Some amazing work has been done by the Baby Buddy project and @jcgoette to build the Baby Buddy Home Assistant HACS Integration.
Purpose
This blueprint makes it easier to log Baby Buddy actions from Home Assistant
What can you do with it?
If you have a baby you know that some people say you should log a variety of activities like sleep times, diaper changes, etc. To see what Baby Buddy can do start at the project’s GitHub page: GitHub - babybuddy/babybuddy: A buddy to help caregivers track sleep, feedings, diaper changes, and tummy time to learn about and predict baby's needs without (as much) guess work.
To see what I did with it go to: Baby Buddy Dashboard & Blueprint
Pre-requisites
Baby Buddy project
– OR Baby Buddy addon Ingress is not currently working, see updates on Issue #2 - Baby Buddy Home Assistant HACS Integration built by @jcgoette
Home Assistant Companion app (iOS or Android)
–Used to receive notification when timer is running to allow quick logging access
This blueprint requires Helpers (You can use whatever name you want or use the below.)
- Input Button Button - Home Assistant
– BB Diaper Helper
– BB Feeding Helper
– BB Pumping Helper
– BB Sleep Helper
– BB Tummy Time Helper - Counter Counter - Home Assistant
– BB Diaper Counter
– BB Feeding Counter
– BB Pumping Counter - Input Text Input Text - Home Assistant
– BB Notes - Input Number Input Number - Home Assistant
– BB Amount
You should also create a new dashboard page. This will be used as the target page when you tap the timer notification.
blueprint:
author: noblewolf
description: "Notifications and control of Baby Buddy. Works with Baby Buddy https://github.com/jcgoette/baby_buddy_homeassistant \n\nThis blueprint requires Helpers (You can use whatever name you want or use the below.)
\n- Input Button https://www.home-assistant.io/integrations/button/
\n- - BB Diaper Helper
\n- - BB Feeding Helper
\n- - BB Pumping Helper
\n- - BB Sleep Helper
\n- - BB Tummy Time Helper
\n- Counter https://www.home-assistant.io/integrations/counter/
\n- - BB Diaper Counter
\n- - BB Feeding Counter
\n- - BB Pumping Counter
\n- Input Text https://www.home-assistant.io/integrations/input_text/
\n- - BB Notes
\n- Input Number https://www.home-assistant.io/integrations/input_number/
\n- - BB Amount
domain: automation
input:
bb_child:
name: Baby Buddy Child
description: Choose one child per automation.
selector:
entity:
domain: sensor
device_class: babybuddy_child
bb_child_last_timer:
name: Baby Buddy Child Last Timer
description: Timer created by Baby Buddy integration. Choose the same timer as the child name.
selector:
entity:
domain: sensor
device_class: timestamp
notification_group:
name: Notification or Notification Group
description: Device or notify group to notify of timer starting. Blueprint sends a notification each time a timer start. For example notify.josh_s_phone or notify.all_phones
diaper_button:
description: Helper (button type) to trigger diaper log. Use this button in your UI to log a diaper change.
selector:
entity:
domain: input_button
feeding_button:
description: Helper (button type) to trigger feeding log. Use this button in your UI to log a feeding long.
selector:
entity:
pumping_button:
description: Helper (button type) to trigger pumping log. Use this button in your UI to log a pumping session.
selector:
entity:
tummy_time_button:
name: Tummy Timer Button
description: Helper (button type) to trigger tummy time log. Use this button in your UI to log tummy time.
selector:
entity:
sleep_button:
name: Helper to trigger sleep log.
description: Helper (button type) to trigger sleep log. Use this button in your UI to log a sleep session.
selector:
entity:
bb_timer:
name: Baby Buddy Timer
description: The timer created by Baby Buddy. Usually named switch.firstName_lastName_timer For example switch.lindsay_smith_timer
selector:
entity:
domain: switch
diaper_counter:
name: Diaper Change Counter
description: Helper you created to count diaper changes. Resets at midnight.
selector:
entity:
domain: counter
feeding_counter:
description: Helper you created to count feeing sessions. Resets at midnight.
selector:
entity:
domain: counter
pumping_counter:
description: Helper you created to count pumping sessions. Resets at midnight.
selector:
entity:
domain: counter
bb_notes:
description: Shared notes field for diaper change or feeding notes.
selector:
entity:
domain: input_text
bb_amount:
description: Shared amount field for diaper changes and feedings.
selector:
entity:
domain: input_number
bb_ui_url:
name: Link to Baby Buddy tab in your dashboard.
description: Link to a dashboard page that has your Baby Buddy controls. For example /lovelace/baby-buddy Used as the tap action in the timer notificaiton to allow quick access.
- platform: state
entity_id: !input diaper_button
- platform: state
entity_id: !input feeding_button
- platform: state
entity_id: !input pumping_button
- platform: state
entity_id: !input tummy_time_button
- platform: state
entity_id: !input sleep_button
- platform: time
at: "00:00:00"
- platform: state
entity_id: !input bb_timer
to: "on"
- platform: state
to: "off"
variables:
_bb_amount: !input bb_amount
_bb_notes: !input bb_notes
_bb_child_last_timer: !input bb_child_last_timer
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- service: babybuddy.add_diaper_change
type: "{{ states('select.baby_buddy_diaper_type') }}"
color: "{{ states('select.baby_buddy_diaper_color') }}"
notes: "{{ states(_bb_notes) }}"
entity_id: !input bb_child
- service: input_text.set_value
value: ""
entity_id: !input bb_notes
- service: counter.increment
data: {}
entity_id: !input diaper_counter
- conditions:
sequence:
- choose:
- conditions:
- condition: template
value_template: "{{ state_attr(_bb_child_last_timer, 'active') }}"
sequence:
- service: babybuddy.add_feeding
timer: true
type: "{{ states('select.baby_buddy_feeding_type') }}"
method: "{{ states('select.baby_buddy_feeding_method') }}"
amount: "{{ states(_bb_amount) }}"
default:
value: ""
- service: input_number.set_value
value: 0
entity_id: !input bb_amount
data: {}
entity_id: !input feeding_counter
- conditions:
sequence:
- service: babybuddy.add_pumping
amount: '{{ states(_bb_amount) }}'
notes: '{{ states(_bb_notes) }}'
data: {}
entity_id: !input pumping_counter
value: ""
value: 0
- conditions:
sequence:
- service: babybuddy.add_tummy_time
timer: true
- conditions:
sequence:
- service: babybuddy.add_sleep
timer: true
- conditions:
sequence:
- service: counter.reset
data: {}
entity_id:
- !input diaper_counter
- !input feeding_counter
- !input pumping_counter
- conditions:
sequence:
- service: !input notification_group
title: ⏳️ Baby Buddy Timer Running
message: Tap to open Baby Buddy to log timer.
group: baby-buddy-timer
clickAction: !input bb_ui_url
url: !input bb_ui_url
persistent: true
tag: baby-buddy-timer
- conditions:
sequence:
message: clear_notification
mode: parallel
max: 10
Change Log
2022-11-12
Initial Commit
