AWTRIX 3 - Blueprint for creating simple apps for dummies
first thanks for the amazing Component and blueprint.
is it possible to point to the user options in the additional conditions?
based on a result of a variable calculated inside of the automation i want to be able to publish the app or not.
e.g. if icon_template = “not found” i don’t want to publish the app
thanks in advance
show or remove app automatically only via Additional conditions
example
One question,
does anyone know if it is possible to stop an application (for example, which lasts 10 seconds) and start a new application immediately, when something happens. something like (“force”: true). I’m talking about home assistant and MQTT. I tried random things but it didn’t work.
Tx
use case please. Describe what you want to achieve.
btw, use switch for switch to another app.
action: awtrix.awtrix_bedroom_switch_app
in the configuration.yaml i must only add → awtrix:
unfortunately very little is explained here, almost only examples:
no. the latest ver do not need any changes in configuration.yaml. just add via UI
thank you after many many hours a full noob has ist becom it to run thank you.
The biggest problem wars to get installet HACS why they mad them so hard to do :slight_smile:
idk, HACS was created for easy installation / updating any HASS components (expecially for noobs)
:slight_smile:
Is there a way to make the icon stay on screen whilst the text scrolls?
Have you read the manual? Please do, there are all your answers.
Small hint, search for push Icon
Ahh I didn’t even know there was a manual, apologies and thanks! :slight_smile:
Just published a few flows.
BOM Australia Weather Report
https://flows.blueforcer.de/flow/PjqG5X8V5YNK
BOM
A/C Climate Control and Door Notification
https://flows.blueforcer.de/flow/np78OpdZOGKm
Door Open
Dry Mode
Heat Mode
Off Mode
Cool Mode
Will search, sorry, I just seen AWTRIX 3 and did not read the rest. Seemed like the only central place for AWTRIX Info. Created new topic AWTRIX 3 - NodeRED Flows
colors:
  "0": "#00ff7f"
  "5": "#00ff2a"
  "10": "#2aff00"
  "15": "#7fff00"
  "20": "#d4ff00"
  "25": "#ffd400"
  "30": "#ff7f00"
  "35": "#ff5f00"
  "-15": "#007fff"
  "-10": "#00d4ff"
  "-5": "#00ffd4"
value_template: "{{states(entity_id) | round}}"
duration: 5
pos: 3
color: |-
  {{user_data.colors[(colors.items() |
      map(attribute='0') |
      map('int') |
      sort | select('>=', value_template ) |
      first) | string]}}
Hi Oleg, Im probably to stupid to launch a notification :wink: I Imported the blueprint code in Automations. I created a Automation and fill up the fields, but when I start the automation i get a error Code. Unknown Aktion: awtrix.awtrix_xxxx_push_app_data . Did you know what happens? Best regards Thomas
hi Thomas, glad to see you.
Probably you should first setup custom_component
  1. HASC
  2. add repo
  3. GitHub - 10der/homeassistant-custom_components-awtrix: HASS awtrix
Hi Oleg, ok thank you. I installed the custom_conifg repo. What are the next steps. Which yaml must be edited with the File editor?, because when I set the automation the same error appear? Thanks a lot. Please explain all the steps again for a dummy user :wink:
before the next step be sure what all is ok.
open HASS
open Developer tools
http://homeassistant.local:8123/developer-tools/action
and test integration
action: awtrix.awtrix_bedroom_rtttl
  rtttl: two_short:d=4,o=5,b=100:16e6,16e6
After execute, you should hear “beep-beep”
