I haven’t, but I have played with the sip functionality in DoorBird. What SIP integrations are there for home assistant?
I don’t think there’s a native sip component in HA unfortunately.
Hello guys,
It is possible to use my doorbird keypad to turn on inside lights?
Is there an event or something ? Thanks
Hi all,
Really enjoying the Doorbird integration in HA, thanks for all the work.
I am using the relay on my doorbird door station in ‘toggle’ mode (instead of ‘default’), which means they turn on/switch high on a first ‘push’ and turn off/switch low on a second ‘push’. Much like an ordinary switch, with state. It seems that the integration is not yet compatible with this type of switch. I have been looking at te source code and API specs, but have been unable to find a way to alter the behaviour in HA to mimic an ordinary switch. Has anybody got any experience with this?
How are you changing the relay mode? I don’t see it in my Doorbird app.
You can find the option under ‘Administration’ > ‘Relays’ then ‘Mode’ and switch between ‘default’ and ‘toggle’.
Hi Guys
i am also interested in this doorbird system
The indoor : A1101 and outdoor : d2101kv (with keypad)
but i have some questions about it, hope some one can guide me…
I have at my board inside an POE switch, but only 1 UTP cable to the indoor room and 1 UTP cable to the outoor place…
So i can connect both of them, but i also want to make use of the keypad offcourse for my electric door, that UTP cable from my door, also goes to inside to the board…
So if i read the manual, i actually need 2 cables? 1 POE for data and power and 2 extra wires for the relay to open the door? How can i solve this?
I was thinking of using only 4 wires of the UTP , so not POE connected anymore to the outdoor station, 2 wires for the power and 2 wires for the relay, so i can make it happen with 1 UTP right?
For the indoor station, do i need todo the same? do i also need to connect the relays for the electric door? or can i just use the 1 POE cable there? so if i want to open the door from the inside, it goes through lan and gives the signal to the outdoor station?
and what about the power din rail option? can i use one for both indoor and outdoor station? or 1 din power supply for each station?
thnx in advance
EDIT: I read on other forums, that only 4 wires are needed for POE and data? Is that correct? That solves my first question
And what about safety? Isn’t it as simple as taking off the outdoor station and connect the 2 wires to open the door?
With an indoor station, does it also work as stand alone? Or does it need internet access all the time?
i have an indoor A1101 , you can create extra buttons on it (widgets)
i have added a https api call , but seems it doesnt support POST?
how can we add custom tiles on it, to trigger an light for example? how can we do that with an http call ?
webhook only supports POST
Hi there,
I use the doorbird integration (D1101V) but I miss this functions:
- time stamp of the last ring/last motion in the Picture Entity Card
- send the picture of the last ring via notify
Do you have any suggestions?
I have added this two HTTPS calls, but how I get the Logbook for this events?
since my last update doorbird isn’t found anymore. Even when I disable and readd the doorbird it doesnt work anymore. No switch / entities are displayed.
Did I miss anything? any crucial change ?
Nope. Still working here. Should work I think. No breaking changes.
thx i found some problem in the log
Error setting up entry 192.168.5.162 for doorbird
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 249, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/doorbird/__init__.py", line 159, in async_setup_entry
if not await _async_register_events(hass, doorstation):
File "/usr/src/homeassistant/homeassistant/components/doorbird/__init__.py", line 203, in _async_register_events
await hass.async_add_executor_job(doorstation.register_events, hass)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/doorbird/__init__.py", line 280, in register_events
hass_url = get_url(hass)
File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 83, in get_url
request_host = _get_request_host()
File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 123, in _get_request_host
raise NoURLAvailableError
problem was no internal / external url set
If some comes closed to my doorbird without pressing the doorbell buttion, I get a picture via telegram notification. I don’t understand what is the trigger for this because in the integration I have only this event:
Automation:
you must have it setup incorrectly in the schedules section of the doorbird app.
The mistake was, the user in the Doorbird App needs access to API, that’s all
I have a big problem after a factory reset of the doorbird.
Home Assistant > Developer Tools > Events
If I fire this event (doorstation_myname_klingeltaste
) manually, everything works fine.
If I press the button on the Doorbird doorstation, nothing will work.
In the doorbird app (iOS) there is a HTTP(S) call:
- Name: Home Assistant (doorstation_myname_klingeltaste)
- URL: http//192.168.xxx.xxx:8123/api/doorbird/doorstation_myname_klingeltaste?token=xxxxx
The schedule for HTTP(S) call is always on. All users have acces to API.
Where can I find the problem? Do you have an ideas…?
any suggestions for me?
