Currently I have HAOS running on an old PC. I have a newer PC that I have HA / Docker installed. I realize I can create a backup and then upload to the new system, right? Or is there some gotcha going from HAOS to HA Docker? I have a couple of ESP32s and my new system wants to adopt them. Would that remove them from the original? Also, do I need all the original addons in the new system before I attempt the restore?
However you can only backup on a Docker install. There is no restore. To restore you need to copy the files manually from the backup archive to your new system.
I just knew there was a gotcha. Is there a wiki somewhere for a noob to follow? Just so I am not confused, I used a suprervised install, so that is a docker install right?
You can backup and restore a supervised install. However you should not use this install method except as a last resort. It requires you to follow some very strict requirements and you must manage your own OS. It seems like a good option but it is not. Unless you really know what you are doing (read the warning). Do you know how to upgrade Python in a Debian environment?
That question is only relevant if you run HA in a venv. But I agree, running supervised is only advised if you know what you are doing, and it is a lot of work to keep it up-to-date.
I only used the surervised because the HAOS didn’t have the drivers for my machine I wanted to use. My pc is a OEM2550L2D-MX, Integrated Dual-core Intel Atom processor D2550 4GB ram Debian works fine on it. The drivers in question were for the nics
I think your new PC is powerfull enough to run HAos in a Virtual Machine (VMWare has my preference as I found VirtualBox pretty unstable, but VWare is a bit more hassle to configure )
I did install it supervised on Debian 11. I wantd to do a backup and restore but that seems like a hassle. I have been thinking about starting over with it on the supervised system. To those who use the supervised system how often do you need to update the OS? Maybe I need to ask that elsewhere?
I was in the same situation.
I used to run HA under VMWare on a W10 host, until I laid my hands on a newer machine.
Decided to go Debian11SuperVised, but found it had too much limitations and restrictions, as the SuperVisor won’t allow you to do much outside running HA supervised.
So I un-installed Supervisor, and re-enstated my VMWare machine.
In the end, the only thing different from before is that my host now runs on Debian11 instead of W10
I can’t stand Windows. Maybe I will see if I can get VNWare on my little guy. Currently I have HA working on an old desktop PC and I want to get away from it. I am spoiled with the HAOS on it. Which version of VMWare are you using? Is there a turorial somewhere I can use to get it installed?
VMWare player is for free, but i use VMware Workstation (v17), as it is a bit more flexible.
However, Workstation requires a license
The Player requires some manual adjustments on the vmx config file (uefi=true and usb device auto mount), in the Workstation that can be done from the GUI.
Also there are some bash files required to auto-launch the VM (applies to both Player and Workstation)
Both run fine on both Windows as well as Linux, and the VM’s themselves are interchangeable between both OS’s
I didn’t use it, but someone wrote a guide It’s for v16, but not much difference with v17
