Baby Buddy Dashboard & Blueprint
This may not be necessary for you!
Now that Ingress is fixed in the Baby Buddy add-on, creating a custom UI like this in an HA Dashboard may be superfluous. Once you install the add-on you have the option to “Show in sidebar”. This will allow you to access Baby Buddy within the HA Companion app and not use a VPN.
Intro
I recent installed Baby Buddy and Baby Buddy HACS Integration and wanted to share the setup I built with it inspired by @OCT0PUSCRIME work here [WIP] Baby Buddy Integration Frontend
For this I built the Blueprint Baby Buddy Log: Tummy Time, Sleep, Feeding, Diaper Change, Pumping
My Dashboard
Using standard UI cards and subviews I built a basic Baby Buddy UI in Home Assistant. I did this because I’m hosting Baby Buddy at home and did not want to make it directly available to the internet and also wanted to be able to control Baby Buddy with a Zigbee remote and Alexa.
Feeding:
type: entities
entities:
  - entity: select.baby_buddy_feeding_method
  - entity: select.baby_buddy_feeding_type
  - entity: input_number.bb_amount
  - entity: input_text.bb_notes
footer:
  type: buttons
  entities:
    - entity: input_button.bb_feeding_helper
      name: Open Baby Buddy
      tap_action:
        action: url
        url_path: http:/IPADDRESS:8000/feedings/
      name: Log This Feeding
title: Feeding
Diaper:
type: entities
entities:
  - entity: select.baby_buddy_diaper_type
  - entity: select.baby_buddy_diaper_color
footer:
  type: buttons
  entities:
      tap_action:
        action: url
        url_path: http://IPADDRESS:8000/changes/
    - entity: input_button.bb_diaper_helper
      name: Log a Diaper Change
title: Diaper
show_header_toggle: false
Pumping:
type: entities
entities:
footer:
  type: buttons
  entities:
    - entity: input_button.bb_pumping_helper
      tap_action:
        action: url
        url_path: http://IPADDRESS:8000/pumping/
      name: Log This Pumping
title: Pumping
state_color: false
The YAML
I’m not sure who could easily read this but here is my YAML of those dashboard pages:
  - theme: Backend-selected
    title: Baby Buddy
    path: baby-buddy
    icon: mdi:baby
    type: custom:vertical-layout
    badges: []
    cards:
      - type: horizontal-stack
        cards:
          - color: teal
            type: tile
            entity: input_boolean.home_occupied
            icon: mdi:home
            tap_action:
              action: navigate
              navigation_path: /lovelace/
            icon_tap_action:
              action: navigate
            show_entity_picture: false
          - color: pink
            type: tile
            icon: mdi:baby-face
            tap_action:
              action: url
              url_path: http://IP_ADDRESS:8000/
            icon_tap_action:
              action: url
        cards:
          - show_name: true
            show_icon: true
            type: button
            entity: switch.firstName_lastName_timer
            icon_height: 30px
            show_state: false
            tap_action:
              action: toggle
          - show_name: true
            show_icon: true
            type: button
            icon: mdi:baby
            name: End Tummy Time
            icon_height: 30px
            entity: input_button.bb_tummy_time_helper
            tap_action:
              action: toggle
          - show_name: true
            show_icon: true
            type: button
            icon: mdi:sleep-off
            name: End Sleep Time
            icon_height: 30px
            entity: input_button.bb_sleep_helper
            tap_action:
              action: toggle
          - show_name: true
            show_icon: true
            type: button
            tap_action:
              action: navigate
              navigation_path: /lovelace/baby-buddy-feeding
            entity: sensor.firstName_lastName_last_timer
            show_state: false
            hold_action:
              action: navigate
        cards:
          - type: tile
            tap_action:
              action: navigate
              navigation_path: /lovelace/baby-buddy-diaper
            icon_tap_action:
              action: navigate
            icon: mdi:human-baby-changing-table
            entity: sensor.firstName_lastName_last_change
          - type: tile
            entity: sensor.firstName_lastName_last_pumping
            tap_action:
              action: navigate
              navigation_path: /lovelace/pumping
            icon_tap_action:
              action: navigate
      - type: entities
        entities:
          - type: section
            label: Feeding
          - entity: counter.bb_feeding_count
          - type: attribute
            entity: sensor.firstName_lastName_last_feeding
            attribute: end
