Hello
For some reason one of my light automations has stopped working
several lights both zigbee and lightwaverf dont come on when say the sun sets but when I go into the automation and run the individual automation to turn the light on it works, anyone else have this issue
Thanks for the reply, sorry but I deleted the Automation and set each lamp up with its own to see if I can isolate, if that doesnt work (i’ll know tomorrow night) I’ll setup up again and try to recreate then post , but thank you
Ok so the 4 lights that are not turning off\on with an automation are no on individual automations 3 of them did not turn off last night at 23:30 like they were supposed to
1 set of lights are controlled by a frient plug and that worked the other 3 are all Innr bulbs here is the yaml for one of them
alias: Lights Monster Lamp 1 Off
description: “”
I do not know what that square is, but if it is in a condition, then HA will read it as something that needs to be true for it to trigger and if it is just a square, then only a developer will know how it reacts to that.
And please post your automation with the proper formatting.
This might be an issue of a bad indentation and we can not see the indentations without that formatting.
So I tried to add 2 Innr lights that had stopped responding and they could not befound so I decided to buy a new sonoff zigbee stick E ie latest one flashed the firmware and rebuilt my network, Innr bulbs connected straight away but the auomation below does not trigger the garden lights for some reason, could you take a look and tell me what I have done wrong please
