elkropac
(Libor_K)
December 1, 2019, 12:15pm
1
HI, i bought this smart plug, used tuya convert to flash it, then i started to map pins. In process i managed to brick it. See (there are photos of inside)
https://www.aliexpress.com/item/32968895032.html
When searching for flash instructions, i found out, it’s probably this one
I have succesfuly flashed it using tuya-convert with tasmota. I played with several templates, could not find the right one. I decided to swtich to esphome for debuging.
This is my latest config
substitutions:
dev_name: avatto_plug_rgbw_001
esphome:
platform: ESP8266
board: esp01_1m
wifi:
# Enable logging
l…
I dismantled it now i have access to pins on little board with esp chip.
It seems to be this one
https://fccid.io/2AKBPESP8266-S3/User-Manual/User-Manual-3594791.html
Alternative firmware for ESP8266 and ESP32 based devices with easy configuration using webUI, OTA updates, automation using timers or rules, expandability and entirely local control over MQTT, HTTP...
But when connecting to pins 13 and 14, my usb flash device does not work.
ESP board is in top-right corner
Any clues?
thanks
Libor