          - entity: sensor.firstName_lastName_last_feeding
          - type: attribute
            attribute: method
          - type: attribute
            attribute: duration
          - type: section
            label: Pumping
          - entity: counter.bb_pumping_counter
          - entity: sensor.firstName_lastName_last_pumping
            name: Last Volume pumped
          - type: attribute
            attribute: time
          - type: section
            label: Diapers
          - entity: counter.bb_diaper_count
          - entity: sensor.firstName_lastName_last_change
            name: Last change was
          - type: section
            label: Tummy Time
          - entity: sensor.firstName_lastName_last_tummy_time
            name: Last tummy-time duration
          - type: attribute
            name: Last time was
            attribute: end
      - type: history-graph
        entities:
          - entity: sensor.firstName_lastName_last_sleep
        hours_to_show: 24
    title: Baby Buddy Feeding
    path: baby-buddy-feeding
    icon: mdi:mother-nurse
    subview: true
    type: panel
    badges: []
    cards:
      - type: entities
        entities:
        footer:
          type: buttons
          entities:
              tap_action:
                action: url
                url_path: http://IP_ADDRESS:8000/feedings/
        title: Feeding
    subview: true
    title: Baby Buddy Diaper
    path: baby-buddy-diaper
    icon: mdi:emoticon-poop
    type: panel
    badges: []
    cards:
      - type: entities
        entities:
        footer:
          type: buttons
          entities:
              tap_action:
                action: url
                url_path: http://IP_ADDRESS:8000/changes/
        title: Diaper
    subview: true
    title: Pumping
    path: pumping
    icon: mdi:pumpkin
    type: panel
    badges: []
    cards:
      - type: entities
        entities:
        footer:
          type: buttons
          entities:
              tap_action:
                action: url
                url_path: http://IP_ADDRESS:8000/pumping/
        title: Pumping
        state_color: false
Post Baby Update…
So we had our baby last week and so far my wife is preferring using the Baby Buddy directly. Using it directly you can watch the timer run full screen which she likes will feeding/pumping.
You can make use easier by setting it up on your phones as a web app:
iOS: How to Install Web Apps on iPhone or iPad: 6 Steps (with Pictures)
Android: How to Add a Website Shortcut to Your Android Home Screen
Windows Phone: :frowning: Oh how I miss Windows Phone Quicky, an easy way to add shortcuts to your Windows Phone Notification Center | Windows Central < But I did find a guide so that made me smile a bit.
looks great, but the yaml you posted doesn’t exatly make it easy. At some point the indentations has been messed up. Could you post the panel yaml’s?
When you past the yaml into the raw config, you need to make sure your indents are correct. Posting new code won’t correct that, since certain devices will mess up indentations sometimes. If you’re unsure of how things should be indented, I’d recommend adding the code to an existing dashboard and verifying indentations. I had to make a few minor adjustments for indents, but after that it worked perfectly.
Is there anything other than the indentations that is not working?
I didn’t post the panels because it is just an entity list, but I’ve updated the post with that.
Hi, this is simply awesome!!! Like this blueprint is a game changer. I’ve been pulling my hair out getting these sensors to work through coding etc. but the blueprint is magic!
1 issue though: Is there a way that feeding and pumping buttons (& count) work without having anything to do with “Amount”. I am not entering amount anywhere (don’t know where to and don’t want to). I am seeing the following error in the trace:
Stopped because an error was encountered at January 16, 2023 at 11:20:01 AM (runtime: 0.02 seconds)
expected int for dictionary value @ data['amount']
EDIT: I created the amount notepad and no longer get this error but there is no feeding logged. Only the counter increases but nothing is logged for feeding. Any way to simply the feeding and pumping logging with dummy values for amount / type etc. Just want to capture last time on press and increment the daily count.
EDIT 2: Amount and method. If only there’s a way to give dummy values for this and not have automations be broken.
Certain API POSTs require certain data values. Feeding requires an amount value otherwise it won’t post correctly and will result in an error. You can reference what pieces of data are required here.
In my UI I just have an amount of “0” and it stays between restarts. It hasn’t caused any issue for us.
