique_id”: “1711652846244”**
The yaml before copy-paste :
alias: LivInk-b-3k ZitZ 100%
description: “”
    domain: deconz
    platform: device
    subtype: button_3
    condition:
  • service: light.turn_on
    entity_id:
    - light.zithoek_zone
    color_temp: 350
    brightness_pct: 100
    mode: single
the result in LOG
the YAML after copy-paste-deleteold :
description: “2424”
    domain: deconz
    platform: device
    subtype: button_3
    condition:
    entity_id:
    color_temp: 350
    brightness_pct: 100
    mode: single
and its log now :
(with extra attention at the automatisation that starts)
and it keeps being stranger… I just renamed the automatisation. After saving, the automatisations works again !
(so I have to rename my 110 automations to make them work).
Please format the automations using the preformatted text function when you paste so we can maintain spaces etc. It’s important in YAML.
Sounds like something got jacked up i the save and. You know the workaround. But id still STRONGLY suggest you over time change out your device references to entity id’s to prevent this kind of issue in the future.
