I upgraded the HA core to version 2022.2.3. Prior to this I was running HA Core version 2022.2.2. At the same time I updated the Core, I also updated to OS 7.3. Following the upgrade I was unable to enable or edit any of the automations listed under the Automations tab. A peak in the logs reveals;
2022-02-07 14:03:33 ERROR (MainThread) [homeassistant.setup] Error during setup of component automation
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 135, in async_get_device_automation_platform
integration = await async_get_integration_with_requirements(hass, domain)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 56, in async_get_integration_with_requirements
integration = await async_get_integration(hass, domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 614, in async_get_integration
integration = await _async_get_integration(hass, domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 642, in _async_get_integration
raise IntegrationNotFound(domain)
homeassistant.loader.IntegrationNotFound: Integration '' not found.
File "/usr/src/homeassistant/homeassistant/setup.py", line 227, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 232, in async_setup
if not await _async_process_config(hass, config, component):
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 637, in _async_process_config
await async_validate_config_item(hass, raw_config),
File "/usr/src/homeassistant/homeassistant/components/automation/config.py", line 83, in async_validate_config_item
config[CONF_ACTION] = await script.async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 232, in async_validate_actions_config
return await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 280, in async_validate_action_config
config[CONF_DEFAULT] = await async_validate_actions_config(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 247, in async_validate_action_config
platform = await device_automation.async_get_device_automation_platform(
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 138, in async_get_device_automation_platform
raise InvalidDeviceAutomationConfig(
homeassistant.components.device_automation.exceptions.InvalidDeviceAutomationConfig: Integration '' not found
2022-02-07 14:03:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: automation
2022-02-07 14:03:35 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: (DependencyError(...), 'Could not setup dependencies: automation')
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
2022-02-07 14:17:39 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /host/reboot request Server disconnected
2022-02-07 14:17:39 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /host/reboot -
I did a backup prior to updating the Core and was able to recover HA 2022.2.2. Once restored, a hardware reboot was performed and the update tried again. This time it worked without issue. I’m now running a fully updated system.
Question is, what caused the issue and and how can I avoid such in future upgrades.
