I’m trying to wrap my arms around badge customization - but I find the docs confusing:
What does
entity-button
mean ?Can anyone provide a sample?
entity-button
mean ?Docs are wrong for that field. The sample in the image you posted is correct.
Perhaps it’s time to correct the docs then?
(I ask, since I failed to correct it - but I tried. Guess I don’t understand how to correct docs - or perhaps I haven’t got the required access rights)
I’d love to contribute, but as I said - I tried,but failed.
Besides, I wouldn’t know what to type instead of what’s already there. All I know (because you said so) is that what’s currently in there - is wrong.
And I think that the main part missing - is an example. And since I haven’t even been able to make it work at all, I definitely don’t have a working sample I can offer (yet).
Well, that’s not much of an example, is it? What exactly does it do?
I tried to add some more to it, like a different icon, show-name: false etc, but whatever I did, absolutely nothing happened. Didn’t even get any error messages!
it put’s a state label badge in the UI.
You cannot change the look of badges. Certain badges have specific items inside the circle, even if you try to override it, it will do nothing. For example, sensors display the state in the center of the circle and do not display an icon. Therefore icon does nothing for sensors. It’s different for every domain type. You have to try it yourself.
I tried to add it as a card manually as it is not available for selection, but got the following error:
That goes in the badges section on a view. They aren’t cards.
I added several badges using entity-filter
and they actually work as intended, but in the badges list nothing shows:
If you’re referring to entity-filter not showing up in the badge list, then that is expected. The UI for that has not been developed yet.
There are some strange things in the docs so far…
These options seem not working:
Test example:
- title: badges
path: test-badges
badges:
- type: state-label
entity: device_tracker.iphone_5s
show_name: false
- type: state-label
show_icon: false
This is not what I am expecting:
The fields only work for certain domains and most domains have different behavior. This makes it appear as if the fields do nothing
Thank you for a quick reply!
I checked these fields with domains (do not have "lights"
, "scripts"
, "input_datetime"
yet):
automation
sun
device_tracker
sensor
binary_sensor
person
switch
zone
group
input_boolean
input_select
input_number
input_text
Checking entities with "show_name: false"
- type: state-label
entity: automation.1
show_name: false
- type: state-label
entity: sun.sun
show_name: false
- type: state-label
show_name: false
- type: state-label
entity: sensor.cleargrass_1_co2
show_name: false
- type: state-label
entity: binary_sensor.updater
show_name: false
- type: state-label
entity: person.ildar
show_name: false
- type: state-label
entity: switch.test_switch
show_name: false
- type: state-label
entity: zone.home
show_name: false
- type: state-label
entity: group.batteries
show_name: false
- type: state-label
entity: input_boolean.test_boolean
show_name: false
- type: state-label
entity: input_select.graph_hours_to_show_test
show_name: false
- type: state-label
entity: input_number.test_number
show_name: false
- type: state-label
entity: input_text.test_text
show_name: false
Now checking same entities with "show_icon: false"
(just in case: including cases when icons are not supposed to be displayed - for "sensors"
, for example):
Seems like it’s now broken.
For the record.
This PR implements the “show_name” option which is not working this moment.
